| sirchopsalot |
 sirchopsalot Two Stroke Sniffer
 Posted: 23:57 - 25 Nov 2009 Post subject: dt 200 yamaha need help with wiring |
i got a 1986 dt 200 and can't figure out how to wire it.the harness has been cut up and i have no diagram to go off of.i am not going to run lights.the cdi box has 5 wires-blue,blue with a yellow stripe,light blue,brown,black.the ypvs controll box has 5 wires that i cam see that go in to the unit itself but it also has 3 that power it witch are-black with a yellow stripe,brown,black.also this bike had a battery does this power the ypvs controll box or did it just power the lights.the you have the magneto witch has 6 wires-white,yellow with a red stripe,black,brown,light blue,black with a red stripe.then it looks to me as there is a pulser on the outside of the magneto witch has 2 wires-white with a red stripe,white with a green stripe.last the is a volts regulator and that has 4 wires-yellow,red,black,red.really need help here.i am lost.thank you. |
| hmmmnz |
 hmmmnz Super Spammer
| sirchopsalot |
| rodeobob |
 rodeobob Two Stroke Sniffer
| sirchopsalot |
| hmmmnz |
| sirchopsalot |
| hmmmnz |
 Posted: 08:28 - 27 Nov 2009 Post subject: |
| sirchopsalot |
| sirchopsalot |
| sirchopsalot |
| hmmmnz |
 Posted: 20:55 - 28 Nov 2009 Post subject: |
ok that was just the colours from the diagram i used,
ill draw up the diagram with your colours,
the basic princapal is the same,
join the colours that match from the alternator to the reg/rec and from the reg rec to the cdi/battery from the cdi to the servo controllers
its pretty simple ..
give me a bit of time and ill do again ____________________ the humans are dead
I kick arse for the lord
| sirchopsalot |
| sirchopsalot |
| hmmmnz |
The last post was made 16 years, 283 days ago. Instead of replying here, would creating a new thread be more useful? |
