| lau |
 lau Two Stroke Sniffer
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 11:42 - 08 Nov 2009 Post subject: |
Here's the answer to an almost exactly the same question from four years ago...
https://en.allexperts.com/q/Motorcycle-Repair-837/84-GPZ-1100-centerstand.htm
| Quote: | Question
I have a 1984 Kawasaki GPZ 1100. When the on center stand, in neutral the rear wheel rotates very fast (about 2 complete turns per second). If I pull in the clutch, the wheel still moves at the same rate.
I just purchased this motorcycle, it has 12,000 miles, I am the second owner. It was started every month, but very few miles (less then 100 per year) over the past 11 years. Anyway, are there an adjustment, other then the cable, which I can try prior to taking it in?
Answer
Hi Steve,
Try adjusting the clutch and clutch cable.
If the wheel rotates after adjustments, check the clutch plates.
Measure thickness of fiber plate in three areas around each plate. Measure metal plates on a true flat surface for warping. Compare your measurements with the service manual's service limits for clutch plates.
Inspect metal plates for discoloration. If metal blates are blued, they'll need to be replaed.
It's important to replace metal plates, fiber plates and clutch springs as a set. Doing otherwise will result with the worn parts quickly wearing the new parts. (Same with chains and sprockets.) |
____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| lau |
| Cigaro |
 Cigaro World Chat Champion
| iooi |
 iooi Super Spammer
| stinkwheel |
The last post was made 16 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
