Speedfight 100 '98
TUG
PostPosted: 18:31 - 16 Oct 2009    Post subject: Speedfight 100 '98 Reply with quote
Hey guys, bought a speedfight 100 to get me back on the road.
Feels a bit sluggish though for a 100 and top speed is around 52mph just wondering if it should be higher than that its done roughtly 18000miles maybe 20000.
Cheers.
Haz ER-5, innit!
PostPosted: 18:40 - 16 Oct 2009    Post subject: Reply with quote
Top speed should be around 65mph.
You're the mechanic, fix it Laughing
TUG
PostPosted: 19:41 - 16 Oct 2009    Post subject: Reply with quote
Lol shut up smart arse, i've never had anything automatic past 50cc, thought it should be around 65ish, bet its mixture isnt set up propperly.
Haz ER-5, innit!
PostPosted: 20:00 - 16 Oct 2009    Post subject: Reply with quote
When was it last serviced and has it been sat around for a while?
I doubt it's mixture as why would someone mess about the the carb on a standard bike?
I'd either put it down to dirty carb, rollers or worst case scenario, lack of compression, but that's unlikely considering my dads Vivacity 100 is on about the same mileage and runs like it did when it was new.
TUG
PostPosted: 20:02 - 16 Oct 2009    Post subject: Reply with quote
Could of been mauled with then put stock, you never know, It doesnt smoke much which is quite worryinng and has used quite alot of petrol in the past day (already on half a tank).
You at staff bike show tommorrow? i am. Laughing
Haz ER-5, innit!
PostPosted: 20:08 - 16 Oct 2009    Post subject: Reply with quote
Half a tank? you're just riding it too much in excitement Wink
Yeah, I'll be at Stafford trying to get bits for the Chaly.
TUG
PostPosted: 20:14 - 16 Oct 2009    Post subject: Reply with quote
PM me ur number or MSN or facefuck, which ever, should bump into u, wont be on the monster that is the speedfight tho lol
Haz ER-5, innit!
stevo as b4
PostPosted: 22:12 - 16 Oct 2009    Post subject: Reply with quote
probably needs a belt and rollers TBH! You do know that a std SF100 only does about 54mph, and this is 90kph/56mph indicated on the speedo. You will not get much more than 60mph on the clock even down hill!
TUG
PostPosted: 22:19 - 16 Oct 2009    Post subject: Reply with quote
Restricted vairiator?
Haz ER-5, innit!
stevo as b4
PostPosted: 17:45 - 17 Oct 2009    Post subject: Reply with quote
The std bike has definately not got a restriction in the variator, if had one apart several times. You might want to change you belt and rollers if they are worn, as you can loose 5mph+ from worn parts.
TUG
PostPosted: 17:53 - 17 Oct 2009    Post subject: Reply with quote
When i first start it, and try to set off, it floods the bike and i have to wait a few seconds until i can restart the bike too.
Haz ER-5, innit!
stevo as b4
PostPosted: 22:23 - 17 Oct 2009    Post subject: Reply with quote
That sounds like it might be the auto choke sticking on, or dirt in the carb etc? It's worth stripping and cleaning the carb. Get yourself a belt and roller's if they have not been changed in the last 3000-4000km, as they never last longer than that from my experience.
If it get's close to an indicated 58-60mph after that, then it's running as well as a brand new example!
A decent pipe and set up will add about 5-6mph on the flat and downhill, but it's not going to make it a genuine 65mph+ bike.
Mine had nearly 12bhp, and would sit at 115kmh/72ish mph, but in reality it was about 68mph. It also had terrible standing start acceleration, and broke a drive belt within 1500km, and seized once i had upped the compression ratio.
I got it running reliably eventually, but it had pissed me off so much by this time and cost me £££'s, that i was very happy to see it go!
TUG
PostPosted: 22:13 - 20 Oct 2009    Post subject: Reply with quote
How much MPG should i be getting? i did like a 40-50mile run today and i'm on half a tank already!? Laughing
Haz ER-5, innit!
PostPosted: 23:39 - 20 Oct 2009    Post subject: Reply with quote
Is it actually half a tank or half a tank on the fuel gauge?
It does sound a little high but it depends how you ride it.
TUG
PostPosted: 23:40 - 20 Oct 2009    Post subject: Reply with quote
fuel gauge, am convinced thers something wrong.
Haz ER-5, innit!
PostPosted: 23:54 - 20 Oct 2009    Post subject: Reply with quote
Do a proper test. Note down your mileage when you next brim the tank, ride, then brim the tank again and note the mileage and the amount of litres you put in the bike.
TUG
PostPosted: 21:37 - 21 Oct 2009    Post subject: Reply with quote
Will note the milage next time, but its a bog standard 6 litre scooter tank.
Haz ER-5, innit!
PostPosted: 22:02 - 21 Oct 2009    Post subject: Reply with quote
40-50 miles to 3 litres = 60-75mpg. That sounds right.
TUG
PostPosted: 22:05 - 21 Oct 2009    Post subject: Reply with quote
Lol i want my CG back, 200miles to a full tank! damit!
Haz ER-5, innit!
The last post was made 16 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.22 Sec - Server Load: 2.64 - MySQL Queries: 13 - Page Size: 99.87 Kb
