Tips for brake bleeding
Cigaro
PostPosted: 08:56 - 12 Oct 2009    Post subject: Tips for brake bleeding Reply with quote
Right, I've been bleeding my brakes on the GN for half an hour now and I can't seem to get anywhere.
When I open the bleed nipple with the lever pulled back, fluid comes out and it seems to be bubble-free. However, no matter how much I pump, I can't get a firm lever.
There are no leaks anywhere. Yesterday I tried tying the lever to the bar overnight to get any extra air out. Still not getting anywhere.
Why would there be fluid coming out of the bleed nipple but no pressure on the brake lever? Help!
(I've also tried loosening both banjo bolts to try and get the air out of them).
Cigaro
PostPosted: 09:17 - 12 Oct 2009    Post subject: Reply with quote
Sorted it - loosened the top banjo bolt with the lever held in and retightened, straight away the lever went firm. Think there must have been some air trapped Smile
Bishbash
PostPosted: 15:03 - 12 Oct 2009    Post subject: Reply with quote
Glad you got it sorted, just a little tip for you, might help you and others in the future.
If you have had the calipers off and there is absolutely no fluid left, fill the reservoir up and remove the hose from the caliper and place the hose in the brake fluid bottle or a cup of brake fluid, pump the brake lever until there is no air left, then place the cap on the reservoir to stop the fluid running through and then bolt the hose back on, then open the bleed nipple and pump again until you have a brake.
Should take 5 minutes to do!
HTH Thumbs Up
the grim reaper
PostPosted: 15:23 - 12 Oct 2009    Post subject: Reply with quote
Another tip, if you suspect that there's air at the high point of the hose, unbolt the brake assembly from the bar and simply tilt the whole mechanism, saves getting nasty brake fluid everywhere and has the same effect. Should only be two 8mm bolts on most jap bikes.
Grim
acid drop
PostPosted: 18:58 - 13 Oct 2009    Post subject: Reply with quote
Oh and another tip take the bike to the dealers and pay for someone else to do it, it's less ''Stressful''
Cigaro
PostPosted: 08:26 - 15 Oct 2009    Post subject: Reply with quote
Takes all the fun out of it, that does.
buddy
PostPosted: 19:48 - 17 Oct 2009    Post subject: Reply with quote
i was bleeding my brakes today and ive got a fair bit of pressure but the lever isnt as firm as i would like it
is it a good idea to tie the lever to the handlebar. there is a fair bit of firmness but if i squeeze hard i can get the lever to touch the bar
what im saying, is will i damage anything?
When this baby hits 88 miles per hour... you're gonna see some serious shit.
DazHornet
PostPosted: 22:56 - 17 Oct 2009    Post subject: Reply with quote
ive heard of alot of people doing this.
just leave it for one night tied to the bar and it should firm up.
but you wont get any major gains from doing this to be quite honest.
buddy
PostPosted: 10:08 - 18 Oct 2009    Post subject: Reply with quote
well i did it for about half an hour(before you posted, i didnt wanna damage it)
and it helped slightly, but i then read back about the banjo bolt and again it helped slightly, tbh theyre now at an acceptable level
bazza
PostPosted: 11:11 - 18 Oct 2009    Post subject: Reply with quote
Get a vacuum pump kit.
Approved for use by mechanical numpties like me. Thumbs Up
PostPosted: 12:46 - 18 Oct 2009    Post subject: Reply with quote
Tying the lever to the bar is fine. I did it with my TZR overnight and the next day the lever was lovely and firm.
That_Hornet
PostPosted: 13:36 - 18 Oct 2009    Post subject: Reply with quote
Is this the weekend for working on brakes or something?
I fitted some braided hoses on the hornet yesterday.
Bleading them i got myself one of these.
https://www.amazon.co.uk/Draper-5010559373161-37316-Bleeding-Kit/dp/B0001K9TTM
Top bit of kit. Took 15 minutes, at most, for the 3 calipers.
DazHornet
PostPosted: 16:37 - 18 Oct 2009    Post subject: Reply with quote
dont see the point in someone else doing such an easy job Shocked
like the previous said, it costs money Shocked
no mechanic bills FTW!!!
PostPosted: 19:10 - 18 Oct 2009    Post subject: Reply with quote
I found a pipe in my toolbox with a 1 way valve in it. Works wonders.
Stelmer
PostPosted: 20:03 - 18 Oct 2009    Post subject: Reply with quote
I put a fuel filter on the end of a hose attached to the nipple, a clear hose on the filter and sucked the fluid into each caliper.
Then proceeded with the traditional method which worked well. Took about 30 mins.
bazza
PostPosted: 20:11 - 18 Oct 2009    Post subject: Reply with quote
Vincent wrote:
I seemed to have managed perfectly well for 30 years with just a jam jar and a pipe with no valve.
Have a cookie.
Velopete
PostPosted: 12:25 - 21 Oct 2009    Post subject: Brake Bleeding on Honda CB250RS Reply with quote
Hi Everyone.
I have just spend a number of hours over 3 days trying to get my brakes bled after overhauling the master and slave cylinders on my CB250RS. The problem I was having was that there was so much air in the system that I could not get it out using regular bleeding methods. The small motorcycle master cylinder just compressed the air in the systme only pushing out a few bubbles at a time. I came across your forum in a search for a solution. I tried the vacuum approach to get the air out that someone suggested but this only sucked air in through the bleed valve threads.
In the end I tried pushing the slave cylinder back into its housing with a wooden wedge leaving the reservior cap off. This successfully ejected a lot of air back into the reservior and eventually I was able to get the brake working again and completed the job by bleeding the last few bits of air via a tube and jar with fluid.
Many hours wasted here so I thought I would share my discovery for anyone struggling with this problem.
Barry_M2
PostPosted: 12:39 - 21 Oct 2009    Post subject: Reply with quote
Why people do this I've no idea!?
When you pull the brake lever in, it closes of the fluid to the reservior. So no air is going to escape from the brake line!
Pointless!
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
Barry_M2
PostPosted: 12:41 - 21 Oct 2009    Post subject: Reply with quote
Ditto, even when fitting completely new (dry) lines. Never had a problem.
Do I get a cookie too Bazza? Very Happy
Pleeeeeeease.... Thumbs Up
PostPosted: 12:48 - 21 Oct 2009    Post subject: Reply with quote
Pointless!
Not sure but it does seem to work to an extent.
Only thing I can think of is that having the lever pulled hard overnight gives a chance for air to accumulate in the master cylinder near the piston. When you release the lever the caliper pistons push back slightly (and air in the system expands to push fluid back) and pushes the air out as the hole into the reservoir is uncovered.
You would think that the same would happen if you normally pull and release the lever. I can only assume that doing this normally doesn't give the air a chance to accumulate near the m/c piston and so just fluid gets pushed back into the reservoir.
Keith[/url]
Barry_M2
PostPosted: 12:52 - 21 Oct 2009    Post subject: Reply with quote
Keith[/url]
Mmm, possibly. But having never had this problem I've not tried it.
The last post was made 16 years, 221 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.13 - MySQL Queries: 13 - Page Size: 130.39 Kb
