| surfbum65 |
 surfbum65 Derestricted Danger
 Posted: 17:36 - 24 Oct 2009 Post subject: YAMAHA XJ600 DIVERSION OIL CONSUMPTION |
Hi, I've just bought a '94 Yamaha XJ600 DIVERSION today with 10,500 genuine miles.
When I picked the bike up the oil level was full. I rode the 212 miles from Newcastle to Birmingham mostly on fast roads & motorways.
Noticed when I got home the level was now 1/4 full.
It didn't smoke and there are no apparent leaks. The exhausts are dry inside (no oil residue).
Is this normal or is there something going on?
I'd hate to think I've bought a lemmon
Thanks
Pete |
| Pete. |
 Pete. Super Spammer
 Posted: 18:13 - 24 Oct 2009 Post subject: |
Firstly if it doesn't smoke, doesn't rattle, runs well and ticks over I wouldn't worry. If there are any leaks I'd expect to find them in the area of the front sprocket, but if it was bad you'd have a drip or a small puddle.
First thing I'd do is stand the bike level on the drive or in the garage and check the oil then top it up to the max. Then I'd ride it for a couple of hundred miles and check it again when stood on exactly the same spot. You can get a large difference in the level of oil in the sight glass of a bike just by leaning it ever so slightly, or by not having it on level ground front to rear. This might be the case with your bike. Don't worry, they are a tough engine. ____________________ a.k.a 'Geri'
| surfbum65 |
| alun111 |
 alun111 World Chat Champion
| iooi |
 iooi Super Spammer
 Posted: 08:23 - 25 Oct 2009 Post subject: |
You sure that you were on level ground all the time, as it only takes a slight slope to make it look high/low.
Personally its one of the 1st things i do when i get a bike. Change the oil and filter.
Try removing the tank as well and looking in the air filter. They can dump oil in there.
I have a 97 with 43 K on the clock and it does not use any oil at all. ____________________ Just because my bike was A DIVVY, does not mean i am...... |
| surfbum65 |
| el_oso |
 el_oso World Chat Champion
| surfbum65 |
 Posted: 20:34 - 25 Oct 2009 Post subject: |
I can deffinetely vouch for the light being sensitive. It was on this morning. When I braked the oil light went out and when I settled into a steady speed it came back on for a bit then went out. I've topped up the oil so I'll keep an eye on it.
Did discover that when I put my bike in different sides/areas of the garage the oil level changed .
Floor not as level as it looks. I've marked out a spot where the centre stand sits now so I'll park the bike in that exact spot and keep an eye on level.
Haven't noticed it smoking but I'll be more vigilant.
Thanks  ____________________ Previous bikes: CZ 125, Zip 50 scooter, Peugeot 125 scooter, Marauder 125, Virago XV 535, Kawasaki Drifter, Bonneville America, VN750, Harley 883 Sportster. Now own both a Customised Harley Superglide and XJ 600 Diversion |
| surfbum65 |
 Posted: 01:11 - 08 Nov 2009 Post subject: Oil level problem solved |
After 2 weeks of parking my bike in the exact same spot in the garage (i marked it out with tape) the oil has stayed the same level
Turns out my garage floor is a bit uneven in places. Move it a couple of feet either way & you get different readings.
Thanks again to everyone for the advice.
P.s. Is the gearbox always noisy when it's in neutral? Sure I read somewhere this was normal  ____________________ Previous bikes: CZ 125, Zip 50 scooter, Peugeot 125 scooter, Marauder 125, Virago XV 535, Kawasaki Drifter, Bonneville America, VN750, Harley 883 Sportster. Now own both a Customised Harley Superglide and XJ 600 Diversion |
| serlant |
 serlant Brolly Dolly
| surfbum65 |
 Posted: 07:32 - 08 Nov 2009 Post subject: |
Yep, exactly as you say. Pull in the clutch & noise stops otherwise gearbox/clutch work fine aside from being a bit clunky on gear change which I understand is also normal. Thanks  ____________________ Previous bikes: CZ 125, Zip 50 scooter, Peugeot 125 scooter, Marauder 125, Virago XV 535, Kawasaki Drifter, Bonneville America, VN750, Harley 883 Sportster. Now own both a Customised Harley Superglide and XJ 600 Diversion |
| Pete. |
 Pete. Super Spammer
 Posted: 09:48 - 08 Nov 2009 Post subject: |
Yes normal as said.
Be aware also that the noises your bike engine makes will be greatly amplified when it's in your garage or alleyway or alongside a solid wall such as the side of a house. The thing to worry aboiut is sudden significant changes in the noise or feel of your bike. Give the oil level a quick check one in a while and do the scheduled servicing. Pay more attention to keeping your chain lubed religiously especially in the coming months. ____________________ a.k.a 'Geri'
| Thom |
 Thom World Chat Champion
| surfbum65 |
 Posted: 18:26 - 08 Nov 2009 Post subject: |
Thanks all for the help and advice. With the heated grips I fitted and with regular maintanance I'm all set for the winter  ____________________ Previous bikes: CZ 125, Zip 50 scooter, Peugeot 125 scooter, Marauder 125, Virago XV 535, Kawasaki Drifter, Bonneville America, VN750, Harley 883 Sportster. Now own both a Customised Harley Superglide and XJ 600 Diversion |
| klk650 |
 klk650 L Plate Warrior
| surfbum65 |
 Posted: 15:34 - 25 Jan 2010 Post subject: |
| klk650 wrote: | Hello
After passing my test in November, I am now th prud owner of a 600 diversion 1997, but have found that the oil light comes on sometimes ? I read the read ups on here, but I know if it came on on my car I would STOP and panic, is this the same with my bike ?
Thanks in advance for all advice.
Karen |
Hi Karen,
Congrat's on passing your test. Great feeling isn't it? My bike license means more to me than my car license.
To your question. Mine was the same. Top it up with oil and the problem will go away. The light is the oil level indicator, not oil pressure and is very sensitive. A little under the max' level and the light will come on especially when braking, accelarating and turning.
I found that when I parked my bike in different parts of the garage the readings would keep changing (uneven floor tho' visually it looks level). It only takes a 1/4 " either way on the centre stand to change the oil level reading.
Happy biking and keep the rubber side down and the shiny side up
Pete ____________________ Previous bikes: CZ 125, Zip 50 scooter, Peugeot 125 scooter, Marauder 125, Virago XV 535, Kawasaki Drifter, Bonneville America, VN750, Harley 883 Sportster. Now own both a Customised Harley Superglide and XJ 600 Diversion |
| smegballs |
 smegballs World Chat Champion
| klk650 |
 Posted: 17:25 - 25 Jan 2010 Post subject: |
I agree, it took me two attempts at the new mod1 test, and three attempts at part 2, and I was more chuffed to do this than to do a car test.
I have read about the diversion being touchy on the oil light on another forum, but I am glad you have reinforced that view, as an oil light usually means big trouble and no oil circulation.
I found the jump from the 600 from my little 125 custom to be quite intimidating, but as my hubby says, you'll soon be zooming around.
Thanks for you help, and piece of mind
Karen
| surfbum65 wrote: | | klk650 wrote: | Hello
Karen |
Hi Karen,
Pete |
The last post was made 16 years, 28 days ago. Instead of replying here, would creating a new thread be more useful? |
