cam belts
hmmmnz
PostPosted: 12:04 - 01 Dec 2009    Post subject: cam belts Reply with quote
are there any bikes out there, bar the rotax lumps that use cam belts???
i really like the idea, especially on air cooled engines, it makes things very easy
the humans are dead
I kick arse for the lord
PostPosted: 12:06 - 01 Dec 2009    Post subject: Reply with quote
Most Ducatis use belts (all that I can think of for the last 20+ years).
neatbik
Ducati Thumbs Up
PostPosted: 12:13 - 01 Dec 2009    Post subject: Reply with quote
There are a few others. Think Gold Wings do. The Gilera singles from the late 80s / early 90s (eg, Nordwest) used belts as well. The small Moto Morini V twins used a short belt.
PostPosted: 12:44 - 01 Dec 2009    Post subject: Reply with quote
Rather than belt drive, Gear/bevel drive probably the ultimate I suppose. Kawasaki W650 and VFR750 spring to mind. Some Ducatis.
Knowing the Japs, if they ever made one with a belt drive, they'd put it in the middle of the engine just to be fucking difficult.
PostPosted: 12:48 - 01 Dec 2009    Post subject: Reply with quote
Pushrods FTW Thumbs Up
PostPosted: 12:59 - 01 Dec 2009    Post subject: Reply with quote
Trouble with gear and bevel drive is the cost of making it, and the difficulty with tolerances. Try skimming the head on a VFR.
But belts have a short life, especially on bikes (and become a pain to change when you start putting variable valve timing gubbins somewhere between the crank and cams). Personally I prefer cam chain drive as with a reasonably designed tensioner it is almost maintenance free.
Seen split link cam chains used in cars and lasting ages (150k+ miles).
PostPosted: 13:06 - 01 Dec 2009    Post subject: Reply with quote
You still need a drive for the cam, and that can easily be a chain or even a belt (the Morini V twins used a belt to drive a cam, and then push rods).
Kris
PostPosted: 13:09 - 01 Dec 2009    Post subject: Reply with quote
My Pan European has one.
Suggested mileage between changes is 80-90k.
Cool
www.prisonplanet.com
Rockhopper
PostPosted: 13:55 - 01 Dec 2009    Post subject: Reply with quote
And on the latest Ducati's you need some very gucci tools to change and tension the belts as they don't have timing marks any more.
PostPosted: 14:01 - 01 Dec 2009    Post subject: Reply with quote
I still remain to be convinced that there is any good reason to put the camchain in the middle of a modern, water-cooled engine. Stick it on one end, then it would be a 10 minute job to change a camchain.
I refuse to believe it would put a massive off-centre stress on a solid metal cam which has more support (for its size) than the crank does
Yes the engine would be wider at the end but it would be narrower in the middle.
Charlie
PostPosted: 14:10 - 01 Dec 2009    Post subject: Reply with quote
I still think it is because they purposely make it harder for the average Joe to service allowing the dealers to earn more money.
Think the argument is that the cams need to be stronger and heavier to stop them twisting slightly along their length. However I tend to agree that would be a price worth paying for making them easy to change. Suspect noise might have something to do with it as well (ie, keep the noisy chain in the middle of the engine), and the ease of supporting the cam either side of the driven sprocket.
That said, no real reason why the cam chains themselves should be so short lived. Seems silly that one of the faults people had with the GPZ900R was that the cam chains only lasted about 20K, while some seem to regard that as an achievement these days. My old FZ is still on its first cam chain and tensioner at 68k.
The last post was made 16 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 80.48 Kb
