Suzuki GN250 Rebuild - Now running!
Cigaro
PostPosted: 17:26 - 28 Oct 2009    Post subject: Suzuki GN250 Rebuild - Now running! Reply with quote
Well, here was my GN250 when I bought it:
https://farm3.static.flickr.com/2488/3998301760_7b9bb6b33a_b.jpg
Basically bought it as a non-runner - it actually does run but sounded like shit.
I adjusted the valve clearances, it helped a bit but not much. Also I noticed LOTS of rust on the frame, some frayed wires in the loom, etc.
So, I decided that this winter I would strip it down and rebuild it. My plan is to start with the frame - remove all the paint, get rid of the rust, primer and respray, and then do a full overhaul on the engine (just to learn).
Here is what I have sitting in my living room now:
https://farm3.static.flickr.com/2426/4052847917_891177a5c4_b.jpg
The pile of parts that I've taken out of it:
https://farm3.static.flickr.com/2648/4053618190_4cf556fa95_o.jpg
Eventually the tank will be painted gloss black, the downpipes de-rusted and painted with BBQ paint, most of the wiring replaced...
I will update this thread when progress is made. On Sunday I'll pull the frontend off and remove the last few little bits from the frame such as the rear brake pedal and sidestand, and then I can start removing the paint and priming it...
Andy C
Tree Seeking Missile
PostPosted: 07:17 - 29 Oct 2009    Post subject: Reply with quote
Nice project, it is a single?
Should be nice by the end (though if it was me I would keep the red tank and just polish up the downpipes).
Look forward to seeing the updates Thumbs Up
hmmmnz
PostPosted: 09:50 - 30 Oct 2009    Post subject: Reply with quote
i think every man and his dog has had one at one point over here in nz Very Happy (250cc learner limit)
not bad little singles
the humans are dead
I kick arse for the lord
Cigaro
PostPosted: 15:18 - 31 Oct 2009    Post subject: Reply with quote
Frame stripped.
https://farm4.static.flickr.com/3503/4061290816_062afb2eec_b.jpg
Sanding all the paint off tommorrow and giving it a coat of primer, watch this space. Very Happy
PostPosted: 15:37 - 31 Oct 2009    Post subject: Reply with quote
+1 for keeping the tank red. Otherwise it'll be a-rat-a-like bike.
How indepth is this project going to be?
Defo something i'll be doing when i get a 2nd bike.
Pat
Cigaro
PostPosted: 15:51 - 31 Oct 2009    Post subject: Reply with quote
The tank is fooked and does need a respray (and a dent filling up).
I'm thinking of doing the tank in candy-apple green, see the attached image...
'How indepth': basically I want the bike to be as good as new when I'm finished.
Full rebuild of the motor definitely planned.
Fork seals need changing.
Some of the chrome is pretty rusty and needs polishing up.
I've decided not to paint the downpipes, I will polish them instead.
And the whole thing needs tweaking and setting up properly.
PostPosted: 16:06 - 31 Oct 2009    Post subject: Reply with quote
This is when a photo app comes in handy. Some people have the ability to fore-see how it'd turn out. I don't.
Happy sanding
Pat
Nice colour choice BTW
Cigaro
PostPosted: 16:42 - 01 Nov 2009    Post subject: Reply with quote
Most of the paint was removed using Nitromors, and then the worst of the rust was removed using a wirebrush:
https://farm3.static.flickr.com/2621/4063625827_a75cb38bc4_b.jpg
Beer + Powertools = GOOD!
Next, I cleaned the frame with some methylated spirits and wiped it dry. The first coat of primer was added:
https://farm3.static.flickr.com/2421/4065086434_c20d960320_b.jpg
https://farm4.static.flickr.com/3504/4065081832_563dbc0c48_b.jpg
Cigaro
PostPosted: 20:21 - 02 Nov 2009    Post subject: Reply with quote
After the first coat of primer had dried I realised that some dirt and rust were left on the frame and were showing through. So I decided to attack these spots with a wirebrush:
https://farm3.static.flickr.com/2625/4069164869_77888d0c55_b.jpg
The remaining rust is now off. After this I gave the frame another wash with meths and then wet-sanded over the existing primer with some very fine sandpaper.
I've now started to put the second coat on. Waiting for this side to dry now and then tommorrow I'll do the other side.
Throttle
PostPosted: 01:18 - 03 Nov 2009    Post subject: Reply with quote
Good work so far, should look good when it's done.
Nice to see you're a BFG graphics kinda guy Wink
rob_scott92
PostPosted: 17:49 - 03 Nov 2009    Post subject: Reply with quote
nice little project m8.
the bike is where it should be too Thumbs Up in the house, bikes get cold too Mr. Green .
Rob Thumbs Up
Cigaro
PostPosted: 17:57 - 03 Nov 2009    Post subject: Reply with quote
Well, I popped home at lunch today and finished priming the frame. I went to Halfords today and picked up an extremely fine-grit sanding pad (and a rust remover pad which will come in handy for doing the swingarm, as even the wire brush was having problems on the frame).
When I got home from work I wet-sanded the primer with the sanding pad, wiping away any dust with a rag.
https://farm3.static.flickr.com/2566/4072924320_41e4b688cb_b.jpg
This gave me a nice, reasonably smooth finish on which to deposit the colour coats.
https://farm3.static.flickr.com/2694/4072936460_3bb56bd6c8_b.jpg
The old girl has new paint!
The can said to do thin coats and allow 10 minutes between each coat. The spray came out thicker than I anticipated so I've decided to only do two coats, and sand it before finishing off with a clearcoat.
Unfortunately the way my painting 'rig' is set up means that I have to paint the frame in two halves - i.e do what is accessible on one side, wait for the paint to dry and then flip the frame upside down and do the other side. So tommorrow it's two coats on the other side - then it's clearcoat time!
This weekend I'm aiming to get the swingarm and sidestand done, and start stripping the paint from the tank. Thumbs Up
Cigaro
PostPosted: 18:16 - 03 Nov 2009    Post subject: Reply with quote
Just thought I'd add a pic of the frame after the second coat:
https://farm3.static.flickr.com/2626/4072221505_1596fcf6ce_b.jpg
transporter
PostPosted: 00:09 - 04 Nov 2009    Post subject: Reply with quote
The paint on my GN frame wasn't too bad so i just sanded down the problem areas then blew them over with a £1 tin of black from the pound shop then blew that over with clear lacquer. You say youre going to paint the downpipes with BBQ paint,have you used this stuff before, does it cling to chrome OK ?,im looking to paint my engine casings in black to match the cylinder but not sure what paint to use,wondered if BBQ paint would be any good for that,Rich
Cigaro
PostPosted: 07:24 - 04 Nov 2009    Post subject: Reply with quote
I've used BBQ paint to paint the exhaust on my previous bike (the mighty Eliminator) and that worked OK. You might need to sand the chrome a bit to get it to 'key'.
I've decided to try and polish up my pipes, though - it'd be a shame to ruin all that chrome...
Cigaro
PostPosted: 19:01 - 04 Nov 2009    Post subject: Reply with quote
Frame now painted.
https://farm3.static.flickr.com/2540/4075266195_17c9e6ae47_b.jpg
https://farm3.static.flickr.com/2595/4075266191_4c568fe221_b.jpg
Just waiting for it to dry now, Friday I'll sand it and put a clearcoat on. Thumbs Up
PostPosted: 20:35 - 04 Nov 2009    Post subject: Reply with quote
What's the reasoning behind not taking the main stand off?
Cigaro
PostPosted: 07:03 - 05 Nov 2009    Post subject: Reply with quote
Good question! I couldn't work out how to get it off Embarassed I took the splitpin out but it wouldn't come off, it seems to be held in by a rod which is flared at the end. Decided it would just be easier to paint it as-is.
Cigaro
PostPosted: 15:13 - 07 Nov 2009    Post subject: Reply with quote
Update!
Over the last few days I have been finishing the frame off - here it is painted and lacquered:
https://farm3.static.flickr.com/2715/4082594425_d577c30b4c_o.jpg
Next on the agenda is the swingarm. The brake torque arm was still attached, so I removed it:
https://farm3.static.flickr.com/2496/4083339016_d2910a5226_b.jpg
https://farm3.static.flickr.com/2769/4082579217_90652d075e_b.jpg
I have no idea how to remove the swingarm bearings (one seems to be a bit stiff, not sure if it requires regreasing?) so I stuffed some newspaper in the hole instead to stop crap getting in...
https://farm3.static.flickr.com/2674/4083337814_005d310178.jpg
Next I attacked it with the wire brush to remove any rust.
Likewise with the rear brake torque arm. Here they are both prepped for painting (I only removed the rusty bits, any remaining paint I just sanded to give the primer a 'key'...)
https://farm3.static.flickr.com/2530/4083354466_0be9374e5e_b.jpg
All primered up - tommorrow they get painted...
https://farm3.static.flickr.com/2767/4082578133_9385a9b68d_b.jpg
I then started on the tank. First I decided to use this stuff....
https://farm3.static.flickr.com/2726/4083336662_0daa773065.jpg
It removed some of the paint, but I was using loads of it and the majority still wasn't coming off, so instead I used a sanding disc with some coarse sandpaper.
https://farm3.static.flickr.com/2716/4082559855_a28e77465a_b.jpg
Half done, we're off out now so I'll finish it tommorrow. Then I'm going to fill the dents in, sand and primer it.
I also picked up this stuff at Asda, to polish up my shiny bits...
https://farm4.static.flickr.com/3517/4083320256_413de31366_b.jpg
Cigaro
PostPosted: 13:48 - 08 Nov 2009    Post subject: Reply with quote
Done some more today.
Finished sanding the tank (well, I know there is still some paint left on it, but it's pretty well sanded down and will hold the primer OK).
https://farm3.static.flickr.com/2716/4086149284_3ca7b8e461_b.jpg
https://farm3.static.flickr.com/2509/4086147886_467fe0903f_b.jpg
Also sprayed the swingarm and brake torque arm...
https://farm3.static.flickr.com/2753/4086148586_830cf47ec4_b.jpg
After sanding and cleaning the tank, the next job was to fill in the dents. I used this stuff:
https://farm3.static.flickr.com/2543/4085390275_38e5671300.jpg
Before...
https://farm3.static.flickr.com/2485/4085380777_793ed678da_b.jpg
After
https://farm3.static.flickr.com/2708/4085379585_4e8159f552_b.jpg
https://farm1.static.flickr.com/71/4086136430_3363b85509_b.jpg
Just waiting for that to cure now, then it can be sanded down and finally the tank can be primed.
Had a look at the steering head too:
https://farm3.static.flickr.com/2696/4085392481_d7f6ea850b_b.jpg
The bearings look pretty good. The metal is a bit rusty though (as usual). It shall be attacked with a wire brush...
https://farm3.static.flickr.com/2761/4086183472_40a465fc38_o.jpg
Cigaro
PostPosted: 20:35 - 09 Nov 2009    Post subject: Reply with quote
Tank primed...
https://farm3.static.flickr.com/2593/4090928958_46fa4779f3_b.jpg
PostPosted: 21:29 - 09 Nov 2009    Post subject: Reply with quote
Can I see the filler on that primed tank?
Cigaro
PostPosted: 21:54 - 09 Nov 2009    Post subject: Reply with quote
You can see it a bit, I had to resand and do it again but it's still slightly visible.
Decided to go for black around the edges and candy apple green down the middle. Here is the black coat on...
https://farm3.static.flickr.com/2513/4091101024_ee8f332749_b.jpg
Cigaro
PostPosted: 11:40 - 10 Nov 2009    Post subject: Reply with quote
Well, I decided I'd probably muffed up the tank, so I decided to sand before I went to work this morning I would put more filler on. Tonight I'll resand the filler to try and get it smooth, and then prime it again.
Decided to go for the green all over. Today I picked up a can of silver, so I'll use that as the basecoat and then a couple of coats of green. I'll post some pics tonight...
Cigaro
PostPosted: 20:23 - 10 Nov 2009    Post subject: Reply with quote
Right, did it again.
I *thought* it was totally smooth after sanding, but there were still a few small blemishes after repriming.
https://farm3.static.flickr.com/2762/4093061065_ac6a6b3c84_b.jpg
Still, I decided to go ahead with the silver base layer. Here is the first coat:
https://farm3.static.flickr.com/2769/4093062333_8c28912783_b.jpg
The filler does show through a bit more with the silver on, though isn't anything like as bad as this in the flesh...
https://farm3.static.flickr.com/2788/4093059883_2c3e51992d_b.jpg
Tommorrow I'll give it another coat and then start with the green.
Cool
The last post was made 17 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 131 Kb
