Increasing Fuel Efficiency
Thom
PostPosted: 13:11 - 05 Nov 2009    Post subject: Increasing Fuel Efficiency Reply with quote
Right, awaiting a new bike and whilst im stuck in uni i thought i'd ask a question.
The new bike is an ER5, generall quite good as a hack, hwoever im wondering if there is a way i can increase fuel efficiency throughout the rev range?
Now im thinking to myself "Create a more complete burn of the fuel" however i cant see how i can do this easily, perhaps ignition advance(start the burn earlier for a longer burn?) or perhaps new cams (Close the inlet sooner and open the exhaust later?). Perhaps it could be as simple as a different style of spark plug or fuel?
Im not necceserily going to do this but it would be interesting to see what's suggested, and if something comes up that i could perhaps sort out maybe ill try it.
P.s running the bike lean isnt an option unfortunately.
PostPosted: 13:30 - 05 Nov 2009    Post subject: Reply with quote
You probably could lean the mixture out a bit to improve consumption. Just don't do it too much. Similarly playing around with the spring on the slide you could probably get it to open more slowly and saving a bit of fuel.
Advancing the timing would only be an option if the fuel could put up with it (ie, high enough octane rating). Likely you would just get a load of detonation. The spark already happens before the piston is at the top (so the first bit of mixture burnt is pretty much wasted anyway).
If you want it really fuel efficient then use a far longer stroke and ignite the fuel far later so all of the burn is useful (you could probably use a far quicker burning fuel and ignite it later as well), and use a large flywheel to smooth things out and effectively store energy. Don't expect it to be fast though.
yen_powell
PostPosted: 13:46 - 05 Nov 2009    Post subject: Reply with quote
Get rid of any top boxes or panniers, don't wear flappy waterproofs, keep your knees in, keep your tyres pumped up, oil your chain, keep the bike in tune, ride when the traffic is lighter so you don't have to keep start/stopping, plan your filtering so it's a smooth as possible and lose weight.
XT1200Z and a DR350 in bits
el_oso
PostPosted: 16:03 - 05 Nov 2009    Post subject: Reply with quote
changing gearing may help but it will depend on what sort of speed you will be doing. Motorway journeys could be improved quite drastically simply by increasing the gear ratio and dropping the revs. It is very touch and go though as dropping the revs too much will cause more fuel than required to be injected in.
Duke 390
Car: Jeep Wrangler 4.0L
Alexio
PostPosted: 17:07 - 05 Nov 2009    Post subject: Reply with quote
Certainly does depend on how and where you ride it. On certain routes through my town I can increase speed to about 40, clutch in and cruise until my bike hits about 25 and then smoothly re-engage gear to slowly accelerate back to 40. Down hill this works even better. Would definitely depend on the momentum of you bike but this sometimes saves me much fuel when the roads are quiet.
Cigaro
PostPosted: 17:32 - 05 Nov 2009    Post subject: Reply with quote
You will use a lot more fuel keep accelerating back up to speed than if you just sat in gear and cruised.
PostPosted: 17:34 - 05 Nov 2009    Post subject: Reply with quote
Coasting with the engine engaged uses less fuel than if you have the clutch pulled. Obviously you slow down quicker though.
To get the best out of this you'd want to pull the clutch in and flick the kill switch off and then back on, then just let the clutch out, the bike will start and you can continue riding.
PostPosted: 20:57 - 05 Nov 2009    Post subject: Reply with quote
You could use a friction reducing micro oil like ACTIVE8 or ZX1 (sold in Half*rds) add a table spoon of the stuff to a full tank of petrol, then go for a ten mile ride.
On a bike with a carb you will need to adjust your tickover speed afterwards as the revs will rise.
PostPosted: 21:10 - 05 Nov 2009    Post subject: Reply with quote
Not so sure on bike with either carbs or fairly crude fuel injection systems. On cars they often cut the injectors totally when the revs are higher and the throttle is shut, hence on those coasting with the engine engaged does use less fuel than pulling the clutch.
PostPosted: 21:11 - 05 Nov 2009    Post subject: Reply with quote
That won't work if the bike has a wet clutch because it will just make the clutch slip.
Also I was under the impression that friction reducers were supposed to be put into the oil, not the fuel. Putting stuff in the fuel which isn't supposed to be in the fuel is very bad as it leans off the mixture.
Alexio
PostPosted: 22:09 - 05 Nov 2009    Post subject: Reply with quote
Well, I swear my town is the hilliest town in England Shocked by certain routes I guess what I meant was;
When you are going down a hill, don't forget to pull in the clutch and cruise!
Of course, you'd lose the fuel efficiency when having to go back up the hills, but at least it would be kind of balanced rather than simply burning more in a hilly area.
PostPosted: 07:47 - 06 Nov 2009    Post subject: Reply with quote
do you seriously pull your clutch in and cruise...
I thought that was a disaster waiting to happen..thus havent really done that.
Only way to really increase fuel economy is to ride more sensible Razz
PostPosted: 10:25 - 06 Nov 2009    Post subject: Reply with quote
Unlike a teflon based additive, these particular products will not affect a normal wet clutch.
They are added to the fuel to treat the bore, and can be added to the oil to treat any hard bearing surfaces.
The single one off application required (which is 1cc per litre of petrol) is insufficient to cause fueling issues.
Alexio
PostPosted: 10:42 - 06 Nov 2009    Post subject: Reply with quote
When I'm running out of petrol, yes I cruise. Otherwise I don't. It makes me feel like I'm doing something to get myself to the next petrol station without running out of my reserve Laughing
The car theory test tells you that cruising is dangerous and should never be done because in a car braking and steering is often engine assisted.
This isn't in the bike theory test because the brakes and steering aren't dependant on the engine even being turned on thankfully. Also, even while I cruise I'm still in the right gear to brake with my engine if needed.
PostPosted: 14:37 - 06 Nov 2009    Post subject: Reply with quote
Ah cool cheers Alexio!
If i recall you are from Hastings?
Alexio
PostPosted: 15:36 - 06 Nov 2009    Post subject: Reply with quote
Correct. Although I should probably edit what I said slightly. Some big bikes are equiped with ABS which I suspect requires the bike to be turned on in order to work. So if you have ABS, I highly recommend you don't kill your engine and cruise!
The last post was made 16 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.05 - MySQL Queries: 13 - Page Size: 99.84 Kb
