Storing the Hornet (Sort of)
TimNorwich
PostPosted: 16:18 - 27 Oct 2009    Post subject: Storing the Hornet (Sort of) Reply with quote
Ok so I have started to ride the Hornet less now that the winter is kicking in.
I don't want to store it away properly as I'd still like to use it on nicer days of winter.
At the moment it is fairly clean, under a cover in the back of my garden.
Would it be ok like this for the rest of the winter or would bits start seezing up and slowly rottting. There is a fairly good coverage of ACF-50 on it.
Does the cold weather only damage bikes when you are actively using the bike?
Thanks!
Tim.
imanupstart
PostPosted: 17:07 - 27 Oct 2009    Post subject: Reply with quote
Fuel cock off, oil change before storing it and it should be ok. Make sure you go out and start it, leaving it running for a while every week or so. Probably be a good idea to give it a good wash first. Never stored a bike over winter but these are the things I wish I would have done when I left my old 125 to rot in the garage! Laughing
kenny
PostPosted: 18:15 - 27 Oct 2009    Post subject: Reply with quote
If you can turn off the fuel do and try to run it with the fuel off till it dies as fuel goes off so quick these days and you'll find it hard to start when theres mankey fuel floating around in the engine, and as said give it a crank over every so often.
KeNNy 100cc peugot speedfight 125cc Honda NSR125R 650cc suzuki SV650R 125cc suzuki GZ125 600cc yamaha YZF-R6
Noxious89123
PostPosted: 20:24 - 27 Oct 2009    Post subject: Reply with quote
I just bunged some fuel stabiliser in a full tank of fuel, got the engine hot, let it cool off then covered it up.
I also pushed the pistons into the brake calipers, and moved the pads away from the discs, as they'll rust to the disc otherwise!
TimNorwich
PostPosted: 21:14 - 27 Oct 2009    Post subject: Reply with quote
Remember I plan/hope to ride it once a week.
Glory Hunter
PostPosted: 22:12 - 27 Oct 2009    Post subject: Reply with quote
I left my old cb500 outside under a cover for about 6 months (over a winter) as I couldn't afford to do the work to get it through the MOT.
When I went back to it I had to replace the battery but as soon as I'd done that it started first time.
I reckon if you're gonna ride it once a week, you don't really need to do a lot - just don't cover it if it's wet as it will trap in the moisture and cause corrosion.
2003 Suzuki VanVan - Sold
2000 Honda CB500 - written off by a spoilt brat with no manners Sad
2005 Yamaha XT660 - I'm in lurve.... Smile
njd27
PostPosted: 11:32 - 28 Oct 2009    Post subject: Reply with quote
That doesn't actually do the bike a lot of good - either take it for a decent run or don't start it at all.
Flipsta
PostPosted: 12:53 - 28 Oct 2009    Post subject: Reply with quote
Yeah, if you just leave it running by trying to keep it going you're just wasting the battery if you're using it in short bursts. Thats what happened with my speedfight. I started it once a month and it just killed the battery, had to replace it.
-Yamaha DT 125cc RE 2007 (right) >> Decal facelift
-Peugeot Jetforce 2009 50ccIce-Blade
-Peugeot Speedfight 2 100cc
Bendy
Mrs Sensible
PostPosted: 13:30 - 28 Oct 2009    Post subject: Reply with quote
Do nothing other than keep it under a cover and clean all the salty shite off it if you get salty shite all over it. It'll be absolutely fine.
imanupstart
PostPosted: 15:42 - 28 Oct 2009    Post subject: Reply with quote
News to me, I've always been told the opposite! Laughing
TimNorwich
PostPosted: 17:42 - 28 Oct 2009    Post subject: Reply with quote
Oh so what do I beleive now Laughing
Taking it out tonight, first time in 4days thats the longest i've left it since April!
My GPZ fell to shit last year, everything went wrong on it that could of. Just don't want another repeat. Hence the CG Very Happy
mr-inteligent
PostPosted: 17:49 - 28 Oct 2009    Post subject: Reply with quote
I have just checked my old bike today, after storing since September.
There was some rust on the chain, that soon came off and I had to lube / waxed it.
The front break disc was covered in rust! that also seems to come off after a good scrub but is there anything I can do prevent this?
njd27
PostPosted: 12:19 - 29 Oct 2009    Post subject: Reply with quote
The thinking is that
a) the bike takes much longer to get up to temperature when it's just idling, which increases wear
b) it takes an awfully long time to recharge the battery to replace the energy taken by starting the bike. Better to get a battery optimiser.
c) if the bike doesn't get properly up to temperature corrosive exhaust gases will tend to condense inside the exhaust system
TimNorwich
PostPosted: 16:41 - 29 Oct 2009    Post subject: Reply with quote
Doh! So what is the best thing to do then, warm/start it up or not?
PostPosted: 17:30 - 29 Oct 2009    Post subject: Reply with quote
Leave it. As soon as you apply the brake when you ride it again it will rub off.
Don't start it.
Alexio
PostPosted: 18:25 - 29 Oct 2009    Post subject: Reply with quote
Don't start it.
Well, if you do start it make sure you do some proper rides once the engine is warm Thumbs Up It's all or nothing baby.
The last post was made 16 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 92.5 Kb
