Arduino geekery?
UnknownStuntm...
PostPosted: 13:34 - 23 Nov 2009    Post subject: Arduino geekery? Reply with quote
So, I've got one on order for a project, I would like to create a rev counter, from a single cylinder engine. Anyone got any experience of such a thing?
Syx
PostPosted: 15:07 - 23 Nov 2009    Post subject: Reply with quote
I've had some experience with PIC microcontrollers (I have a clock working at home, and am attempting to build a device to measure lean angle) - not sure how similar they are to the Arduino kit. I would guess there are lots of setup examples out there though... and then it's just a matter of the code!
UnknownStuntm...
PostPosted: 15:41 - 23 Nov 2009    Post subject: Reply with quote
I suppose what I'm asking is a microelectronic pickup question really. Like, a coil of wire wrapped around the HT lead, then through some electrickery to remove spikes etc, before it can be safely fed to an I/O.
I remember years back I had some books about this kinda thing where I was supposed to be paying attention in class. Maybe I'll dig them out of the loft.
Syx
PostPosted: 16:54 - 23 Nov 2009    Post subject: Reply with quote
I seem to remember that some rev counters work by wrapping a "sensor wire" around the HT lead to induce a pulse - so that seems to be your option! I'd probably start out by doing that and passing it through a couple of filters then seeing what kind of pulse you get from it.
Edit: The filters you need will most likely be the same kind you get on voltage transformers, as they do the same thing (smooth out the "spikes"). Although I would guess you don't want to oversmooth as it is the spikes you'll be using!
Here's a similar project that includes a schematic: https://www.quasarelectronics.com/smart-kit/1143-digital-rpm-indicator.htm
PostPosted: 18:29 - 23 Nov 2009    Post subject: Reply with quote
I'd be tempted to try a 555 timer as a Schmitt trigger with, as Syx has mentioned, a few loops of wire wrapped around the HT lead. The 555 will then produce a clean (reversed) square wave which you should be able to count on the Arduino.
https://www.kpsec.freeuk.com/555timer.htm#buffer
I read that if you don't have access to a test signal generator to calibrate it, you can always use the 50Hz from mains hum, which would be 3000RPM Smile
UnknownStuntm...
PostPosted: 19:24 - 23 Nov 2009    Post subject: Reply with quote
Excellent, I shall break the soldering iron out as soon as the ard turns up, you two are suitably rewarded for some inventive thinking.
Need to get 6 engines' rpms simultaneously, (well, maybe two engines, as they'll be arranged in two banks of three) and prepare some way of showing the data. It's for a power tool drag racing project you see... Very Happy
Syx
PostPosted: 17:17 - 24 Nov 2009    Post subject: Reply with quote
Such is the complexity of life - a simple description hides a much more involved project!
Best of luck with it Thumbs Up
PostPosted: 20:07 - 26 Nov 2009    Post subject: Re: Arduino geekery? Reply with quote
My Veypor and the aftermarket tacho on the SV650 race bike I did have both cut into the +ve to the coil (before not after).
Using one of those splicing style connectors.
UnknownStuntm...
PostPosted: 07:29 - 27 Nov 2009    Post subject: Reply with quote
Well, the engines have no way to get a LT signal out. It's a two stroke disc cutter, and they have a sealed ignition amplifier with a massive magnet to generate the spark. I think the only way I'd be able to pick up the signal would be to wrap a wire around the HT lead.
But anyway, something dawned on me yesterday, it's a single speed thing, so I can just use a bike computer sensor to get the speed of any of the wheels, it'll be directly linked to the rpm of all the motors...
Syx
PostPosted: 12:48 - 27 Nov 2009    Post subject: Reply with quote
Being single speed does make things much easier... although I'm not sure if the accuracy of a bike speedo is much to shout about!
UnknownStuntm...
PostPosted: 13:56 - 27 Nov 2009    Post subject: Reply with quote
just the sensor I'll be using, driving the arduino. It needs to manage the second stage of events you see. Smile
The last post was made 16 years, 308 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 66.88 Kb
