| bbou8284 |
 bbou8284 L Plate Warrior
| chris-red |
| Rottweiler |
 Rottweiler Scooby Slapper
| adama |
 adama Traffic Copper
 Posted: 23:08 - 21 Apr 2009 Post subject: |
Is it your first bike?, 3k+ for what they are is a bit steep, and as far as i know..stock is full power, unless you wanna get a new exhaust system to add maybe a few bhp...all you can do i believe. ____________________ Vlogging - www.youtube.com/caprio85
CBT Passed - 24/04/08 - Theory Passed 18/07/08 - Practical Passed 2/04/09 |
| deanoet |
 deanoet World Chat Champion
| ThoughtContro... |
 ThoughtContro... World Chat Champion
| TUG |
 TUG World Chat Champion
| chris-red |
| TUG |
| Kickstart |
 Kickstart The Oracle
| TUG |
| Kickstart |
| TUG |
| Kickstart |
| TUG |
 Posted: 12:18 - 04 May 2009 Post subject: |
I think we can agree we look at it from different perspectives?  ____________________ Haz ER-5, innit! |
| Kickstart |
| TUG |
| Kickstart |
| chris-red |
| TUG |
| EUMP |
 EUMP Spanner Monkey
 Posted: 22:26 - 10 May 2009 Post subject: |
Could pop in a big bore, but if your riding a 125, then im assuming your early/late 17, so you cant yet  |
| racetec001 |
 racetec001 L Plate Warrior
 Posted: 20:05 - 26 Sep 2009 Post subject: yamaha yzf r 125 deresticting/tuning |
Hi,after reading the posts on this subject and feeling a bit miffed,i thought i should contribute a little as i feel comments along the lines of paying a lot of money for the type of bike,get a bigger bike and the likes are to be kind,both crass and off point.
From experiance on type i would make these comments and also dispell the myths on cats cdi units and the like.
Fact; some cats perform better than others but all cats without exception impede performance in simple form,the better a cylinder head flows [intakes and exhales] the greater the performance,period,cats restrict exhaust gas removal because firstly they cause a positive exhaust gas pressure between the cat and the exhaust manifold[not good for head gas flow] and then there are a dozen other reasons i won,t bore you with unless pressed.
The cdi unit in this case,is coupled to digital fuel mapping and factory fixed set to give optimum performance whilst achieving emissions compliance,hence it is possible to gain considerable power by removing the cat and tricking this unit to perform better,i will explain the mods i have done and the power gains a little later run out of space on this post. ____________________ forward motion,max attack |
| racetec001 |
 Posted: 20:37 - 26 Sep 2009 Post subject: yamaha yzf r 125 derestict/tuning |
FOLLOW ON FROM PREVIOUS POST.
Ok,my sons bike,09 model with 1800 miles,standard bike,power run on dyno,14.2 kw 74 mph.
Mods done,cat removed, exhaust manifold matched to cyl head,inlet intake re worked and matched to inlet port, road run for 50 miles then second dyno run 15,7 kw 83 mph.
After re think and speaking with yam technical,stock bike has ignition retarded by 4 degrees to eleviate engine knock because of high cylinder head temps from low octane fuel and heat build up from cat.
Second mods put inline electronic filter between ignition sensor and cdi to gain 5 degrees of ignition advance by delaying ignition signal [confusing the cdi],changed fuel to optimax[shell V power] and added octane booster.
Further power run on dyno 17.2 kw 91 mph with a improved 40 mph to 70 mph over stock just shy of 4 seconds quicker.
More devolpment now,i have a spare engine in bits doing a lot of technical calculations and measurements,so far i have found that the camshaft has plenty of lift but is shy on duration on both the inlet and exhaust side,so needs reprofiling plus i have,nt done anything with the electronic fueling yet,so will keep you posted as devolpments are made. ____________________ forward motion,max attack |
| 0ddball |
 0ddball World Chat Champion
| tutton |
 tutton World Chat Champion
The last post was made 16 years, 123 days ago. Instead of replying here, would creating a new thread be more useful? |
