OT: Car Clutch
el_oso
PostPosted: 14:18 - 07 Nov 2009    Post subject: OT: Car Clutch Reply with quote
got an 03 fiesta and the clutch has gone
anyone know anything about an 03 fiesta clutch
assuming it is hydraulic not cable and im assuming it has something to do with the MC/SC/hose/hydraulic leak or (snapped cable if it is a cable clutch) as it was a sudden fail.
haven't had any problems up until now. no slipping (or not that i've noticed.
suggestions? ideas? anything that will help?
thanks in advance
Duke 390
Car: Jeep Wrangler 4.0L
kingsmith
PostPosted: 14:44 - 07 Nov 2009    Post subject: Reply with quote
so what way has it gone ??
can you not get gears when clutch pressed is the pedal going to the floor??
if cable probley snapped?
and hydrolic then might have leak somewere in the system..hard to say with out details..
honda cg 125 copy cheap and crap, perfect for work..
suzuki gsxr600 srad 2000
passed 12/11/09 happy boy
duhawkz
PostPosted: 15:29 - 07 Nov 2009    Post subject: Reply with quote
I found this it sounds like its a common problem
The rod on the pedal that actuates the salve cylinder on these have a nasty tendency to slip off the pedal - when you get it repaired - there is a clip available from garages/motor accessory shops etc that looks like a washer with teeth on it pointing towards the centre - this will stop the rod sliding away from the pedal stopping it from breaking.
hope this helps
el_oso
PostPosted: 16:16 - 07 Nov 2009    Post subject: Reply with quote
sorted. went out to check my first guess which was that it was something to do with the pedal/slave cylinder as i still had working brakes. looked at the linkage between the pedal and the slave cylinder and it had indeed slipped off. come back and found that duhawkz has the right answer.
thanks for the help guys.
one last question, anyone know any where i can get a downloadable haynes manual for the fiesta
Duke 390
duhawkz
PostPosted: 16:32 - 07 Nov 2009    Post subject: Reply with quote
https://www.torrentz.com/3176fc023be959d6bea00ff563139af3c0d4d5d7
Noxious89123
PostPosted: 20:36 - 07 Nov 2009    Post subject: Reply with quote
A Haynes is only £19, just buy one. But I'm a big fat hypocrite, because I download stuff for "free". It is rather handy to have one next to you when your working on stuff.
Haynes Manual
Finglonga
PostPosted: 21:41 - 07 Nov 2009    Post subject: Reply with quote
Haynes Manual
Thats what a printer is for, just print off the pages you need. Wink
Andy Sez....
F.Y.Y.F.F.
el_oso
PostPosted: 10:34 - 08 Nov 2009    Post subject: Reply with quote
i only really want the manual to check numbers to be honest.
i also don't want to spend £19 on something that i can download for free when i don't even use this car.
Duke 390
The last post was made 16 years, 236 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 56.58 Kb
