| stinkwheel |
 Posted: 18:47 - 26 Sep 2009 Post subject: Is my microfilter microfiltering? |
My internet connection has been somewhat tempremental recently.
I just realised this started when I got a new phone (A BT cordless one).
The internet connection doesn't stay up properly but the modem thinks it does, sites return "no data" after a while of trying to connect to them.
Does it with two different wired routers. To get it back, you need to switch both the router and the computer off then back on again.
I also get an occasional beep on the phone line (not call waiting, it's a different sort of beep and I don't have call waiting).
This is leading me to conclude that the phone is interfering with the internet connection. I've tried two other microfilters and it made no difference. I unplugged the phone last night and the connection has stayed up since then.
Does this sound plausible/possible? Any suggestions as to what I could do about it?
Maybe plug the phone and the router into different sockets, each with a microfilter? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Frost |
 Frost World Chat Champion
| stinkwheel |
| neil. |
 neil. World Chat Champion
 Posted: 05:31 - 27 Sep 2009 Post subject: |
With microfilters, the ones with the trailing lead (on the right) are best, and contain more electronics to deal with rogue nastiness etc, so use them over the small 'socket doubler' types.
It may be something in the house causing interference on the line. A general rule of thumb is to connect the router to your master socket, rather than an extension socket. If you're already doing this, then, if your master socket is an NTE5 one, you can unscrew the faceplate to reveal a test socket that basically sits before any extensions etc. Try that and if your connection works, then something at your end is up. If not, then it could be a dodgy router or a problem with the line itself. Your ISP should be able to test it out.
A last resort option is disconnecting the ring wire in your master socket, but don't try that unless you are confident with it as it will be costly to sort things out if you mess up.
See also: https://www.kitz.co.uk/adsl/socket.htm
Good luck with it! These things can be a complete bitch to get fixed. ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| duhawkz |
 duhawkz World Chat Champion
| stinkwheel |
 Posted: 22:19 - 27 Sep 2009 Post subject: |
Is hardwired with cat6 cable. I don't buy into all this wireless crap. It's something else to go wrong, slower, less secure and totally unecessary for my desktop computer. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Alexio |
 Alexio World Chat Champion
 Posted: 01:07 - 28 Sep 2009 Post subject: |
I guess the only other possibility is that your phone is faulty. The micro-filter is probably doing it's job of splitting the frequencies that the broadband and phone signals operate on, but if the phone is putting those higher frequency signals on the line anyway due to a malfunction then it will interfere.
Just throwing it out there...
Can you try using a different phone? Otherwise, in my experience, it's almost always a badly wired up house as far as the phone cables are concerned. Use the master socket etc etc etc.  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| CaNsA |
 CaNsA Super Spammer
| divuk83 |
 divuk83 World Chat Champion
The last post was made 16 years, 359 days ago. Instead of replying here, would creating a new thread be more useful? |
