Car brake discs
Noxious89123
PostPosted: 18:54 - 13 Oct 2009    Post subject: Car brake discs Reply with quote
Do you reckon these are fucked?
I think they are, the lip on the edges is alot thicker than the total thickness of the disc. Standard thickness is 20mm, min. is liste as 18mm. But apart from the amount of wear, is this level of corrosion "normal"?
https://img62.imageshack.us/img62/4764/small1000547.jpg
https://img62.imageshack.us/img62/7676/small1000548.jpg
https://img385.imageshack.us/img385/8171/small1000549.jpg
Can get a set of replacement discs and pads for just £30.
Car pulls slightly to the left under heavy braking. It's a '53 plate Ka.
acid drop
PostPosted: 19:03 - 13 Oct 2009    Post subject: Reply with quote
I would say those discs are past their sell by date, If you can get discs and pads for thirty quid go for it, Brakes on a car are as important as brakes on a bike.
Noxious89123
PostPosted: 19:20 - 13 Oct 2009    Post subject: Reply with quote
Good answers, I already bought the discs yesterday, and received them today Thumbs Up Laughing
Thought they looked prtty fucked.
The inner vanes look like they've already been coated with black vht paint, so that's all good.
Cba to totally strip and clean the calipers. The outer edge of the piston look pretty corroded to fuck anyways. It's far enough out that it isn't a problem. But by the time I've gone through this new set of pads, an the piston is futher out, it'll probably have correded further.
In which case I'll just replace both calipers.
£35 each from Ford Thumbs Up Laughing
This car is a bag of shit, but i love it for that reason. It's so cheap on everything Very Happy
Nb
PostPosted: 22:08 - 13 Oct 2009    Post subject: Reply with quote
As you already know there fooked. But, is that car a ka? If it is, look at the picture and in the red circle the subframe/body mount looks fairly corroded. This can fail the mot if the tester has any clue what hes doing, failed two in recent weeks on those areas. Neutral
https://img.photobucket.com/albums/v678/blazebrown/kasubframemount.jpg
Noxious89123
PostPosted: 22:23 - 13 Oct 2009    Post subject: Reply with quote
It is, and it does look rather corroded.
Might give it a rub down and coat it with some hammerite. Sound like a good plan?
(Fuck yeah, everyone in Workshop loves hammerite!)
I have a good friend who is a welder, so if it's fucked, he can fix it. Smile
Noxious89123
PostPosted: 22:35 - 13 Oct 2009    Post subject: Reply with quote
I've not checked the other side yet, I'll check them both thoroughly when I do the brakes.
If it's particularly bad, then I'll just have to do what I can, and then flog it asap...
I really got ripped off when I bought this pos.
Cigaro
PostPosted: 07:22 - 14 Oct 2009    Post subject: Reply with quote
Remember you'll have to push the piston back in to get the pads to fit.
Nb
PostPosted: 17:30 - 14 Oct 2009    Post subject: Reply with quote
Yeah, clean it up and hammerite the crap out of it. And then grab some gravel and chuck it so it sticks on, nobody will see it. Mr. Green You can get a welding repair kit from ford, the repair normally costs about 250 pounds all in. Shocked
PostPosted: 18:14 - 14 Oct 2009    Post subject: Reply with quote
A bit of Araldite and it'll be as good as new.
Noxious89123
PostPosted: 18:39 - 14 Oct 2009    Post subject: Reply with quote
They don't move all the way back ino the caliper, part of it will always stay stuck out, as there is a groove aroun the piston where the dust boot attaches. The pads that are in there at the moment have alot of meat left on them too, but i figured I'd do pads and discs at the same time, especially as it was only £30 for the lot.
PostPosted: 19:39 - 14 Oct 2009    Post subject: Reply with quote
Those disks look rather thin, although remarkably smoothly worn for how worn they are.
don
PostPosted: 22:41 - 21 Oct 2009    Post subject: discs Reply with quote
Car discs are cast iron, so always look rusty, its best to tap round the circumference with a hammer,,,the rust round the edge will ping off,after that check the disc thickness, and the condition inside the vents, and the disc surface for cracks.
Remember the rust round the circumference has swollen to twice its original size, so dont think that because the rust is thick it means the disc has worn that much,
I did a pads replacement for a mate,,,he was used to bikes,,,he freaked out when he saw the rusty discs,,,went to the local garage who sold him genuine replacement discs and calipers when they werent needed,,,hundreds of pound unnecessarily.
As for painting to stop the rust forming when it isnt going to be seen,,,why bother, itll come off anyway
cbr600
The last post was made 16 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.58 - MySQL Queries: 13 - Page Size: 79.62 Kb
