| smegballs |
 smegballs World Chat Champion
| Howling TerrorOutOfOffice |
 Posted: 00:32 - 10 Nov 2009 Post subject: |
Budget?
These are the best of the cheapest. When i say best i mean very good as well.
Marantz do some cracking CD or SACD players ditto for NAD
Cambridge Audio make great amps.
Wharefdale 10.1 speakers
Mordant Avant speakers
Or maybe you want some active speakers? (built in amps).
Pat ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
 Posted: 00:42 - 10 Nov 2009 Post subject: |
How big is your room and its shape? Upstairs?
This will have a bearing on size of amp and speakers and even whether you'll be able to use a subwoofer.
Placement of speakers is important aswell. What you put them on and where you put them. In a corner they will sound boomy. On a wooden desk they'll vibrate.
My mission is to get people to listen to their music properly.
| smegballs |
 Posted: 00:51 - 10 Nov 2009 Post subject: |
Concentrate on the amp. You can plug almost anything into a good amp.
I'd also suggest just getting a stereo one, your music is stereo.
Couple of biggish, standard speakers that match the amp to start with and see how it goes. Take a simple stereo amp with a single volume knob and a 5.1 surround amp with flashy lights, sliders and twiddly bits for the same price and I know which will give you the best sound quality. A good amp will let you turn it up LOUD without distorting the sound
To be honest, my entry level 200W cambridge audio amp with triple cone, bi-wired floor standing speakers has a high enough output that you really wouldn't want to be in the same room at anything over 3/4 volume.
If you want more bass, you could add in a sub woofer.
I got the CA amp because it has plenty of inputs and an analogue channel for my record player. It's connected to the record player, radio tuner, playstation, DVD player and computer. I also connected the monitor output back into the computer so I can record whatever is playing on the stereo.
Playing guitar hero is fucking awesome on that setup .
EDIT: Picture. This was not an expensive setup.
https://www.bikechatforums.com/download.php?id=68981
| Pernig |
 Pernig World Chat Champion
 Posted: 00:53 - 10 Nov 2009 Post subject: |
If you have a decent PC it is a great starting point for your system as it can handle all your mutlimedia 'sources' in one package. Do bear in mind that many PC's sound cards are prone to some really nasty noise, so consider using a digital output (S/PDIF or HDMI) or buying an amp with some sort of noise reduction.
Also, I have found the sound card drivers are often at fault for noise, so perhaps consider learning how to set up ASIO on your PC.
Modular and separate systems are hard to come by from mainstream stores nowadays. The way I do it is build my own boxes or buy cheap speakers with boxes that are in good condition and put my own speakers and crossovers inside so I have a bit more cash left to spend on a nice amp.
I bought a pair of ancient Aiwa speakers with a stereo system from an old lady at a car boot for £15. The boxes were in really good condition so I took the old components out and bought some 16 and a half inch JBL component car speakers (equivalent to a Control 1, another very good speaker for cheap and especially good for wall mounting as it is compact), then bought some sexy old-fashioned JBL badges from eBay to tart them up.
I definitely agree with Terror in that if you want to spend a lot of money on your speakers to get active ones. Saves a lot of faffing around! ____________________ H100 Breaking for spares |
| smegballs |
 Posted: 01:07 - 10 Nov 2009 Post subject: |
Keep an eye on richer sounds for some bargain hi-fi equipment.
They often have some real bargain end of range/clearance stuff.
https://www.richersounds.com/ |
 Posted: 01:18 - 10 Nov 2009 Post subject: |
Right kind of idea. As has been said, the Cambridge Audio ones are a good, entry level amp. and there are quite a few on ebay. The build quality is excellent, they are a solid piece of kit with plenty of intelligently designed heat-sinking. The A1 and A5 models have stood the test of time.
You could do a lot worse than an A5 as a first amp. Mine hasn't been switched off for five years. |
| smegballs |
| Ariel Badger |
 Ariel Badger Super Spammer
| smegballs |
| Raffles |
 Raffles World Chat Champion
| smegballs |
| oldpink |
 oldpink World Chat Champion
 Posted: 16:20 - 10 Nov 2009 Post subject: |
I found the 5.1 system impractical for my room. And unless its set up as per piccy above you won't enjoy it.
As mentioned you can't beat a 2 spoeaker system run by a discreet and powerful amp with thick cable to speakers that match. Bi-wire if possible as it improves clarity (marginal)
https://i104.photobucket.com/albums/m174/howlingterror_2006/how-to-bi-wire-speakers-2.gif
If you're using speaker stands (Argos are cheap) Fill them with sand(use sealant on the bottom) and use the spikes.
Use blobs of blu-tac to 'de-couple' them from whatever they're sat on. I use mo-pads..but i'm a tart.
Speakers and yourself should form a equilateral triangle. With the tweeters at ear level.
No need to splash out on expensive cable. QED Silver is ideal as it looks good, thick electric copper cable is ugly but works just the same. Just don't use that weedy wire everyone has knocking about.
You'll get a clearer sound if your speakers are kept away from walls and especially corners. If you have to put them close to a wall, choose speakers with fwd facing ports.
| Matthie |
 Matthie World Chat Champion
 Posted: 17:43 - 10 Nov 2009 Post subject: |
In my 'garage' (2 rooms, double glazed ect) I have 2 mission floor standing speakers, 2 normal hifi speakers for treble, and 2 10" 600W JBL car subs in a box in the middle. The subs are running off a 1500W car amp and are pretty beefy!
Got all of those running off my decks and apparently you can hear the bass a few houses down on the street when I have it at my normal volume.  ____________________ ***Previous: GPR50, FZ750 *** Current: Monkey bike, yella SV 650 ***
Tutton says: I hate random hardons, they are so weird... |
| WishayKillie |
 WishayKillie World Chat Champion
 Posted: 17:52 - 10 Nov 2009 Post subject: |
| stinkwheel wrote: | Concentrate on the amp. You can plug almost anything into a good amp.
https://www.bikechatforums.com/download.php?id=68981 |
I spy a bottle of Lagavullin (I think) in that drinks cabinet  ____________________ Current; 10' Aprilia Dorsoduro 750.
"Needs a check-up, fae the neck up!" |
| divuk83 |
 divuk83 World Chat Champion
 Posted: 21:38 - 10 Nov 2009 Post subject: |
Don't waste money on bi-wiring speakers, just make a little pair of jumpers cables between the two sets of terminals on the back of the speakers.
https://www.divuk83.net/images/F_-_Connection.jpg
If you main source is your PC then don't use the crap onboard sound, and M-Audio 2496 is a good budget card for stereo music. Can be had for less than 50 squid, sounds much better than any onboard sound and has RCA outputs which makes it easier to connect up to an amp.
Don't use any crap car "hi fi" stuff as it's just designed to make a boomy noise and not be in any way musical.
What is your budget?
Dave |
| trevoriv |
 trevoriv World Chat Champion
 Posted: 23:09 - 10 Nov 2009 Post subject: |
 Posted: 01:29 - 11 Nov 2009 Post subject: |
But a good amp (like the C.A. A5) has multiple outputs. So to biwire you do the following: |
| divuk83 |
 Posted: 10:24 - 11 Nov 2009 Post subject: |
It makes no difference if you use both sets of outputs on the amp or not, main (slight) improvement is from bypassing the crap metal links on the the binding posts on the back of the speakers. This also means you only need half as much speaker cable saving you money.
https://img687.imageshack.us/img687/4149/howtobiwirespeakers2a.gif
Many "good" amps do not have two sets of speaker outputs as it's unnecessary.
Dave |
 Posted: 23:47 - 11 Nov 2009 Post subject: |
^^^You are not using the speakers full potential in that diagram. And the Linking Brackets are quite often gold plated even on sub £100 speakers.
So if your speaker has 2 pairs of connectors why not use them. Especially if you're young and got good hearing...(wasted on my battered flaps)
Again, if you're being thrifty get some of this.
| Pernig |
The last post was made 16 years, 309 days ago. Instead of replying here, would creating a new thread be more useful? |
