| lonner |
 lonner Spanner Monkey
 Posted: 22:38 - 12 Nov 2009 Post subject: silican brake fluid (anyone used it) |
as the title suggests.
i have not tried it and assume its dot 5 synthetic etc
any pitfalls as apparently it does not ruin paint and no water absorption.
thanks for any info  |
| Bezzer |
 Bezzer World Chat Champion
 Posted: 00:16 - 13 Nov 2009 Post subject: |
Dot 5 Silicone isn't really used on road machines more for race as it has a high boiling point but needs to be changed regularly or in classic type motors where they hardly ever run as it's not corrosive. Not really suitable for the road as needs to be changed regular as it absorbs air , not moisture like Dot3/4, not absorbing moisture means the water stays in the system seperately , reduces pressure and can be a bitch to get out. Also you can't use it with ABS systems as it doesn't lubricate well and can't mix it with 3/4 so you need an uncontaminated braking system - hoses, master cylinder, calipers etc. All in all not worth changing to  ____________________ I used to be indecisive but now I'm not quite so sure. |
 Posted: 00:20 - 13 Nov 2009 Post subject: |
Think the main bike use for it is for Harleys. Also used in some military vehicles.
Advantage is that as it doesn't absorb water it pretty much lasts for ever so little need to bleed it. Down side is as it doesn't absorb water, any moisture in the system tends to stay there and is difficult to flush out.
Doesn't attack paintwork.
Although it has a high boiling point if tends to give soft brakes even in normal use.
| lonner |
 Posted: 08:02 - 13 Nov 2009 Post subject: |
thanks guys
i noticed its rather pricey too.
was told to fit it with all my new brakes but i have no probs with dot4 as i change it regularly |
| MarJay |
 MarJay But it's British!
| lonner |
| Ariel Badger |
 Ariel Badger Super Spammer
The last post was made 16 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
