vibrating, slight knocking???
lizard821000
PostPosted: 12:23 - 01 Dec 2009    Post subject: vibrating, slight knocking??? Reply with quote
1992 alcast jc20 ....just noticed this tonight.... i had a spare few hours earlier and after the sh*tty weather of late i decided to clean n mini service my bike... washed her all down.... cleaned the brakes with brake cleaner, lubed choke n throttle...toped up oils....etc. any way..... i took her out tonight and noticed a very faint vibrating ...or felt..... iv never felt this before, this seemed new. i am due a ring change, iv done 10 000 km s on the clock.... 6000 soming miles! my bike is nearly 19 years old so i was going to change the rings a little early than recomended, i cant see how it could av bin any thing i done earlier that day? lube cables and such!?? but what i did notice is a very,very,very slight weep , seems to be motor oil comin from the hole where the gear selector rod comes out of the crank case...and a little from the oil removal bolt too. im wounderin if that accient that happed the other week when 2 little sh*t c*nt pushed me bike over might have landed on the gear shaft and made a hair frackture or soming in the cranck case....i sertainly cant see a crack but thats a lot of weight to hit the gear shaft ay!!?? if iv bin loosing a little oil for weeks could this contribute to the vibratin im feeling??? i also noticed today, that iv never noticed befor that the manifold where the exhaust pipe meets the engine seems to be slightly ajar and not sit tightly parrallel , not split just ajar....with a gap of 5-6mm , dont know if this is new but could this also be the cause of the vibratin, if the combustion gas is leakin out before entering the pipe!!?? maybe the rings av just gone and im now gettin a little piston slap!?? dunno, the noise sounds like if you had a fan n held a piece of paper against it!!!! that sort of flappin noise...really faint though, n a faint vibration....? im gunna av a closer look at both tommorrow but any further help lads please, cherrs
yeah baby!!
PostPosted: 13:37 - 01 Dec 2009    Post subject: Reply with quote
That is so difficult to read Confused
lizard821000
PostPosted: 15:17 - 01 Dec 2009    Post subject: Reply with quote
i checked the exhaust n manifold and its solid so thats ruled out, that has always bin like that...... i took her for an hours fast run just now and still feelin this slight vibratin, best discribed as a flap noise say if your wearin a t-shirt on your bike and the wind flaps it rapid.... that noise but more mechanical obviously lol......... i did start noticing too that 1st n 2nd gear were gettin a little bit clunky to shift into and from...... i took a pick of the gear stem too, see the little drip comin off the point of entering the crank case...
yeah baby!!
Mark65
PostPosted: 16:02 - 01 Dec 2009    Post subject: Reply with quote
19 years?, possibly a worn oil seal.
Mark
lizard821000
PostPosted: 16:26 - 01 Dec 2009    Post subject: Reply with quote
this is what she sounds like..... alittle rough!!!
https://www.youtube.com/watch?v=F_ZaHLe6cb8
yeah baby!!
lizard821000
PostPosted: 02:50 - 02 Dec 2009    Post subject: Reply with quote
nearly 18 then lol....i know, my spellings shit boys, ill try harder miss . Dance! worried that i shouldnt really be riding her at all , i could be makin it worse!!?? ay! i also noticed towards the end of my ride today that my left foot when on the foot peg was shackin quite abit...or atleast enough for me to notice...which i never have befor!!?? all just seems a bit shakeier than normal....could the fall of knocked somin to do with the balance of my bottem end, aswell as maybe the slight leak too...hmm??? apreciate any help lads.... Thumbs Up
yeah baby!!
CaNsA
PostPosted: 11:02 - 02 Dec 2009    Post subject: Reply with quote
the......... <enter>......... key......... is......... alot......... better......... than....................................
or.........are.........you.........the.........slow.........reader.........in.........your.........class.........?
xXshadowXx
PostPosted: 11:48 - 02 Dec 2009    Post subject: Reply with quote
DUDE.
https://shadowgaming.com.au/images/Untitled.jpg
Click 1. Then 2. Then finally 3.
Intro, body, and conclusion. Sentence structure my friend.
About your bike; if there is one thing i've learned, it's that when you hear funny noises that weren't there before, then you shouldn't ride it til you know what it is.
The noise you're describing sounds like something, somewhere, is rubbing or impacting on something else. It could be inside the engine or a different part of the bike.
Does the speed of the sound increase/decrease with the revs of the engine or the speed you're travelling at? Does it sound metallic or plastic or something else?
lizard821000
PostPosted: 15:56 - 02 Dec 2009    Post subject: Reply with quote
it sounds like metal but muffled.... sort of grinding, but it just happened over night, not gradual. you see the vid? when reved , it gets worse..
yeah baby!!
lizard821000
PostPosted: 15:58 - 02 Dec 2009    Post subject: Reply with quote
dont mean to sound funny lads cos i apriciate the advise but is this a grammer forum or some think?? Shocked
yeah baby!!
unitybiker
PostPosted: 16:17 - 02 Dec 2009    Post subject: Reply with quote
the gbox oil seal looks goosed but can it be replaced without splitting the engine cases ?, a drip from the gbox drain plug could be a fkked washer or no washer at all (they get lost) check the chain and outer engine cases and make sure the tank rubbers are o.k this will help eleminate any spurious noises .
lizard821000
PostPosted: 16:59 - 02 Dec 2009    Post subject: Reply with quote
cherrs unitybiker, ill check it out ..... soon as this fkin rain stops!! Mad any other thoughts lads ?? bout the bike, not me fkin spelling.... i was gunna try harder .... but bite me. Cool
yeah baby!!
Carl_steveo
PostPosted: 17:07 - 02 Dec 2009    Post subject: Reply with quote
Is the sound/vibration constant? I have this problem at the minute and i've been given some advice off here about it. My bike fell over in the wind months back, when I went for a blast on it there were vibrations and a noise at about 5500 rpm. It stops this before and after 5500 rpm. I was told on here to check the airbox for a leak. The exhaust to see if its fitted properly and to check the engine mounts. All could have possibly come loose when it fell. I haven't checked these yet but it might be worth a look.
The gearbox oil!!! I have no idea about that!! lol
Current: Honda Nsr 125
Live: Sunderland
crackpotterpi...
PostPosted: 17:21 - 03 Dec 2009    Post subject: Reply with quote
check the exhaust thorughly,noticed a weird noise on mine last week was suspicious about the exhaust i took it off and a very small crack just after where it mounts to the head where the 2 halfs of the exhaust are welded together had split before the expansion chamber I could only see it when I held it up to the light looking down the pipe.I watched your video mine is 19 years old and sounds about the same as that!! lol
1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun
lizard821000
PostPosted: 19:20 - 03 Dec 2009    Post subject: Reply with quote
lol, cool mate. ill double check the pipe, i did notice some dents on the under side of the pipe, where i must av taken a sleepin policeman too quick.... Embarassed
yeah baby!!
The last post was made 16 years, 316 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 87.88 Kb
