Tell me about dye sublimation printing
Ariel Badger
PostPosted: 23:38 - 07 Dec 2009    Post subject: Tell me about dye sublimation printing Reply with quote
I have been given money to spend on a dye sub printer.
I need recommendations/pointers/experiences to help me choose on what to buy.
Can the BCF massive help please?
Thanks in advance
Wali T
Clanger
Stirrer
PostPosted: 10:59 - 08 Dec 2009    Post subject: Reply with quote
https://en.wikipedia.org/wiki/Dye-sublimation_printer
panrider_uk
PostPosted: 13:02 - 08 Dec 2009    Post subject: Reply with quote
Wali
Is it for normal printing or dye-sub printing onto t-shirts, mugs etc?
Mark
Ariel Badger
PostPosted: 00:00 - 09 Dec 2009    Post subject: Reply with quote
panrider_uk wrote:
Wali
Mark
Yes, it is for use within school for shirts, cups etc, etc, we would be using it for textiles and graphics products but it could spread wider across the curriculum but that is my intended use.
Tell me what you know please!
panrider_uk
PostPosted: 00:18 - 09 Dec 2009    Post subject: Reply with quote
I've used Epson mainly but they do have a tendency to clog the heads if not in regular use.
I've just replaced my Epson R1800 (A3) with a Ricoh Gelsprinter G7000 (also A3). The Ricoh is much better in my option and as it has high capacity (70ml) catridges it does away with the need for a separate bulk ink system (dyesub cartidges for the Epsons are very expensive). It also uses gel ink which works under higher pressure and is less proe to clogging.
I think its worth spending the extra on A3 unless you know that you'll not be doing any larger format items in future - you can't press graphics wider than 11"(ish) with an A4 format printer.
Here's a link to the printer/ink page of one of my suppliers:
Click
Dyesub works by printing the graphic onto paper (dyesub paper releases more ink on heating than normal paper) and then transferring it to a substrate using heat and pressure.
The ink is a special type that sublimates at around 170C.
The substrate you press onto needs to be designed for dyesub or have a high polyester content.
For best results you would use a heat press rather than a domestic iron to transfer the image.
The press I use is a 16" flatbed clamshell type which is suitable for most things up to A3 in size. You can get special presses for mugs, plates and caps. I don't do plates or caps and use a mug oven and wraparound clamps for mugs.
The ink sublimates into the substrate and so will not scratch or wash off.
Mark
Ariel Badger
PostPosted: 00:35 - 09 Dec 2009    Post subject: Reply with quote
Could you Pm me a phone number and a conveniant time for a chat please?
panrider_uk
PostPosted: 00:47 - 09 Dec 2009    Post subject: Reply with quote
PM sent
Mark
The last post was made 16 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.61 - MySQL Queries: 15 - Page Size: 52.82 Kb
