Neutral
lau
PostPosted: 11:10 - 08 Nov 2009    Post subject: Neutral Reply with quote
Hey,  I have a 2001 Kawasaki Er5, when the on center stand, in neutral the rear wheel rotates (about 2 complete turns per second). If I pull in the clutch, the wheel still moves at the same rate. Does anyone know what's causing this?
lau
PostPosted: 11:42 - 08 Nov 2009    Post subject: Reply with quote
Here's the answer to an almost exactly the same question from four years ago...
https://en.allexperts.com/q/Motorcycle-Repair-837/84-GPZ-1100-centerstand.htm
Question
I have a 1984 Kawasaki GPZ 1100. When the on center stand, in neutral the rear wheel rotates very fast (about 2 complete turns per second). If I pull in the clutch, the wheel still moves at the same rate.
I just purchased this motorcycle, it has 12,000 miles, I am the second owner. It was started every month, but very few miles (less then 100 per year) over the past 11 years. Anyway, are there an adjustment, other then the cable, which I can try prior to taking it in?
Answer
Hi Steve,
Try adjusting the clutch and clutch cable.
If the wheel rotates after adjustments, check the clutch plates.
Measure thickness of fiber plate in three areas around each plate. Measure metal plates on a true flat surface for warping. Compare your measurements with the service manual's service limits for clutch plates.
Inspect metal plates for discoloration. If metal blates are blued, they'll need to be replaed.
It's important to replace metal plates, fiber plates and clutch springs as a set. Doing otherwise will result with the worn parts quickly wearing the new parts. (Same with chains and sprockets.)
lau
PostPosted: 11:55 - 08 Nov 2009    Post subject: Reply with quote
Nice one thanks! I'll give it a go.
Lau
Cigaro
PostPosted: 14:32 - 08 Nov 2009    Post subject: Reply with quote
A lot of bikes do this - I think it is fairly normal.
iooi
PostPosted: 09:15 - 09 Nov 2009    Post subject: Re: Neutral Reply with quote
lau
If you stop the wheel with the brake does it start moving again when you release the brake ?
PostPosted: 12:19 - 09 Nov 2009    Post subject: Reply with quote
Providing it stops when you apply the back brake, don't worry about it, it's perfectly normal.
It is nothing at all to do with the clutch so don't bother stripping it.
ER5s do have an issue where the clutch plates stick together if left standing for a long time, causing it to stall when put into first. This usually sorts itself out after a few attempts at changing into gear but isn't what you are describing anyway.
A very basic (and not strictly accurate) rundown of a bike gearbox:
There are three shafts whith a variety of gears on them. The gears are slid along the shaft by the gearshift to engage with one another so they turn together in different ratios. They can also be slid from "plain" parts of the shaft where they rotate on the shaft to "splined" parts of the shaft where they turn the shaft too.
The gears turn all the time (which is why bike gearboxes change so smoothly), the different ratios are given by moving certain combinations onto the splines so they turn together.
They still turn in neutral too but the gears are all on a "plain" part of the shaft so in theory they turn on the shaft rather than turning the shaft with them.
In a totally frictionless gearbox, they would spin away merrily by themselves. Such a thing is not really possible, the slight friction between the gears and the shaft causes the wheel to turn.
Most modern bikes have a rear disc brake which grips the disc slightly even when off, this prevents you seeing the wheel turning. I'm guessing your bike has a drum brake.
Overall it's a good sign. It means your wheel rotates freely with very little resistance.
The last post was made 16 years, 351 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 50.04 Kb
