Battery losing charge
HeavensBiker
PostPosted: 13:05 - 06 Oct 2009    Post subject: Battery losing charge Reply with quote
hi people i got a mz301etz.when the battery is connected it loses charge quite quickly.ther are 2 blanks space in the fuse holder but not sure what for?has anyone got a wiring diagram?also wer can i get a front disk for it it a k reg wire wheels.cheers
mrt
PostPosted: 22:24 - 06 Oct 2009    Post subject: Reply with quote
HB, don't know best place for a disc, but the battery drain can usually be found using a multimeter.Make sure the ignition switch is off and keys out.Charge the battery up and connect the positive lead up to the bike, then select the amps range on the meter and place one meter lead on the negative batt terminal and the other on the bikes negative lead.You should see preferably 0.00 amps being drawn with the ignition being off. For a car a max of 0.05 amps is allowed, so a bike should see any more than 0.03 amps max I would imagine.Let's say you've got a 0.50 amp drain on this test.Now pull the fuses one by one until the drain drops to below the threshold - when it does you've isolated the offending circuit.From here you can then re-fit the fuse, and disconnect components on that circuit until you've found your drain. Remember to move the wiring harness around to incase you have a partial short in the loom.Hope this helps. Very Happy[/list]
mrt
PostPosted: 22:30 - 06 Oct 2009    Post subject: Reply with quote
Sorry for the jumbled post, the text box just shrinks all my paragraphs into one box!
HeavensBiker
PostPosted: 15:27 - 07 Oct 2009    Post subject: Reply with quote
aha thanks a lot mrt.that will come in great help for when it come to the strip down.have you any idea where i can get front fork seals cheers
The last post was made 16 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 2.43 - MySQL Queries: 13 - Page Size: 38.52 Kb
