silican brake fluid (anyone used it)
lonner
PostPosted: 22:38 - 12 Nov 2009    Post subject: silican brake fluid (anyone used it) Reply with quote
as the title suggests.
i have not tried it and assume its dot 5 synthetic etc
any pitfalls as apparently it does not ruin paint and no water absorption.
thanks for any info Thumbs Up
Bezzer
PostPosted: 00:16 - 13 Nov 2009    Post subject: Reply with quote
Dot 5 Silicone isn't really used on road machines more for race as it has a high boiling point but needs to be changed regularly or in classic type motors where they hardly ever run as it's not corrosive. Not really suitable for the road as needs to be changed regular as it absorbs air , not moisture like Dot3/4, not absorbing moisture means the water stays in the system seperately , reduces pressure and can be a bitch to get out. Also you can't use it with ABS systems as it doesn't lubricate well and can't mix it with 3/4 so you need an uncontaminated braking system - hoses, master cylinder, calipers etc. All in all not worth changing to Confused
PostPosted: 00:20 - 13 Nov 2009    Post subject: Reply with quote
Think the main bike use for it is for Harleys. Also used in some military vehicles.
Advantage is that as it doesn't absorb water it pretty much lasts for ever so little need to bleed it. Down side is as it doesn't absorb water, any moisture in the system tends to stay there and is difficult to flush out.
Doesn't attack paintwork.
Although it has a high boiling point if tends to give soft brakes even in normal use.
lonner
PostPosted: 08:02 - 13 Nov 2009    Post subject: Reply with quote
thanks guys Thumbs Up
i noticed its rather pricey too. Shocked
was told to fit it with all my new brakes but i have no probs with dot4 as i change it regularly
PostPosted: 10:36 - 13 Nov 2009    Post subject: Reply with quote
They might have been suggesting DOT 5.1, which is a normal non silicon fluid (and is compatible with DOT 3 and DOT 4) but with a higher boiling point than DOT 4.
PostPosted: 12:38 - 13 Nov 2009    Post subject: Reply with quote
I thought it wasn't legal to use dot 5 on the road?
lonner
PostPosted: 13:00 - 13 Nov 2009    Post subject: Reply with quote
yes your probably right on that keith Thumbs Up
marjay
as for the legal issue if its race use only id guess that would be true Thumbs Up
PostPosted: 13:11 - 13 Nov 2009    Post subject: Reply with quote
Nothing I have heard of about DOT 5 being illegal for road use. Plenty of people do use it, including Harley Davidson as standard in many models (at least until recently). Virtually nobody uses it for racing as it has the down side of spongy brakes while its up side of long life is pretty irrelevant.
Ariel Badger
PostPosted: 21:08 - 13 Nov 2009    Post subject: Reply with quote
I think you are confusing it with heroin in primary schools.
The last post was made 16 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.38 - MySQL Queries: 14 - Page Size: 62.47 Kb
