Ali Welding
Damon
PostPosted: 19:34 - 03 Dec 2009    Post subject: Ali Welding Reply with quote
Hi all,
Does anyone here know where I could get my ali swingarm welded up. I have had a look on google etc but could only find info on TIG welding equipment, not companies that weld aluminium.
Thanks all, love cookies given Karma
hmmmnz
PostPosted: 19:44 - 03 Dec 2009    Post subject: Reply with quote
if you were in edinburgh i would tell you to go to pentland tech,
they are the best welders of anything i have ever come across,
they did my streetfighter subframe, my single sider milling and modding, they custom made 2 stainless link pipes for me out of a straight peice of stainless pipe, and you couldn't see the 37 welds it required when it was done.
vmaxdude will vouch for them as well, has they did his swing arm on his mz baggi, and loads of stuff for his vmax
the humans are dead
I kick arse for the lord
PostPosted: 20:05 - 03 Dec 2009    Post subject: Re: Ali Welding Reply with quote
Know someone around here that could no doubt do it, but not much help to you probably.
Probably best to ask in at local bike places, as they'll probably have someone they send stuff to.
Damon
PostPosted: 20:10 - 03 Dec 2009    Post subject: Reply with quote
cheers guys,
Have you got any contact details for above companies, I will ask if i can just box it up and post it over.
Thanks,
Damon
PostPosted: 20:20 - 03 Dec 2009    Post subject: Reply with quote
Can try and find out, but mine is a quite 'local' little place - bloke in a shed (with lots of big welders) kinda thing.
Have you looked at the price of second hand swing arms? May be as easy to get one rather than pay for postage twice as well as getting the work done.
Itchy
PostPosted: 20:22 - 03 Dec 2009    Post subject: Reply with quote
Why do you need it welded up? , just buy a new one!, It may well work out cheaper.
Swing arms are cheap, my CBR replacement was £20 IIRC , namely as G said to me once there is a low demand for swing arms because people who break them usually die in the process of breaking them.
Damon
PostPosted: 20:37 - 03 Dec 2009    Post subject: Reply with quote
It's not broken, It's me being a bit gay and wanting something a bit different. Its purely for looks. I want this
https://oldskoolsuzuki.info/uk_lee/Technical/swingarm.jpg
To be welded up to look heavily braced a bit like this...
https://farm3.static.flickr.com/2620/3725220172_276b908ab5.jpg
I am sending some bits to get powder coated (swingarm being one of them) so the idea is to weld up, smooth down and powder coat.
Neutral
Dibble
PostPosted: 20:42 - 03 Dec 2009    Post subject: Reply with quote
I work for a company supplying stuff to metal fabricators covering SE,SW and W postcodes so know most welders in those areas.
I can only think of one Coded Ali welder there near the New Den.
I have in the past asked them about getting brackets welded onto an ally frame when I was considering a CRM/CR hybrid.
The expert opinion was that it was a bad idea as the frame might be weakened (annealed?) and they weren't keen on the idea at all. There a lot of grades of Alu which react differently to heat and you can't tell which your swingarm is.
Bearing in mind the owner is a proper time served biker with experience in customizing bikes I took his word for it.
I'll PM you their number ,or ask the rep covering CR&SM if she knows anyone nearer if you want but I'd search the breakers if I was you.
PostPosted: 21:56 - 03 Dec 2009    Post subject: Reply with quote
Could look at some kind of glue - ie the sort Aeroplane wings are held on with etc Smile.
Or maybe tin foil?... seen some nice alloys done with this Wink.
Dibble
PostPosted: 22:16 - 03 Dec 2009    Post subject: Reply with quote
Yes glue will work I've been playing with "Structural Acrylic" for the aluminum Cafe racer tailpiece I'm planning.
It does heat up as it cures but not like tig welding so no risk of damage or distortion as it cools.
I'm not sure if it will take the heat in powdercoating but I'll check tomorrow, the data sheets in the car and it's cold.
Dibble
PostPosted: 17:53 - 04 Dec 2009    Post subject: Reply with quote
Structural Acrylic is fine between -40c and +120c but can tolerate higher temperatures briefly.
Now you just need to know what temperature they heat it too when powdercoating. Smile
temeluchus
PostPosted: 18:50 - 04 Dec 2009    Post subject: Reply with quote
200C according to wikipedia.
Damon
PostPosted: 18:57 - 04 Dec 2009    Post subject: Reply with quote
Thanks for the replies guys.
where can I pick up some of this "Structural Acrylic"?
arry
PostPosted: 19:30 - 04 Dec 2009    Post subject: Reply with quote
I know a bloody good alloy welder/fabricator in Sidcup if it's any good to you; he works mainly on custom american/classic cars - knocked up a winged sump, alloy rad and other goodies for a mate of mine
Damon
PostPosted: 19:34 - 04 Dec 2009    Post subject: Reply with quote
That would be brill, I have been looking at structial acrylic and it seems like I can only get large quantities for big money.
Thanks mate
Karma
Hetzer
PostPosted: 19:39 - 04 Dec 2009    Post subject: Reply with quote
Glue it with a Pritt-Stick, it's very cheap and bonds for a lifetime or your money back.
arry
PostPosted: 19:59 - 04 Dec 2009    Post subject: Reply with quote
Thanks mate
Karma
Just text my mate to get his number - hopefully he'll come back to me shortly Thumbs Up
BenR
PostPosted: 20:22 - 04 Dec 2009    Post subject: Reply with quote
https://www.harris-performance.com/ Thumbs Up
Damon
PostPosted: 20:46 - 04 Dec 2009    Post subject: Reply with quote
At over £3,000 it may be a bit out of my price range... Very Happy
They do look good though
arry
PostPosted: 09:14 - 14 Dec 2009    Post subject: Reply with quote
Sorry for delay DamOn - PM with his number incoming
DEN MONKEY
PostPosted: 09:31 - 14 Dec 2009    Post subject: Reply with quote
fiberglass maybe ?
meh
The last post was made 16 years, 318 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 109.73 Kb
