| Ariel Badger |
 Ariel Badger Super Spammer
| Clanger |
 Clanger Stirrer
| panrider_uk |
 panrider_uk World Chat Champion
| Ariel Badger |
| panrider_uk |
 Posted: 00:18 - 09 Dec 2009 Post subject: |
I've used Epson mainly but they do have a tendency to clog the heads if not in regular use.
I've just replaced my Epson R1800 (A3) with a Ricoh Gelsprinter G7000 (also A3). The Ricoh is much better in my option and as it has high capacity (70ml) catridges it does away with the need for a separate bulk ink system (dyesub cartidges for the Epsons are very expensive). It also uses gel ink which works under higher pressure and is less proe to clogging.
I think its worth spending the extra on A3 unless you know that you'll not be doing any larger format items in future - you can't press graphics wider than 11"(ish) with an A4 format printer.
Here's a link to the printer/ink page of one of my suppliers:
Click
Dyesub works by printing the graphic onto paper (dyesub paper releases more ink on heating than normal paper) and then transferring it to a substrate using heat and pressure.
The ink is a special type that sublimates at around 170C.
The substrate you press onto needs to be designed for dyesub or have a high polyester content.
For best results you would use a heat press rather than a domestic iron to transfer the image.
The press I use is a 16" flatbed clamshell type which is suitable for most things up to A3 in size. You can get special presses for mugs, plates and caps. I don't do plates or caps and use a mug oven and wraparound clamps for mugs.
The ink sublimates into the substrate and so will not scratch or wash off.
Mark ____________________ Current bikes: Honda ST1100 Pan European. Moto Guzzi V85 TT Travel |
| Ariel Badger |
| panrider_uk |
The last post was made 16 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
