| honda-cg |
 honda-cg L Plate Warrior
 Posted: 18:53 - 13 Oct 2009 Post subject: Carb problem !! |
Hello, i recently purchased a Honda cg125 (1993) the previous owner had problems with the carb (always running on half choke) - i messed about with the idle screws for a while with no success then stupidly decided to remove the chamber from top of the carb now i can't get the bike to fire up. anyone any suggestions ??? thanks |
| Billing |
 Billing World Chat Champion
 Posted: 19:25 - 13 Oct 2009 Post subject: |
any money you've put the slide in backwards, take the top off, twist it 180 degrees (line the groove in the slide up with a little bump in the carb body) then put it back in, basically you've made it go wide open throttle  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| Blue_SV650S |
 Blue_SV650S World Chat Champion
| honda-cg |
 Posted: 20:45 - 13 Oct 2009 Post subject: |
| honda-cg |
| Blue_SV650S |
 Posted: 20:58 - 13 Oct 2009 Post subject: |
| Billing |
 Posted: 09:03 - 14 Oct 2009 Post subject: |
Trust me Blue, you can do it because it did exactly the same thing on mine and if you turn the slide 360 degrees itll end up in the same place with the same problem XD ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| honda-cg |
 Posted: 13:48 - 14 Oct 2009 Post subject: |
Yeah your spot on - don't know what i was thinking about it was in the correct position but think the carb's fooked as i need to run it on half choke  |
| Blue_SV650S |
| Alexio |
 Alexio World Chat Champion
 Posted: 14:53 - 14 Oct 2009 Post subject: |
Gah, WHAT IDIOT WOULD RUN THEIR CG ON HALF CHOKE?!
Definitely clean up that carb with some well deserved TLC. I shouldn't get angry about what is unsurprisingly a mistreated learner bike but the RSPCCG has responsibilities to maintain. ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
The last post was made 16 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
