Is your bike touchy in 1st gear?
Feasty
PostPosted: 13:43 - 22 Oct 2009    Post subject: Is your bike touchy in 1st gear? Reply with quote
If I ride along at a slow speed in 1st with about half rev's, my bike is very jerky pulling forwards then pulling back, pulling forwards then pulling back etc. Even though I'm holding the accelerator steady and trying to ride smoothly.
In higher gears I can keep the bike going at a constant speed without this happening but if I alter the speed just a little, faster or slower then the bike jumps forwards or pulls sharply back again... bit like a wild stallion!! Laughing
Is there anything I can do about this to make the accelerator smoother and less jumpy?
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
Acemastr
PostPosted: 13:49 - 22 Oct 2009    Post subject: Reply with quote
I had this, turned out to be a chain with a tight spot, replaced the chain and it's smooth now, any movement on the throttle sin't particularly smooth but that's just crappy fuelling.
2016 Toyota Tacoma Limited
JAMSXR
PostPosted: 13:53 - 22 Oct 2009    Post subject: Reply with quote
Only use 1st to pull off?
Feasty
PostPosted: 14:02 - 22 Oct 2009    Post subject: Reply with quote
Not sure where you're coming from with that, I always use 1st to pull off anyway. It's at constant speed this happens not on pulling off... Confused
Alexio
PostPosted: 14:08 - 22 Oct 2009    Post subject: Reply with quote
Only very, very occasionally do I stay in 1st when in 3MPH traffic that really is moving at a constant rate that slowly. Know what you mean though, had that a bit with my chinese 125 in 3rd gear occasionally Shocked (Do not buy chinese bikes - just say no)
Skudd
Can be the chain, carbs/fuel injectors, but also can be your clutch control.
Alexio
PostPosted: 14:10 - 22 Oct 2009    Post subject: Reply with quote
Clutch control?! He's talking about when the gear is fully engaged.
Edit: Ah, that does bring to mind that you should check your clutch cable and linkage. Make sure that your clutch really is fully disengaged.
Feasty
PostPosted: 14:16 - 22 Oct 2009    Post subject: Reply with quote
Spot on. Thumbs Up
There is a little play in the clutch lever when the gear is fully engaged which I'd imagine means the clutch is full disengaged? I'll double check the linkage though, thanks.
Skudd
PostPosted: 14:24 - 22 Oct 2009    Post subject: Re: Is your bike touchy in 1st gear? Reply with quote
Perhaps slip the clutch slightly at the point that you know it will be lumpy?
JAMSXR
PostPosted: 14:28 - 22 Oct 2009    Post subject: Reply with quote
Well on all my previous bikes I have only ever used 1st gear for pulling off apart from the odd occasion. On my RSV 1st gear is very high so I do have to use it quite allot and unless I feather the clutch it's very jerky.
Feasty
PostPosted: 14:55 - 22 Oct 2009    Post subject: Reply with quote
Thing is I know ways round it, partial clutch, different gears etc, etc. I was just wondering if all/other bikes did this or wether it's specific to my bike and also perhaps if it being a single cylinder thumper would make any difference? i.e. low down power...
I can cope with it easily enough but am just a bit concerned it might be trying to tell me that something's wrong. Like Acemastr said about a tight spot in the chain or Alexio about the clutch linkage etc.
wizzzard
PostPosted: 15:04 - 22 Oct 2009    Post subject: Re: Is your bike touchy in 1st gear? Reply with quote
https://i656.photobucket.com/albums/uu281/wizzzard2009/WyldStallyns.jpg
JAMSXR
PostPosted: 15:04 - 22 Oct 2009    Post subject: Reply with quote
I would say it's the bike, my KTM Duke was very similar to how you describe in first, a bit like a bucking bronco!
Alexio
PostPosted: 15:06 - 22 Oct 2009    Post subject: Reply with quote
If it helps, just before I replaced my last chain on my CG (had an epic amount of miles on it) it was stretched in a ton of places and ready to fall off (once or twice it actually skipped off of the back sprocket, much like on a mountain bike).
However, it didn't do what you are describing in first gear. Maybe it was a better chain though Razz
Whosthedaddy
PostPosted: 15:24 - 22 Oct 2009    Post subject: Reply with quote
Its one of the TRX's little gems in my eyes. 1st gear is quite long, not snatchy like you've mentioned and even when tapped down into during slow moving traffic it remains smooth and confidence inspiring. I feel confident in taking it through the revs and not worried that the front will lift unlike when on an IL4.
Ive managed to knock it into 1st and go round roundabouts thinking I'm in 2nd and not patted an eyelid. Damn you 5 speed box, still not learnt to count.
PostPosted: 15:56 - 22 Oct 2009    Post subject: Reply with quote
At 5,000rpm there is a flat spot on my bike where the engine starts 4 stroking, it's impossible to ride in 1st gear past it.
I've not got around to fixing it yet but it's likely to be the powervalves not being synchronised and one is moving slightly before the other.
Alexio
PostPosted: 17:06 - 22 Oct 2009    Post subject: Reply with quote
BLUEX5 wrote:
It's a big single trait, you could possibly tone it down by fannying around with the gearing but you'll never stop it.
Hmm, that makes sense actually, hadn't thought about it much before but single 4 strokes do seem to be uncomfortable staying at an exact amount of revs in some situations... which makes sense because of being a 4 stroke... power delivery every fourth time.
So - your solution is to either weld on another cylinder or convert your engine into a 2 stroke Laughing Laughing
Whosthedaddy
PostPosted: 17:13 - 22 Oct 2009    Post subject: Reply with quote
Even the little single on the monkey is really snatchy in 1st.
rac3r
PostPosted: 18:30 - 22 Oct 2009    Post subject: Reply with quote
Yep my Monster is the same until you get past 3k revs Thumbs Up
Chequered Flag
Bikeless
PostPosted: 18:31 - 22 Oct 2009    Post subject: Reply with quote
sounds like it is hunting which you get with a lean mixture, maybe a blockage in a fuel filter or carburettor.
Feasty
PostPosted: 08:09 - 23 Oct 2009    Post subject: Reply with quote
Well thanks guys, it does make sense to be related to having a single 4 stroke. I'm not sure I'd love it quite as much if I'd ridden a smoother bike first though, but with this being my first bike I really like the extra grunt I get at low rev's.
fireblade2102, if it's 'hunting' as you mention would it be more likely to do this at other times too, i.e. idling?
The last post was made 16 years, 321 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 118.43 Kb
