"over"-revving
TechJinx
PostPosted: 09:45 - 09 Oct 2009    Post subject: "over"-revving Reply with quote
not sure if this is common but when you accelerate hard is it usual for the bike to appear to over-rev.
What I mean is that if I crank the throttle about 75% as quickly as I could then I get normal smooth acceleration but if I'm in second for example and twist full on the revs will jump but it seems to take a while for the engine "pull" to catch up.
So you'll get a jump in the Revs to say 10,000 then despite still being full on throttle they'll then creep back to 7-8000 and you'll feel the bike accelerating and the revs creep back up speeding the bike up.
Is this something fairly common? Sorry if it's explained badly
bikes: SV650S K5 that is making me do this Very Happy 57 CBR125 RW-7 - sold ; 54 CBR125 - anyone wanna buy a project?
YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE DUCT TAPE.
serlant
PostPosted: 09:55 - 09 Oct 2009    Post subject: Reply with quote
That will be the clutch slipping, adjust the cable to the free play specified in the manual, and if it still slips might be time for a new clutch.
TechJinx
PostPosted: 10:49 - 09 Oct 2009    Post subject: Reply with quote
Means nothing to me, I'm a technical dunce! Laughing
Is this the kind of thing that would be picked up/fixed on a service as it's due one in a few miles or so?
Ol
PostPosted: 10:58 - 09 Oct 2009    Post subject: Reply with quote
Adjusting the Cable MIGHT be included in the service depending on where you take it, although i doubt it. Changing the clutch definately wont be included! The bad news is that it's only going to get worse before you get it fixed !
Olly.
serlant
PostPosted: 11:19 - 09 Oct 2009    Post subject: Reply with quote
for free play basically this, but change 3mm to whatever it specifys in your manual.
https://i419.photobucket.com/albums/pp276/thump_140/clutchfreeplay.jpg
Charlie
PostPosted: 11:45 - 09 Oct 2009    Post subject: Reply with quote
If you went to a bike meet I am sure you could get someone there to adjust it (via the adjuster at the top), it really isn't hard. They have the same system on pedal bike brakes.
Jayy
Mr. Ponzi
PostPosted: 11:57 - 09 Oct 2009    Post subject: Reply with quote
Something I've noticed on my 98 ZX6R is when you accelerate full throttle and it hits about 12k it suddenly bursts a spout of power for a second. Is that just a power valve?
Coxyzxr
PostPosted: 13:12 - 09 Oct 2009    Post subject: Reply with quote
Humm... no...
It's either 2 things. Clutch slips then regains or if it's bang on same RPM each time its the "Powerband" term used with trepidation
It's when the ZX6r wakes up, use and abuse it.
**WAS FITTED "WRONG WAY ROUND" !** CANT ACCOUNT FOR THE STUPID !
Alexio
PostPosted: 13:40 - 09 Oct 2009    Post subject: Reply with quote
As you slowly release your clutch while changing gears it helps to be slowly decreasing your throttle as well anyway so that the two "meet" faster. Sometimes the revs will match where they are supposed to be while the clutch is still partially engaged (slipping) so that as you release the clutch entirely you wont get any of this unpredictable RPM Business anyway. This definitely sounds like a clutch cable issue though. I suggest adjusting it immediately. A kind garage will spend 60 seconds doing it for you most likely.
Hope I've explained that well, I'm not always good at articulating what I mean.
TechJinx
PostPosted: 13:42 - 09 Oct 2009    Post subject: Reply with quote
Cheers for the reponses guys - I'll try the cable tonight as that looks like a simple fix if thats the problem. Otherwise I'll get her down the garage.
On an unrelated note - upsettingly the first winter glove day of the year for my commute Sad
Andy
Alexio
PostPosted: 13:48 - 09 Oct 2009    Post subject: Reply with quote
Andy
Agreed, was absolutely freezing last night and needed my winter gloves for the first time. Better get used to it, on a bike winter is always far too long Thumbs Up
TechJinx
PostPosted: 13:52 - 09 Oct 2009    Post subject: Reply with quote
The REALLY upsetting thing will be when I need to put the muffs on the handle bars.....
Muscle Bike Rider
PostPosted: 13:57 - 09 Oct 2009    Post subject: Reply with quote
Can you adjust the pressure of the clutch leaver here to? mine feels a bit tight / stiff would be nice a bit looser easier, sometimes when stood at lights for a while you gotta keep a tight grip on lever, recently had new clutch cable fitted after it snapped by RAC, guy said it would soften up after a bit of use but it still feels the same.
Ta,
Paul.
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
Polo
PostPosted: 14:12 - 09 Oct 2009    Post subject: Reply with quote
I thought I had clutch slip on my bike but I actually realised that when I was getting a bit spirited and making really good progress Wink I was actually pulling on the clutch lever a snatch in anticipation of the next gear change.
Conciously take your fingers away from the lever next time and just grip the bar and see if it still does it - before you adjust stuff!!! Thumbs Up
My mum smells your fingers
iooi
PostPosted: 20:05 - 09 Oct 2009    Post subject: Reply with quote
A5tra_G wrote:
sometimes when stood at lights for a while you gotta keep a tight grip on lever,.
If waiting at lights for a while then sit in netural Rolling Eyes
T0MMY
PostPosted: 11:25 - 10 Oct 2009    Post subject: Reply with quote
May I be the first?...
That'll be the tension in the powerband releasing. Basically, as the rev counter goes round it tightens up the powerband and then at 12k rpm the tension is suddenly released to add a spurt of power. This is how wheelies are done.
powerband joke no. 21549, copyright T0MMY 2009, all rights reserved
ZX6R + CBR600RR
The last post was made 16 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 14 - Page Size: 93.4 Kb
