| Billing |
 Billing World Chat Champion
 Posted: 02:29 - 06 Dec 2009 Post subject: TZR Problem confirmation |
Hi guys, I'm having a little bit of a problem with my first TZR.
It's a cnut to start, even though the carb is clean and not sticking, and when it does start, it runs for a little while, but then cuts out and won't start for ages.
The gearbox oil is cloudy and white, but the coolant level isn't dropping, and the coolant is still bright orange in colour (as it was when I put it in. Could this be evidence that the cranks seal (s) have failed? if so I'll be ordering a set from Yamaha on wednesday when I'm up that way for my mod 1  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
BCF Eastern members map here ---> g.co/maps/2tm8b PM me to be added to it! |
| shadowbiker |
 shadowbiker Traffic Copper
| Billing |
| shadowbiker |
 Posted: 03:26 - 06 Dec 2009 Post subject: |
does it bump ok ?
could be rebuild time any photos of said problem ? also did you change the rings with the barrel and head ? also when was the oil last changed ? |
| Vincent |
 Vincent Banned
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 12:11 - 06 Dec 2009 Post subject: |
I`d start by checking that you do not have a problem with fuel starvation,(crap in the fuel lines)-remove the pipes from the carbs put the fuel tap on prime you should get plenty of fuel flowing.
clean all the jets with carb cleaner and a blast of air.
I`s unlikely to be ignition or rings\piston ware going on what you said.
after that I would be looking at more serious problems, the tzr`s tend to need a full rebuild after about 35-45000 miles ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| Billing |
 Posted: 14:34 - 06 Dec 2009 Post subject: |
I'll check the lines, and I'll (for the 9th time ) strip and clean the carb out.
It was fully rebuilt about 1000 miles ago, I know the bloke who did it. I then replaced the cylinder gasket less than 30 miles ago. I'll also change the gearbox oil and see if it clears the oil up ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Billing |
| Vincent |
 Vincent Banned
| Billing |
| Billing |
| Billing |
 Posted: 00:23 - 09 Dec 2009 Post subject: |
Right, tookthe plug out today after trying to start it, it reeks of petrol. I cleaned it up a bit (with a lighter because I didn't have a spare plug to hand) put it back in, and it fired up for about 10 seconds, then backfired and cut out.
Could it be running too rich and fouling plugs and killing them? I'm getting a new plug tomorrow, might try an Iridium as its about £2 more and it *supposedly* doesn't foul as easily as a regular one (copper core?)
The gearbox oil has taken over an hour to drain out, its almost pure white, and very thick. Could the waterpump seal have failed, causing the gooey mess, but not enough that a noticable amount of coolant is being lost?
Again, any help in getting this running is much appreciated ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Dr. DaveJPS |
 Dr. DaveJPS World Chat Champion
| Billing |
 Posted: 12:24 - 10 Dec 2009 Post subject: |
on the TZR its got a little shaft on the side that you pull out, it makes a little click and stays out (choke on) i know this because it was easier to start with the shaft out, but ran like shit until the shaft was in
I'm in the middle of tidying the house so will do the gearbox oil and a new plug as soon as im done. I'm also going to whip the filter out, from memory its got a twin layer DIY filter, so I'm wondering whether the density of that is altering the fuel air mix, because its too thick. if it seems to run better without a filter I'll get a proper Yammy one  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Billing |
 Posted: 22:22 - 11 Dec 2009 Post subject: |
Hi, Does anyone have a picture of a TZR125 powervalve setup? I can't figure out where things plug in
I've plugged the control box into the loom via the Black+Brown connector and Black/White (possibly yellow) bullet connector.
trouble is i have no idea where to plug the servo into or the other 5 wires on the control box.
Any help appreciated  ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| Billing |
 Posted: 14:49 - 13 Dec 2009 Post subject: |
| Kickstart wrote: | Hi
Just uploading a photo of the wiring diagram for a TZR125 2RH.
https://www.alfa-pages.co.uk/TempPicture/TZR125Wiring.jpg
On those the control unit is under the seat on the r/h side, on the side of the subframe, just back from the footrest hanger. The servo unit is on the inside of the main frame on the right, just above the barrel.
Keith |
Hi Keith,
Thanks for posting that, I had a look, and it appears that my first guess was correc,. the servo is plugged directly onto the controller.
I emailed the guy I bought it off, and he sent me the wiring diargram you posted, and an english version. He said it had come off a bike being broken for spares and he had seen it working. I assume that because my battery is fairly discharged it doesn't have enough power to do the startup thing (buzzes 3 times) ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
| ms51ves3 |
 ms51ves3 Super Spammer
| Billing |
 Posted: 16:39 - 13 Dec 2009 Post subject: |
It's a fairly new battery, I just haven't run the engine for long enough to charge it, I'll try borrowing a charger and hooking it up to that to check it's all good I'm busy stripping the carb down and giving it a proper thorough clean to see if, when combined with a new spark plug, it helps with the running problem ____________________ '84 TS50X, '91 TZR125, '89 CBR400RR, '91 VFR400R NC30, '98 R1
The last post was made 16 years, 248 days ago. Instead of replying here, would creating a new thread be more useful? |
