| Bike Jockey |
 Bike Jockey Two Stroke Sniffer
| ms51ves3 |
 ms51ves3 Super Spammer
| Bike Jockey |
| ms51ves3 |
| Bike Jockey |
| and |
 and World Chat Champion
| Damon |
 Damon World Chat Champion
 Posted: 10:21 - 21 Nov 2009 Post subject: |
Surley you could have carried on. I haven't had a speedo on my old RS for over a year now. You shouldn't be looking at it anyway, just judge your speed on the cars/ things around you.  |
| Ariel Badger |
 Ariel Badger Super Spammer
| smegballs |
 smegballs World Chat Champion
| brendentaylor |
 brendentaylor L Plate Warrior
 Posted: 04:15 - 23 Nov 2009 Post subject: |
Hi there,
I haven't got any ideas, but I was wondering if you ever got a solution
as I would like to do the same thing. Cheers! ____________________ gifts for men
| Mystery |
 Mystery World Chat Champion
 Posted: 04:41 - 23 Nov 2009 Post subject: |
as stated you should be able to judge without the speedo, i learned after i sheard the cable on my bike i just use the revs and speed of cars in front  ____________________ Carbon knuckles assure you maximum protect against debris and unfortunate accidents or if someone cuts you off, their side mirror.Mopeds are like chubby chicks.. they are really fun to ride until you're friends catch you on one |
| chris-red |
 Posted: 05:49 - 23 Nov 2009 Post subject: |
HAHA you actually cancelled a journey for that
Personally if I is easy to get to unbolt it at the clock end get wheel the bike forward (you may need help) see if the inner of the cable is turning if it is grab it with you fingers and put some light resistance against it to see if it stops turning, then take the other end off and put a drill on it turn it slowly and see if the other end of the cable spins.
If the cable doesn't spin and you can stop it either time you need a new cable.
If it doesn't spin when being wheeled forward but does with the drill there is a problem with the speedo unit at the wheel/gearbox
If it spins both times fine you have a problem in your clocks.
You hope it is the first one as it is the cheapest/easiest option.  ____________________ Well, you know what they say. If you want to save the world, you have to push a few old ladies down the stairs.
| Alexio |
 Alexio World Chat Champion
 Posted: 11:12 - 23 Nov 2009 Post subject: |
Agreed. Speedo cables are quite cheap anyways.
I'm also in disbelief that you went back home. I've gone on trips hundreds of miles long on country A roads without a working speedometer, although granted country roads have fewer speed cameras.
You Sir, are a coward  ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| ms51ves3 |
 Posted: 11:15 - 23 Nov 2009 Post subject: |
| chris-red wrote: | HAHA you actually cancelled a journey for that
You hope it is the first one as it is the cheapest/easiest option.  |
An easier way to check a speedo cable is broken is just pull on the opposite ends of the inner cable. If they both come out you know there is a break. |
| Cigaro |
 Cigaro World Chat Champion
| ms51ves3 |
| the grim reaper |
 the grim reaper World Chat Champion
| Syx |
 Syx World Chat Champion
| ms51ves3 |
| G |
 G The Voice of Reason
 Posted: 12:43 - 23 Nov 2009 Post subject: |
For speed traps, with no speedo you just follow other vehicles or go very slow - enough people do this in front of speed traps not to be suspicious.
For the rest of the time, I would be worried if your speedo was the main judge of safety. You don't happen to work for a 'safety camera partnership' do you?
When I got busted ages ago I found I could actually judge the speed at the position they described ten minutes previously pretty accurately.
I took what I thought and knocked a few mph off, which did turn out to be a few mph below what they said. I didn't want to draw attention to the fact there wasn't even a needle on the clocks.
It's quite possible your speedo cable has just vibrated out of one end too, doing it up may be all you need to do. |
| truslack |
 truslack World Chat Champion
| ms51ves3 |
| calyx |
 calyx World Chat Champion
| Bike Jockey |
The last post was made 16 years, 305 days ago. Instead of replying here, would creating a new thread be more useful? |
