shitting stupid vista to xp
Bike Chat Forums Index -> The Geek Zone Goto page 1, 2  Next
The Artist
PostPosted: 20:06 - 18 Oct 2009    Post subject: shitting stupid vista to xp Reply with quote
Mate has vista home (yes I know, bag of shite) it's awful, slow and his computer is actually ok specs wise.
I suggested either go to xp or windows 7 which is brilliant btw.
I have corp xp disc but you can't just downgrade with vista because it is so shit.
Now, if I bung a new HD in, can I put xp on that? Will there be any remminents of vista left in the chipset or something that makes it not work?
Cheers Karma
bazza
PostPosted: 20:26 - 18 Oct 2009    Post subject: Reply with quote
https://apcmag.com/how_to_dual_boot_vista_and_xp_with_vista_installed_first__the_stepbystep_guide.htm
CaNsA
PostPosted: 22:18 - 18 Oct 2009    Post subject: Re: shitting stupid vista to xp Reply with quote
https://motivateurself.files.wordpress.com/2009/02/implied-facepalm.jpg
Get double driver first though. it copies all the drivers you have currently install. good app.
Hetzer
PostPosted: 22:50 - 18 Oct 2009    Post subject: Re: shitting stupid vista to xp Reply with quote
Cheers Karma
Why would you need a new HD? Wipe Vista off the current one, quick-format it and install XP on it.
CaNsA
PostPosted: 22:54 - 18 Oct 2009    Post subject: Reply with quote
I have that horrible feeling that allymoss is "practising" doing IT Repair on his mates computer......
surely this cant end well.
The Artist
PostPosted: 23:29 - 18 Oct 2009    Post subject: Reply with quote
How would I format the drive with vista still on there?
map
Mr Calendar
PostPosted: 10:06 - 19 Oct 2009    Post subject: Reply with quote
Old school, boot from another device (floppy, usb drive, usb floppy, boot cd/dvd, BartPE disk, etc.) with the necessary command interface on it Rolling Eyes
Maybe it's just me but I have a feeling that if you didn't know that you should put down the keyboard and walk away now.
Hetzer
PostPosted: 10:50 - 19 Oct 2009    Post subject: Reply with quote
You boot the system off an XP CD and use the 'delete partition' command that comes up on one of the install-windows (it's an idiot-proof wizard effectively, follows up with a 'quick-format' window). You may need to go into the BIOS first (hammer the Delete key as the system is firing up, or look for whatever key it requires during start-up, sometimes it's not the Delete key). In the BIOS you need to set the CD-drive as the first boot-up drive.
t121anf
PostPosted: 12:04 - 19 Oct 2009    Post subject: Reply with quote
don't even need to select quick format, delete the partition as said then click install on the unpartitioned space and hey presto it'll format it for you.
Hetzer
PostPosted: 12:41 - 19 Oct 2009    Post subject: Reply with quote
Quickly or slowly?
t121anf
PostPosted: 15:50 - 19 Oct 2009    Post subject: Reply with quote
does a quick format iirc.
The Artist
I have installed xp many times but the problem being is the hardware is not xp compatible e.g. later version of sata than xp will come with on the disc so I need to somehow get hold of the mobo sata drivers and slip them into the xp disc.
map
Mr Calendar
PostPosted: 16:01 - 19 Oct 2009    Post subject: Reply with quote
allymoss wrote:
...the hardware is not xp compatible...so I need to somehow get hold of the mobo sata drivers and slip them into the xp disc.
Do a google and look into building your own BartPE boot CD disk with the extra necessary drivers.
Add these from the boot CD you built when it asks you in the XP install process.
IIRC try looking for pebuilder. Last time I looked and had to do this there was a pebuilder3110a.zip file to download (should have been updated a zillion times since then).
That had all the necessary info for you to create the boot disk.
You will need an original XP disk though for the creation bit.
Trust me, if I can work it out it's not that hard Very Happy
<edit>
Just looked and pebuilder is here
Same version # as I downloaded a year ago, so not changed that much.
Obviously you'll have to google for the sata drivers you need.
I'd try the computer or motherboard maker's site(s) first.
</edit>
panrider_uk
PostPosted: 21:44 - 19 Oct 2009    Post subject: Reply with quote
It gives the option of quick format or normal format.
Mark
panrider_uk
PostPosted: 21:51 - 19 Oct 2009    Post subject: Reply with quote
Put them on a floppy and press F6 when XP asks if you have any other drivers to install (at beginning of the install).
Mark
Hetzer
PostPosted: 21:55 - 19 Oct 2009    Post subject: Reply with quote
Mark
What's a floppy? I did see a PC once, a few years ago, that had a space on the front panel that said "Floppy? Fvck off back to the Ark."
Put the drivers on a USB stick and pray the system recognizes it when you need it to.
The Artist
PostPosted: 22:09 - 19 Oct 2009    Post subject: Reply with quote
Found a program called nLite which means I can edit the xp disc before I use it and integrate the drivers I need onto it.
https://www.nliteos.com/
What do you guys reckon?
panrider_uk
PostPosted: 22:10 - 19 Oct 2009    Post subject: Reply with quote
Hetzer wrote:
Mark
Floppy drive is a small flat device that you plug into a USB slot.
Good luck getting XP install to read a USB stick.
Mark
CaNsA
PostPosted: 22:15 - 19 Oct 2009    Post subject: Reply with quote
allymoss you are a dick.
Did i not say one of my previous posts to use Double Driver?
It will copy all the drivers that the system is using for the hardware you are running.
tit
Hetzer
PostPosted: 22:31 - 19 Oct 2009    Post subject: Reply with quote
Mark
Yeah, that's why I said pray.
You'd also want to be praying for somebody to kick some sense up your arse if you went out and spent money on a USB-floppy just to install a driver. The same USB that a USB-stick uses that won't be recognized by the XP install. Laughing
panrider_uk
PostPosted: 22:33 - 19 Oct 2009    Post subject: Reply with quote
XP recognises a USB floppy no problem.
Doesn't everyone have 1 or 2 of them kicking around? Smile
Mark
Hetzer
PostPosted: 22:37 - 19 Oct 2009    Post subject: Reply with quote
Mark
I've got one that came with a laptop, but I've never used it. Do they still sell floppies then?
CaNsA
PostPosted: 22:41 - 19 Oct 2009    Post subject: Reply with quote
Now now ladies.
https://img9.imageshack.us/img9/2826/handbag1.jpg
Laughing Wink
panrider_uk
PostPosted: 23:04 - 19 Oct 2009    Post subject: Reply with quote
Mark
They do. Probably for folk who need to install XP onto SATA drives Smile
Actually I still use them for installing Win2003 onto servers with SCSI discs.
Mark
CaNsA
PostPosted: 23:16 - 19 Oct 2009    Post subject: Reply with quote
Well done mark for being the grown up. Have a gold star
https://clipart.peirceinternet.com/png/bullets/gold-star.png
The last post was made 16 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 130.41 Kb
