here comes the cold...(heated grips)
steppen22
PostPosted: 16:19 - 07 Oct 2009    Post subject: here comes the cold...(heated grips) Reply with quote
I must get some heated grips this year. Don't want another year of stuffing cotton wool into my gloves to try to keep warm...
which are regarded as good grips, which ones to avoid?
are there any that can be removed, as I have various bikes (main=er5)
no regrets, no retreat, no apology.
I've made mistakes in the past, and I apologise for FUCK ALL.
Skudd
PostPosted: 16:33 - 07 Oct 2009    Post subject: Reply with quote
I got a set of Dr Bike heated grips, same as Oxford except cheaper, made by the same people just branded defferently. They have been excellent, very easy to fit.
Oxford do a wrap around mat that goes on your grip, they can be taken off and moved around to other bikes, but I don't like them as they make the grips larger, although they are good for pillions holding on the hand grips at the back of the bike.
Charlie
PostPosted: 16:40 - 07 Oct 2009    Post subject: Reply with quote
My oxford ones have been pretty good... and I realised the other day that they make it very easy to use an optimate as you just disconnect the wire going to the battery and connect to the optimate, useful if you bike battery doesn't last very well over the winter (there must be a charging problem somewhere) and the fact that when plugged in the oxford grips very slowly drain some power from the battery.
Irezumi aka Reuben
Carrot Top
PostPosted: 17:21 - 07 Oct 2009    Post subject: Reply with quote
Hand guards do a better job in my experience.
As for grips, look up sickpup on here. He sells good ones. Thumbs Up
neil.
PostPosted: 18:49 - 07 Oct 2009    Post subject: Reply with quote
Oxford Hot Hands are removable. They get pretty toasty even through my winter gloves and have no thermostat so it's a choice between hot or not. I just relax my grip and let air flow under my hands to cool things down. When it gets really cold I shove the bar muffs on. Thumbs Up
smegballs
PostPosted: 00:31 - 08 Oct 2009    Post subject: Reply with quote
I'm thinking of making some bar heaters this year.....
Gonna get some constantan and wrap up a load of loops round some sort of insulating former, then cast it inside a resin cylinder to put inside the bar.....
Don't suppose anyone knows a good thermally stable castable resin as I have no idea.....
Acemastr
PostPosted: 07:11 - 08 Oct 2009    Post subject: Reply with quote
Oxford grips here, when wet they cause my throttle to become really quite difficult to twist oddly enough, but are lovely and warm. Do drain battery on a YBR pretty nicely though, it's either lights or grips unfortunately.
2016 Toyota Tacoma Limited
smegballs
PostPosted: 07:34 - 08 Oct 2009    Post subject: Reply with quote
This is a bit worrying with everyones grips draining their battery....
Say you had 20W of grips running (10W per hand), that should still be pretty warm, electrically should only be like an extra indicator bulb being on all the time which isnt much load....
I suppose the cold and possibly old batteries conspire together to make for a drainy charging system. A little ampmeter like on the old bikes would be good see where the power is actually going.....
Really how hot do you need them? If you have gloves on as well, surely the main thing is just to take the edge off the cold and get a little heat back in your hands rather than give them a massive roasting...
Acemastr
PostPosted: 08:05 - 08 Oct 2009    Post subject: Reply with quote
Brand new bike, even cut out one day going along the A14 because it had no charge. I have 'all year' gloves, even with liners and the grips my hands still hurt extremely bad.
Mal
PostPosted: 08:13 - 08 Oct 2009    Post subject: Reply with quote
I've got a set of the Oxford heated grips - do an ace job, my only problem is I've drained my battery twice by forgetting to switch them off (any hints on how to wire them into the ignition circuit would be gratefully received).
I've actually got a set of the Hot Hands too (unused) which were bought in error, now if I can only remember where I put them....
Mal
Current: 2002 FJR1300, 1999 Thundercat, Previous: 1998 XVS650 Dragstar
"In the end we're all just chalk lines on the concrete - drawn, only to be washed away."
smegballs
PostPosted: 08:31 - 08 Oct 2009    Post subject: Reply with quote
Right then Mal, you first have to find out which is the ignition controlled live on your bike. Look in a wiring diagram for that, it will be the one connected to the CDI, coils etc when the key is turned....
Here is a diagram, you might want to relay it instead of a direct connection but its too early for relay diagrams Laughing
https://i35.tinypic.com/167qgjp.jpg
The second fuse is optional but recommended in case anything fucks up. Just an inline fuse is fine. To work out you fuse value use A = P/V
ie, if its a 12 volt system with 24w grips installed, then you have 2 amps of current so a 3 or 5 amp fuse would be appropriate.
HTHn Thumbs Up
the grim reaper
PostPosted: 10:04 - 08 Oct 2009    Post subject: Reply with quote
I wouldn't recommend the Dr bike ones. The back of the control unit is an open PCB, mine blew up in the first week. The supplier sent me a new set and the throttle grip stopped working after three months. Fortunately, I didn't send the original ones back, so I will replace the throttle grip with the one from the first set.
Apparently the Dr Bike and early Oxford ones are renowned for failing on the throttle side, because the cable into the grip breaks at the point that it enters.
Grim
Charlie
PostPosted: 10:11 - 08 Oct 2009    Post subject: Reply with quote
if you are buying new oxford ones there is no need to wire them up like that as the will turn off when the battery drops below a certain level.... how ever this means that even when they are off they do draw a small amount of current, over time it is quite a bit and that plus a cold, hard to start motor normally does the battery over. Well it does on my little 250 (which I am pretty sure has the same battery as the 600 Thinking )
t121anf
PostPosted: 10:32 - 08 Oct 2009    Post subject: Reply with quote
got oxford ones on my bike, adjustable temp, only on if ignition is on.
just wish they weren't so fat
Jayy
Mr. Ponzi
PostPosted: 11:10 - 08 Oct 2009    Post subject: Reply with quote
Might invest in a set of these as it literally is starting to get fooking freezing now. Like in the past 2 weeks it's gone to sub zero temperatures.
Have to start taking it easy as I'm still thrashing my bike like it's summer weather and as I found out yesterday, opening the throttle fully for a quick burst, the back wheel spins like fuck when it's freezing cos there's less grip on the road.
Can't wait to get my KTM now.
smegballs
PostPosted: 11:20 - 08 Oct 2009    Post subject: Reply with quote
Grim
Thats the main reason I don't like the sound of heated grips. The throttle heater has to rotate and stretch which must fatigue the cable.....
Google "warmfit" bar heaters, its a solid lump that sits inside the bar and heats it up that way
Review of them here fitted to a MZ: https://homepage.ntlworld.com/nicholas.kotarski/Heaters.htm
Whosthedaddy
PostPosted: 11:27 - 08 Oct 2009    Post subject: Reply with quote
Anyone used heated gloves instead?
Mr Hammers
PostPosted: 11:33 - 08 Oct 2009    Post subject: Reply with quote
It would seem WarmFit isn't trading anymore. Sad The site does give a UK retailer email addy though, so i've mailed them to ask if they still have any sets left. Will update when i get a reply...
A Guide To Powerbands
Peirre oBollox
PostPosted: 19:33 - 08 Oct 2009    Post subject: Reply with quote
Pollyheaters?
https://www.pollyheaters.com/
Clanger
Stirrer
PostPosted: 20:01 - 08 Oct 2009    Post subject: Reply with quote
I've got a set of heated grips, they've been sitting on the floor next to the bike for...oooh a good year now. Laughing
steppen22
PostPosted: 12:38 - 18 Oct 2009    Post subject: Reply with quote
how hard are these to fit?
tsmith
PostPosted: 13:48 - 18 Oct 2009    Post subject: Reply with quote
I've got Daytona heated grips and they are excellent. Been using them for almost 10 years now.
https://www.sounddistribution.co.uk/products.asp?recnumber=2015
Clanger
Stirrer
PostPosted: 19:26 - 18 Oct 2009    Post subject: Reply with quote
Really really wish my heated grips were on the bike today...brrr!
Jayuk
PostPosted: 00:57 - 19 Oct 2009    Post subject: Reply with quote
The newer oxford ones 2008 and above can be wired direct to the battery, the current draw is tiny.
Also they turn themselves off when they sense a drop in power from the Battery.
I have left mine on so many times and never come back to a flat battery.
Hmmmm maybe the Varadero has a very good Battery (i doubt it) but i use them with the lights and my sat nav running never have any problems
Jay
Previous (in no order) Yamaha Passola - DT50mx - MZ TS125 - KE125 - DTR 125 - RD350 - RD500 - YZ125 - YZ250 - NSR125 - KR1S.
Current - CBBF600sa - Honda Varadero
Tarmacsurfer
PostPosted: 01:17 - 19 Oct 2009    Post subject: Reply with quote
22 posts in and Sickpup hasn't mentioned that he now stocks a range of heated clothing? I'm surprised Shocked
In light of this, I'll help out. Sickpup now sells heated clothing Very Happy
I'm immortal. Well, so far.
The last post was made 16 years, 355 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 126.77 Kb
