piston problem
ALLY KURWA
PostPosted: 06:58 - 10 Nov 2009    Post subject: piston problem Reply with quote
I HAVE A KAWASAKI KMX 125cc LIQIUD COOLED AND ITS A 2STROKE EGINED BIKE .MY SLEEVE HAD A PROBLEM AND I HAD TO REPLACE IT SO I REPLACED IT WITH A STEEL METAL MATERIALED SLEEVE BUT FROM WHEN I DID THAT IT ALWAYS BREAKS THE PISTON RINGS EVERY TWO DAYS AFTER REPLACEMENT
Ariel Badger
PostPosted: 07:57 - 10 Nov 2009    Post subject: Reply with quote
Ring gap.
Caps.
PostPosted: 16:02 - 10 Nov 2009    Post subject: Reply with quote
Piston rings catching on unchamfered transfer ports ?
stevo as b4
PostPosted: 17:19 - 10 Nov 2009    Post subject: Reply with quote
Your post is unclear tbh! Do you mean that your cylinder barrel was fitted with a sleeve or liner to replace the damaged Nikasil coating of the original bore surface?
Have you had the liner replaced again, and is it an oversize bore and piston being used, or standard? Do you know what the ring gaps are and what clearances are being used bore to piston etc.
I suspect that a linered cylinder will need larger piston/ bore clearances than the original Nikasil plated cylinder would require.
Blue_SV650S
PostPosted: 17:42 - 10 Nov 2009    Post subject: Reply with quote
Yep, presuming what he said, I think you might find 'they all do that sir'.
I was thinking of getting this as a solution to my scored Nikasil, but the bike shop I went to said he has had a couple of these done now and have exactly the problem you are describing. He admitted he might have had an unlucky pair, but also said he wont get any more done now (lets face it, that is understandable). He said he wasn't 100% sure why it was having problems, but suspected it was something to do with the heat transfer of piston and liner. Perhaps that the piston is designed to expand at the same rate as a Nikiasil bore, you put a sleeved liner in there and it has a different expansion rate. Obviously if this is slower .... NIP!!! Wink
As others have said, check the ports look to be correctly tapered, and it is the correct size piston/ring, but sadly you may well have found a 3rd example to add to this mechanics/shops growing list of 'it just does it' jobs!! Shocked Sad
The last post was made 16 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 44.14 Kb
