dipped headlights on zx6r?
scream aim fire
PostPosted: 16:48 - 19 Oct 2009    Post subject: dipped headlights on zx6r? Reply with quote
hi all, got a problem on the zx6r (a1p), it seems i have no dipped headlight and am currently blinding every mofo on the road
im sure before the light on the right would come on when i put the light switch to the middle setting now it dosn't come on unless i put it on high beam, i thought it might be a bulb for both dipped and high beams so i bought a new bulb but still getting the same problem,
when i put the switch to the middle only the pointless little light in the middle comes on
can anyone help?
sorry if that sounds like a load of jibberish lol
CBT PASSED 18/01/09 THEORY PASSED 14/04/09 DAS PASSED 17/04/09 3 minors wet test.
Bikes: 2009 Aprilia RS125 (PX'D) - A1P ZX6R - Stolen -Triumph Daytona 600 -wrote off via BMW
Current bike: P7F ZX6R
DaveH
PostPosted: 17:09 - 19 Oct 2009    Post subject: Reply with quote
If both bulbs are out, on dip, then sounds like the relay is knackered; there is one relay for dip and another one for full.
Hmm, the switch to the middle will only put the position light on; fully left, the switch will either put DIP on, or FULL beam , depending on the position of the switch on the left switch cluster.
https://www.timhastingsracing.co.uk/
ZX7R & ER6F
scream aim fire
PostPosted: 17:14 - 19 Oct 2009    Post subject: Reply with quote
is the relay relativily hard to replace?
got to get it mot'd this week Neutral
DaveH
PostPosted: 17:34 - 19 Oct 2009    Post subject: Reply with quote
Can't think where it's located, could be on the back of the bracket that holds the clocks Confused
Not sure, mine never had any of that so just used std relays from halfords
ZX7R & ER6F
scream aim fire
PostPosted: 17:47 - 19 Oct 2009    Post subject: Reply with quote
will have to take the bike apart tomorrow, cheers for your help.
scream aim fire
PostPosted: 16:50 - 20 Oct 2009    Post subject: Reply with quote
hmm i dont think its the relay as i took them both off and switched them over and the full beams still work but the dipped don't,
checked all the fuses and none of them were broken
now im completly lost Sad
DaveH
PostPosted: 04:34 - 21 Oct 2009    Post subject: Reply with quote
Only two things it can be now;
1) There is a break in the wiring from the switch circtuit to the relay
2) There is a break in the wiring from the light circuit side of the relay
Do you have access to a multimeter so that you can measure voltages or resistance?
One quick test would be to take the two connectors off the relay that go to the light and short them together; if the lights come on, then the problem lies with the switching circuit, if they don't come on, then there is a problem with the lighting side.
ZX7R & ER6F
scream aim fire
PostPosted: 15:08 - 22 Oct 2009    Post subject: Reply with quote
damn, i have a feeling this is going to cost a fair bit to sort out Sad
DaveH
PostPosted: 15:12 - 22 Oct 2009    Post subject: Reply with quote
Hopefully not Karma
A bit of time and patience/perseverance will hopefully see it identified.
A (cheap) multimeter will make it considerably easier though Thumbs Up
ZX7R & ER6F
scream aim fire
PostPosted: 17:41 - 22 Oct 2009    Post subject: Reply with quote
took it to the shop i bought it from today, said to bring it to his mechanic tomorrow and he'll have a look at it for me (have 2 days warranty left on the bike Mr. Green
cheers for you help!
The last post was made 16 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 66.98 Kb
