Chain life?
killa
Won't Shut Up
PostPosted: 10:16 - 11 Nov 2009    Post subject: Chain life? Reply with quote
Errr, just had a scan over that thread where the chain was almost snapped and thought of mine.
I can't actually remember when i bought my D.I.D chain and sprocket kit but its been bloody good and still seems good today, never really needs adjusting.
How many miles should you be looking at before changing one of these??
I think i've done around 7K on this kit.
sickpup
Old Timer
PostPosted: 11:44 - 11 Nov 2009    Post subject: Reply with quote
I did 26k on the last one. I don't think you have to worry yet.
PostPosted: 11:59 - 11 Nov 2009    Post subject: Reply with quote
15k seems to be about average for me. Sometimes if well looked ater they will last far longer.
Alexio
PostPosted: 12:05 - 11 Nov 2009    Post subject: Reply with quote
+1 for about 15k so far in my experience Thumbs Up
neil.
PostPosted: 12:20 - 11 Nov 2009    Post subject: Reply with quote
15K for me too. Thumbs Up
Dragonfly
PostPosted: 12:25 - 11 Nov 2009    Post subject: Reply with quote
sorry but (to the tune of blur-park life)
all the chains, so many chains and they all go round and round round and round they go, chain life!
All the breast.
Muzza on Binge:
PostPosted: 12:29 - 11 Nov 2009    Post subject: Reply with quote
Tut Tut
yen_powell
PostPosted: 12:34 - 11 Nov 2009    Post subject: Reply with quote
I'm up to 33,000 miles on my DID x-ring chain and it's still in top condition. I'm going to replace the front sprocket though, it's well past it's best.
I seem to be getting similar mileage to when I ran a scottoiler so maybe they don't do as well as I thought. I just drop a bit of car engine oil on the inside run of the x rings every so often when it looks dry. Wet weather means every other day, dry weather it can go a few weeks without re oiling.
XT1200Z and a DR350 in bits
27cows
PostPosted: 12:36 - 11 Nov 2009    Post subject: Reply with quote
It's impossible to say what the life of any chain will be, because how quickly or otherwise it wears will depend on a huge number of factors. The best thing to do is visually inspect the chain when lubing it, and bin it the moment a significant tight spot appears.
LeeR
PostPosted: 12:45 - 11 Nov 2009    Post subject: Reply with quote
Previously I've gotten 15,000 miles from mine, but since fitting the Scottoiler it looks as though I'll get a lot more.
My claim to fame: Austin Vince nicked my pen...
Dragonfly
PostPosted: 12:54 - 11 Nov 2009    Post subject: Reply with quote
Tut Tut
Sorry Shifty Embarassed
All the breast.
Muzza on Binge:
doggone
PostPosted: 13:54 - 11 Nov 2009    Post subject: Reply with quote
They do tend to seem 'as new' then go very rapidly once they start.
Kris
PostPosted: 14:23 - 11 Nov 2009    Post subject: Reply with quote
Yep, agree with that.
Just recently changed mine after 31k miles (a clean and re-oil every other week) and the chain went from good condition to being pulled off the rear sprocket in under a week.
www.prisonplanet.com
PostPosted: 16:22 - 11 Nov 2009    Post subject: Reply with quote
Unsure of the age/mileage of my chain. Its got 2 tight spots and can be pulled halfway up the tooth at the rear of the sprocket.
I've had no problems with it and keep it clean, adjusted and lubed. Reckon i should replace? or will it last a few thou more?
Pat
Skudd
It does depend on how you maintain your chain and the way you ride. If you don't oil the chain, leave it slack and are always on the gas the chain won't last long. If you keep the chain oiled, adjusted correctly and are smooth with the throttle then your chain should last.
panrider_uk
PostPosted: 16:26 - 11 Nov 2009    Post subject: Reply with quote
How often do you check/adjust your chains?
Mark
Alexio
PostPosted: 16:29 - 11 Nov 2009    Post subject: Reply with quote
Mark
For me it's at least every thousand miles although I glance at my chain quite often to see if it's too loose or dry.
robbieguy2003
PostPosted: 17:01 - 11 Nov 2009    Post subject: Reply with quote
Last chain was from new (bike had 0 miles) and I got to 14k on that, it would have still had a bit more in it to be honest but not huge amounts.
I'd abused that chain a little as well.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
chillpill
PostPosted: 17:33 - 11 Nov 2009    Post subject: Reply with quote
Alexio wrote:
Mark
https://rofflezilla.com/images/o-rly.bmp
Alexio wrote:
My CG was running like crap (hitting a whole 50MPH) but it was pointed out to me that there was rust on my chain and upon inspection I found my chain without any lubrication at all Shocked. So I oiled up my chain and off we set up the A21. Was hitting 60 - 65 no problem now.
Charlie
PostPosted: 17:38 - 11 Nov 2009    Post subject: Reply with quote
Current chain is a gold DID thingy, done near 20,000 miles with chain adjustment only when tyres fitted. Also run a dual injector Scotoilier. I have just replaced the front sprocket as that was gone. Was just a cheap front sprocket, so I will see what the chain does. I think it will be fine, although I think I should expect it to not like it as you are meant to change the sprockets & chains together.
sickpup
Old Timer
PostPosted: 22:18 - 11 Nov 2009    Post subject: Reply with quote
Mark
Every day.
PostPosted: 22:23 - 11 Nov 2009    Post subject: Reply with quote
Depends on the bike and how lazy I am. ZZR600 gets lubed pretty much every day it is used (normally a 200 mile round trip). But it has only been adjusted twice in the last year I think.
Bikes without centre stands get abused a bit more.
Alexio
PostPosted: 23:56 - 11 Nov 2009    Post subject: Reply with quote
Yeah and by quite often clearly I didn't mean so often that I don't overlook it once in a while Rolling Eyes you haven't caught me out with my own words, it just happens that "quite often" is open to interpretation and it's been raining an awful lot recently. No good for chains at all, in the winter I guess I have to check more often.
And that particular time I found rust on my chain it definitely wasn't there three days before which before that was the last time I had properly used my bike.
The last post was made 16 years, 297 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 123.94 Kb
