Can a bike be jump started of a car
lnewland
PostPosted: 13:35 - 31 Oct 2009    Post subject: Can a bike be jump started of a car Reply with quote
Hi all, I started the bike the other morning, which it did fine however i put it into gear prior to removing it from the side stand and it cut the engine. as a result of keep trying to start it i think i have flattened the battery. The bike is currently stuck at work and i was wondering if it is possible to jump it of a car without causing any damage to the bike. in the past i have used a power pack but i seem to have lost the charger.
Cg125 stolen and returned trashed
Cb500
Yamaha R6
Nb
PostPosted: 13:36 - 31 Oct 2009    Post subject: Reply with quote
Dont really see a problem with it.
Marci
PostPosted: 13:47 - 31 Oct 2009    Post subject: Reply with quote
S'always worked for me... just tell em not to step on the gas while it's hooked up to the bike...
That said, I've never had the car running when I've done it - always got whoever to kill the ignition - car batteries are usually plenty strong enough to get you going without needing the engine running.
FAB-Racing MiniMotoSidecars - Back with a vengeance - F1 Class 2011...
CBR170 engine, custom chassis - www.minimotoscene.co.uk
Finglonga
PostPosted: 13:56 - 31 Oct 2009    Post subject: Reply with quote
It will be fine, don't worry. Why not bump start it though much less hassle.
Andy Sez....
F.Y.Y.F.F.
smegballs
Yeah Ive heard that running the engine can cook your reg/rec as all of a sudden there is a massive power in your system and no load. So the reg/rec takes a massive loading an promptly expires.....
Ive used a car battery plenty of times before. We used to have a car battery on a little trolley for jump starts, power drill whatever. That always worked fine an started a bike within a second or two...
Just watch the polarity tho or you will cook your fuse....
lnewland
PostPosted: 13:59 - 31 Oct 2009    Post subject: Reply with quote
tried that and it just wouldnt go. thanks anyway
Cb500
Yamaha R6
PostPosted: 14:02 - 31 Oct 2009    Post subject: Reply with quote
Charging voltage is the same for bikes and cars, but there's no need to run the car because a fully charged car battery will crank a bike until the starter motor cooks itself before it goes flat.
smegballs
PostPosted: 14:06 - 31 Oct 2009    Post subject: Reply with quote
Thats a good point there!
Try not to use the starter motor for a long period, try to give it some time to cool between starting attempts.
Of course as long as the bike is behaving it should be ok if you have just ran down the battery.
PostPosted: 18:04 - 31 Oct 2009    Post subject: Reply with quote
Fine, but don't do it with the engine running.
If the cars voltage regulator is set to charge at a slightly higher voltage than the bikes one, your bikes reg/rec will try to dump the excess voltage from the car alternator to earth. The car will be putting out a lot more amps than your bikes reg/rec was designed to cope with and you could cook it.
EDIT: And don't attach the positive directly to the cars battery positive. On modern cars there is usually a seperate "tag" to attach jump leads to. Once the bike fires up, it'll try to charge the car battery too. On some cars (peugeots for definate), charging directly onto the battery positive can kill the ECU. It'll say in the manual where to attach jump leads.
Pussy Magnet This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Raffles
PostPosted: 19:47 - 31 Oct 2009    Post subject: Reply with quote
bikerdudematt wrote:
i always bump start bikes so much easyer and less effort needed .
If the bike you're trying to bump uses an alternator to produce power and the battery is completely flat then it'll take much more than a little effort to start it. You could push the bike from Land's End to John o' Groats (and back again if you weren't too knackered) and it still wouldn't start.
PostPosted: 19:51 - 31 Oct 2009    Post subject: Reply with quote
the car is 12v and most small bikes under 125's are run on 6v batterys
Very few bikes are 6V these days. Last common ones were some of the 100cc commuters such as the H100.
Trouble with bump starting modern stuff is if it is fuel injected then you are not going to get the pump to run and pressurise the system, even if the rest of the injection system gets enough power to run.
L-Jam
PostPosted: 00:33 - 04 Nov 2009    Post subject: Reply with quote
Bump starting; you look like a dick in the middle of town, but it gives you a great sense of satisfaction when the engine kicks in.
Journalist, student, egotist.
konsoli
PostPosted: 15:13 - 04 Nov 2009    Post subject: Reply with quote
my 70cc scooter was once jump started by a 2litre ford van. Laughing yer, they can be.
PostPosted: 16:16 - 04 Nov 2009    Post subject: Reply with quote
Depends on the bike - newer bikes generally won't at all in my experience (even pre FI), but not had a problem with most older designs.
el_oso
PostPosted: 18:15 - 04 Nov 2009    Post subject: Reply with quote
try bumping a bmw r1100. not always possible. took three guys pushing and one 6'6" guy on the bike downhill at least three attempts to jump it.
i've started a bike with a car battery no problems. little xr125. (was a bit wet and didn't fancy going out in the rain
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 18:35 - 04 Nov 2009    Post subject: Reply with quote
Pah, try eight for a firestorm and a lot lot more than three attempts! Ok, we were hung over.. and this was after trying to jump it from another bike and it failing.
CaPo
PostPosted: 09:45 - 05 Nov 2009    Post subject: Reply with quote
Ive had success in the past jumping my gpz off of fords. Tried it recently with a pug 306 though and it killed the starter solenoid Sad
Finglonga
PostPosted: 11:15 - 05 Nov 2009    Post subject: Reply with quote
Can bump my R1150Gs with no problems, it's all about getting the right technique. Wink
Andy Sez....
F.Y.Y.F.F.
The last post was made 16 years, 108 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 103.56 Kb
