NSR 125 Oil
aLcOcK
PostPosted: 20:00 - 26 Sep 2009    Post subject: NSR 125 Oil Reply with quote
hi, me and my dad have just removed an engine from a nsr 125 and fitted another one.
What oil do i need to use to top the bike up under the fuel tank and what oil do i use for the engine Smile we're knew to this ahaa.
Also with the coolant whats the steps to fill the radiator
thanks for your help
RichP
PostPosted: 20:18 - 26 Sep 2009    Post subject: Reply with quote
For the oil that you but into the bottle under the tank on the right you should use a good quality two stroke oil, preferably synthetic. Something like Fuch's Silkolene.
For the gearbox 10W40 Engine oil, make sure its motorbike oil though as car oils sometimes have friction modifiers that make the clutch slip.
For the coolant not sure on 'correct' procedure but i filled it up from the radiator cap until it was full to the top. I then topped up the expansion bottle to the low mark. Finally i gave the pipes around the waterpump a good squeeze to prime it.
Start up the engine and blip it to 5000 a few times, top up as necessary.
alains
PostPosted: 08:53 - 27 Sep 2009    Post subject: Reply with quote
yes uses only fully synthetic oil (even for the gear box)
note : the quantity for the gear box is 0.7L no more no less (the level is hard to see precisely , so use liquid measure)
The last post was made 16 years, 184 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 35.4 Kb
