| map |
 map Mr Calendar
 Posted: 12:26 - 20 Oct 2009 Post subject: Electrical work needed - what's a good price? |
Need to get an old fuse box replaced.
I always seem to feel I get ripped off by contractors in these things.
I wondered what was a ballpark price for this work?
That is removal, supply of replacement and fitting.
I was thinking it may be cheaper to source the stuff myself and pay for removal and fitting, but it's an area I'm not that familiar with.
Any other advice appreciated.
Thanks in anticipation  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| jayrhammond |
 jayrhammond Two Stroke Sniffer
| map |
 map Mr Calendar
 Posted: 12:38 - 20 Oct 2009 Post subject: |
Thanks.
Need the thing replaced because of the big 30amp fuse.
It's being used for the shower and has blown.
I suspect it's been overheating for ages as the holder just crumbles and the socket is black.
I also suspect that the fuse value is too low for the shower. I guess that fitter didn't check, which is why I'm wary*
* yes I know shouldn't treat everyone the same after one bad experience but it does, as I said, make me cautious, which isn't a bad thing. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 12:50 - 20 Oct 2009 Post subject: |
Sure you need the whole fuse box replaced? When my old shower burnt out, I just had a separate, higher amperage feed put in, with it's own RCD. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| map |
 map Mr Calendar
| The Shaggy D.A. |
 Posted: 13:28 - 20 Oct 2009 Post subject: |
Yes, bit of a bugger to price just that part as when the shower died we decided it was time for a new bathroom, so it was done as part of the whole job. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| WildGoose |
 WildGoose White Van Man
 Posted: 19:01 - 20 Oct 2009 Post subject: |
I had a fuse box replaced while I ripped my kitchen out, it cost me £675 parts + labour. Basically 1 days work, although he ran over into the following day, because he turned up late and had to make a trip out for parts (typical tradesman ).
Can see the old box here, in a crappy position near under the taps.
https://www.bikechatforums.com/files/newplaster.jpg
Had to install a waterproof junction box there to bring it up to code, then chase it up to a new position on the wall, hidden in a cupboard, a far more convenient location, also uses the new MCB breakers rather than the old pull out fuse type circuit breakers.
He also chased out the wall and installed two new sockets for the kithen on a separate circuit and did a bit of earth bonding, boiler/pipes etc. So a straight fusebox change will be a bit cheaper and quicker, but most of the cost is the labour time.
New stuff.,..
https://www.bikechatforums.com/files/newelectrics.jpg ____________________ So in other words, he stopped you for being flagrantly in posession of a motorcycle in direct contravention of the Hippies, Darkies and People Whose Face I Don't Like The Look of (Police Powers) Act. 1976 |
| panrider_uk |
 panrider_uk World Chat Champion
| firefox |
 firefox World Chat Champion
| Sparks! |
 Sparks! Sir Tart-a-lot
 Posted: 18:11 - 22 Oct 2009 Post subject: |
Last private fuseboard I done was £350 cash for supply, fit + certificate.
Not sure what my company would charge at the min, but gives you an idea.
p.s as far as private work goes.. I'm not cheap! but you get what ya pay for and I've had no complaints  ____________________ Current Toys: 06 Yamaha WR250F | Nissan 350Z GT | Tech 4 Homes |
| Sparks! |
| panrider_uk |
| map |
 map Mr Calendar
 Posted: 11:25 - 23 Oct 2009 Post subject: |
Thanks for the replies.
I've been offline for a few days with a dodgy wireless hub.
Applying the necessary ointment and appears to be clearing up
It's not causing much hassle at the moment as bathroom needs re-grouting anyway and the missus' prefers a bath.
In the process of 'phoning around for quotes.
I love dealing with tradesmen, it's like some of them don't actually want the work and to take money off me
When I get some figures and/or have the work done I'll post so you can share my horror or relief.
| Robby |
 Robby Dirty Old Man
 Posted: 15:40 - 23 Oct 2009 Post subject: |
When I was getting assorted bits of work done I used www.mybuilder.com
Means I don't have to spend ages talking to tradesmen on the phone. It has a feedback system too. |
| MarJay |
 MarJay But it's British!
| amnesia |
 amnesia Spanner Monkey
 Posted: 21:17 - 25 Oct 2009 Post subject: |
Bit of a derail...sorry but...
A professional did that? - I thought that at the very least 'good practice' says the cables should be vertical from sockets etc. so people in the future 'know' where any cables are and can safely hit nails into walls without worrying about getting a new hair-do. ____________________ 25/7 I'm a God-damn Rock Star
"Arguing about the best 125 is like arguing which Spice Girl could sing best" |
| WildGoose |
| Speedy3 |
 Speedy3 Traffic Copper
 Posted: 09:23 - 27 Oct 2009 Post subject: |
Try www.MyHammer.co.uk
People bid for the job, and you can see how they've been rated for what work they've done before and also any qualifications they have, have been verified. You should get a few people bidding and a very competitive quote  ____________________ Current bike: 2005 Triumph Speed Triple 1050 :: Previous Bikes: 2001 Kawasaki ZZR-600 E9 (Sold) 1996 Yamaha Diversion 600s (Sold),1997 Honda CB250 Nighthawk (Sold), 1988 Honda VFR 400 NC24 (Written Off), 1987 Honda CB350 S-G (Sold), Yamaha DT125 (Sold), Honda X8R-S 50cc (Stolen) |
| steven_191 |
 steven_191 Nearly there...
 Posted: 17:15 - 28 Oct 2009 Post subject: |
im an electrician.
id say the current price is around £400. plus or minus depending on how much work there is. although if its a private job in someones spare time it'll be cheaper. remember though that contractors should also be giving you install certificates and maybe test certificates if your having that done too (normally about £150ish for a 3bed house)
you could buy the parts for less than £100, thats a split load board so you have RCD protection for your sockets, and all of the MCBs and main breaker and RCD. you normally would get a selection that suites pretty much any house but extra MCBs for maybe £10 each.
if you go for something like Wylex, Crabtree, they are fairly good quality and fairly cheap. if you go for MEM or MK you could easily pay double although they are much better quality. not that it'll matter to you as you probably wont use them.
check out this bad boy
https://www.screwfix.com/prods/80908/Electrical-Supplies/Consumer-Units/Wylex-Consumer-Units/WYLEX-10-Way-Fully-Insulated-Dual-RCD-Consumer-Unit?ts=49615
i fitted this at our old house and its was more than enough and cheap. |
| Cigaro |
 Cigaro World Chat Champion
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 10:54 - 24 Nov 2009 Post subject: |
| TheBassJunky wrote: | Isn't it legal to do the work yourself as long as you have it checked by a professional?
Might not be, I'm just wondering. |
yep perfectly legal,
infact you dont even need to get it checked,
the householder can do all his own wiring,
which is kind of fucked up, but, as long as you have an idea, and you are prepared to face the consequences if you fuck it up, then sweet by me,
when i was in scotland, i used to do fusebox replacements
everything included for 250quid cash
good deal for the client and i'd make almost 200 quid,
and it would only take me an hour or so,
go on gumtree and see if anyone is advertising ____________________ the humans are dead
I kick arse for the lord
| tutton |
 tutton World Chat Champion
| unitybiker |
 unitybiker Nova Slayer
| panrider_uk |
| Sparks! |
The last post was made 16 years, 264 days ago. Instead of replying here, would creating a new thread be more useful? |
