YAMAHA XJ600 DIVERSION OIL CONSUMPTION
surfbum65
PostPosted: 18:36 - 24 Oct 2009    Post subject: YAMAHA XJ600 DIVERSION OIL CONSUMPTION Reply with quote
Hi, I've just bought a '94 Yamaha XJ600 DIVERSION today with 10,500 genuine miles.
When I picked the bike up the oil level was full. I rode the 212 miles from Newcastle to Birmingham mostly on fast roads & motorways.
Noticed when I got home the level was now 1/4 full.
It didn't smoke and there are no apparent leaks. The exhausts are dry inside (no oil residue).
Is this normal or is there something going on?
I'd hate to think I've bought a lemmon Sad
Thanks
Pete
PostPosted: 19:13 - 24 Oct 2009    Post subject: Reply with quote
Firstly if it doesn't smoke, doesn't rattle, runs well and ticks over I wouldn't worry. If there are any leaks I'd expect to find them in the area of the front sprocket, but if it was bad you'd have a drip or a small puddle.
First thing I'd do is stand the bike level on the drive or in the garage and check the oil then top it up to the max. Then I'd ride it for a couple of hundred miles and check it again when stood on exactly the same spot. You can get a large difference in the level of oil in the sight glass of a bike just by leaning it ever so slightly, or by not having it on level ground front to rear. This might be the case with your bike. Don't worry, they are a tough engine.
surfbum65
PostPosted: 20:45 - 24 Oct 2009    Post subject: Reply with quote
Hi Geri,
Thanks very much for your reply. The first place I checked the oil was in the motorway services after I'd done about 100 miles. It was on the max. I then checked it in my garage after the next 100 miles. This is when I had seen the difference.
I'll do what you suggest & hopefully it will be ok.
Thanks again for your help
Pete
alun111
PostPosted: 06:40 - 25 Oct 2009    Post subject: Reply with quote
You should be checking the oil when the engine is stone cold. Best leaving it overnight to get an accurate reading.
iooi
PostPosted: 09:23 - 25 Oct 2009    Post subject: Reply with quote
You sure that you were on level ground all the time, as it only takes a slight slope to make it look high/low.
Personally its one of the 1st things i do when i get a bike. Change the oil and filter.
Try removing the tank as well and looking in the air filter. They can dump oil in there.
I have a 97 with 43 K on the clock and it does not use any oil at all.
surfbum65
PostPosted: 13:56 - 25 Oct 2009    Post subject: Reply with quote
Thanks to everyone for your help. I can't say that the ground was level at the services or when I first set off from Newcastle train station where I met the seller.
I've topped it up in my garage and will check again periodically when it's parked on the same spot and hopefully all will be well. I'll also check the oil filter as you suggest.
Thanks again for everyones advice. I' keep you up to date.
el_oso
PostPosted: 15:12 - 25 Oct 2009    Post subject: Reply with quote
i have to top my divvy up with oil every few hundred miles. Has been running perfectly for the past 10months.
Problem with so few miles on such an old bike is that water and dust/grime/grit/crap tends to settle and corrode stuff and cause problems.
the reason why mine is using so much oil is because the rubber valve seals are gone brittle and are leaking. This is only a problem when i first start the engine. A fair amount of blue smoke. After about 10seconds the smoke has disappeared with no other problems. just keep it topped up with oil.
Also the oil light on the divvy is very sensitive. when that light comes on. check your oil level and top it up
Duke 390
Car: Jeep Wrangler 4.0L
surfbum65
PostPosted: 21:34 - 25 Oct 2009    Post subject: Reply with quote
I can deffinetely vouch for the light being sensitive. It was on this morning. When I braked the oil light went out and when I settled into a steady speed it came back on for a bit then went out. I've topped up the oil so I'll keep an eye on it.
Did discover that when I put my bike in different sides/areas of the garage the oil level changed Shocked .
Floor not as level as it looks. I've marked out a spot where the centre stand sits now so I'll park the bike in that exact spot and keep an eye on level.
Haven't noticed it smoking but I'll be more vigilant.
Thanks Very Happy
Previous bikes: CZ 125, Zip 50 scooter, Peugeot 125 scooter, Marauder 125, Virago XV 535, Kawasaki Drifter, Bonneville America, VN750, Harley 883 Sportster. Now own both a Customised Harley Superglide and XJ 600 Diversion
surfbum65
PostPosted: 02:11 - 08 Nov 2009    Post subject: Oil level problem solved Reply with quote
After 2 weeks of parking my bike in the exact same spot in the garage (i marked it out with tape) the oil has stayed the same level Thumbs Up
Turns out my garage floor is a bit uneven in places. Move it a couple of feet either way & you get different readings.
Thanks again to everyone for the advice.
P.s. Is the gearbox always noisy when it's in neutral? Sure I read somewhere this was normal Confused
serlant
PostPosted: 04:41 - 08 Nov 2009    Post subject: Reply with quote
yup, grab the clutch and it should quieten down a bit.
surfbum65
PostPosted: 08:32 - 08 Nov 2009    Post subject: Reply with quote
Yep, exactly as you say. Pull in the clutch & noise stops otherwise gearbox/clutch work fine aside from being a bit clunky on gear change which I understand is also normal. Thanks Very Happy
PostPosted: 10:48 - 08 Nov 2009    Post subject: Reply with quote
Yes normal as said.
Be aware also that the noises your bike engine makes will be greatly amplified when it's in your garage or alleyway or alongside a solid wall such as the side of a house. The thing to worry aboiut is sudden significant changes in the noise or feel of your bike. Give the oil level a quick check one in a while and do the scheduled servicing. Pay more attention to keeping your chain lubed religiously especially in the coming months.
Thom
PostPosted: 10:54 - 08 Nov 2009    Post subject: Reply with quote
i found my diversion would only give a true oil level when it was cold in the morning. if it had even been run for a second the oil seemed to dissapear up into the engine and wouldnt return for a good 20mins+!
surfbum65
PostPosted: 19:26 - 08 Nov 2009    Post subject: Reply with quote
Thanks all for the help and advice. With the heated grips I fitted and with regular maintanance I'm all set for the winter Thumbs Up Very Happy
klk650
PostPosted: 16:21 - 25 Jan 2010    Post subject: Reply with quote
Hello
After passing my test in November, I am now th prud owner of a 600 diversion 1997, but have found that the oil light comes on sometimes ? I read the read ups on here, but I know if it came on on my car I would STOP and panic, is this the same with my bike ?
Thanks in advance for all advice.
Karen
surfbum65
PostPosted: 16:34 - 25 Jan 2010    Post subject: Reply with quote
klk650 wrote:
Hello
Karen
Hi Karen,
Congrat's on passing your test. Great feeling isn't it? My bike license means more to me than my car license.
To your question. Mine was the same. Top it up with oil and the problem will go away. The light is the oil level indicator, not oil pressure and is very sensitive. A little under the max' level and the light will come on especially when braking, accelarating and turning.
I found that when I parked my bike in different parts of the garage the readings would keep changing (uneven floor tho' visually it looks level). It only takes a 1/4 " either way on the centre stand to change the oil level reading.
Happy biking and keep the rubber side down and the shiny side up Cool
Pete
smegballs
PostPosted: 17:55 - 25 Jan 2010    Post subject: Reply with quote
My ZZR is the same. When its cold the oil level is just under max in the sightglass. Once its running there is no oil to be seen in there at all!
klk650
PostPosted: 18:25 - 25 Jan 2010    Post subject: Reply with quote
I agree, it took me two attempts at the new mod1 test, and three attempts at part 2, and I was more chuffed to do this than to do a car test.
I have read about the diversion being touchy on the oil light on another forum, but I am glad you have reinforced that view, as an oil light usually means big trouble and no oil circulation.
I found the jump from the 600 from my little 125 custom to be quite intimidating, but as my hubby says, you'll soon be zooming around.
Thanks for you help, and piece of mind
Karen Laughing Shocked Very Happy Mr. Green Thumbs Up
surfbum65 wrote:
klk650 wrote:
Hello
Karen
Hi Karen,
Pete
The last post was made 16 years, 227 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 14 - Page Size: 103.4 Kb
