| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| Syx |
 Syx World Chat Champion
| UnknownStuntm... |
| Syx |
 Posted: 16:54 - 23 Nov 2009 Post subject: |
I seem to remember that some rev counters work by wrapping a "sensor wire" around the HT lead to induce a pulse - so that seems to be your option! I'd probably start out by doing that and passing it through a couple of filters then seeing what kind of pulse you get from it.
Edit: The filters you need will most likely be the same kind you get on voltage transformers, as they do the same thing (smooth out the "spikes"). Although I would guess you don't want to oversmooth as it is the spikes you'll be using!
Here's a similar project that includes a schematic: https://www.quasarelectronics.com/smart-kit/1143-digital-rpm-indicator.htm |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 18:29 - 23 Nov 2009 Post subject: |
I'd be tempted to try a 555 timer as a Schmitt trigger with, as Syx has mentioned, a few loops of wire wrapped around the HT lead. The 555 will then produce a clean (reversed) square wave which you should be able to count on the Arduino.
https://www.kpsec.freeuk.com/555timer.htm#buffer
I read that if you don't have access to a test signal generator to calibrate it, you can always use the 50Hz from mains hum, which would be 3000RPM  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| UnknownStuntm... |
 Posted: 19:24 - 23 Nov 2009 Post subject: |
Excellent, I shall break the soldering iron out as soon as the ard turns up, you two are suitably rewarded for some inventive thinking.
Need to get 6 engines' rpms simultaneously, (well, maybe two engines, as they'll be arranged in two banks of three) and prepare some way of showing the data. It's for a power tool drag racing project you see...  |
| Syx |
 Posted: 17:17 - 24 Nov 2009 Post subject: |
Such is the complexity of life - a simple description hides a much more involved project!
Best of luck with it  |
| G |
 G The Voice of Reason
| UnknownStuntm... |
| Syx |
| UnknownStuntm... |
 Posted: 13:56 - 27 Nov 2009 Post subject: |
just the sensor I'll be using, driving the arduino. It needs to manage the second stage of events you see.  |
The last post was made 16 years, 308 days ago. Instead of replying here, would creating a new thread be more useful? |
