| hmmmnz |
 hmmmnz Super Spammer
| neatbik |
 neatbik World Chat Champion
 Posted: 12:06 - 01 Dec 2009 Post subject: |
Ducati  |
 Posted: 12:44 - 01 Dec 2009 Post subject: |
Rather than belt drive, Gear/bevel drive probably the ultimate I suppose. Kawasaki W650 and VFR750 spring to mind. Some Ducatis.
Knowing the Japs, if they ever made one with a belt drive, they'd put it in the middle of the engine just to be fucking difficult. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 12:48 - 01 Dec 2009 Post subject: |
Pushrods FTW  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
 Posted: 12:59 - 01 Dec 2009 Post subject: |
Trouble with gear and bevel drive is the cost of making it, and the difficulty with tolerances. Try skimming the head on a VFR.
But belts have a short life, especially on bikes (and become a pain to change when you start putting variable valve timing gubbins somewhere between the crank and cams). Personally I prefer cam chain drive as with a reasonably designed tensioner it is almost maintenance free.
Seen split link cam chains used in cars and lasting ages (150k+ miles).
| Kris |
 Kris World Chat Champion
 Posted: 13:09 - 01 Dec 2009 Post subject: |
My Pan European has one.
Suggested mileage between changes is 80-90k.
 ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| Rockhopper |
 Rockhopper Trackday Trickster
 Posted: 14:01 - 01 Dec 2009 Post subject: |
I still remain to be convinced that there is any good reason to put the camchain in the middle of a modern, water-cooled engine. Stick it on one end, then it would be a 10 minute job to change a camchain.
I refuse to believe it would put a massive off-centre stress on a solid metal cam which has more support (for its size) than the crank does
Yes the engine would be wider at the end but it would be narrower in the middle. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Charlie |
 Charlie World Chat Champion
 Posted: 14:10 - 01 Dec 2009 Post subject: |
Think the argument is that the cams need to be stronger and heavier to stop them twisting slightly along their length. However I tend to agree that would be a price worth paying for making them easy to change. Suspect noise might have something to do with it as well (ie, keep the noisy chain in the middle of the engine), and the ease of supporting the cam either side of the driven sprocket.
That said, no real reason why the cam chains themselves should be so short lived. Seems silly that one of the faults people had with the GPZ900R was that the cam chains only lasted about 20K, while some seem to regard that as an achievement these days. My old FZ is still on its first cam chain and tensioner at 68k.
The last post was made 16 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
