IS THIS A STOOPID QUESTION? are cranks interchangeable?
stirlinggaz
PostPosted: 18:57 - 08 Dec 2009    Post subject: IS THIS A STOOPID QUESTION? are cranks interchangeable? Reply with quote
right this is the 3rd time i have tried to post this,~
the long & short of it is : my mate has a knackerd trail bike & fancies a hoon around the local tracks.(with me on my mtx)
problem is his bikes fucked.
con rod is looking mashed up at the point where bits are pressed together..
i could send it for a con rod renewal, but tbh, the rest of the crank is in a bad way. the tapers all gouged & scored (presumably from when the woodruff key sheared off.
heres the solution i have come up with.
i have a bottom end off the exact same bike in the shed!
the con rod is good, so are the main bearings & crank.
would it be possible to transplant the the bits from my old bottom end (as its in bits, lol) into his knackered bottom end,
then use his decent top end.
would this be doable for an amatuer like me?
bearing in in mind i have restored a few bikes, done a few top end rebuilds but have have never really touched a crank or con rod.
any suggestions?
cheers,
GAZ
finpos
PostPosted: 19:49 - 08 Dec 2009    Post subject: Reply with quote
Can be done, but putting a load of worn parts into a differently worn engine generally doesn't get you a lot of long-time reliability. And that's if both the engines were in half decent condition in the first place!
Raffles
PostPosted: 19:57 - 08 Dec 2009    Post subject: Reply with quote
If the bits that you are transplanting are in good nick then go for it. It's only the same as buying an exchange item from a dealer.
Frost
PostPosted: 20:27 - 08 Dec 2009    Post subject: Reply with quote
Provided you put the crack and rod in as a unit it's definately do-able by someone with enough tools to open up an engine Thumbs Up
As others have said your mates engine probably has worn bearings where the crank sits, so changing these would be inexpensive and a bloody good idea.
PostPosted: 01:31 - 09 Dec 2009    Post subject: Reply with quote
Pretty simple. Pretty much a case of split the engine, lift old crank out, drop new crank in.
Obviously you'd need to remove whatever is on either end of the crank too which can be more or less complex depending on the model.
As said, might be a good time to renew the main bearings. Also fit new crank seals (assuming it's a stroker).
Look at it this way. You currently have two fucked engines. If you make an almighty arse of the job, at the end of the day, you would still have two fucked engines.
stirlinggaz
PostPosted: 07:05 - 09 Dec 2009    Post subject: Reply with quote
hi,
thanks thats exactly what i want to hear!
if it is a case of just swapping one crank for another, then im sorted.( i think)
i've got nothing to lose, as both bottom ends are fucked anyway.
as said before, main bearimgs LOOK good, but if they do have to come off + be replaced, i presume im gonna have to get my hands on a special kind of bearing puller/slide hammer? (or bribe someone who owns one, lol)
cheers,
GAZ
hmmmnz
PostPosted: 07:56 - 09 Dec 2009    Post subject: Reply with quote
check the new crank for up and down play with the con road, if there is no movement then go for gold,
if there is movement then you need to get the crank pressed apart,
and then you'll need a new crank pin and big end bearing,
normally you'd do the whole sh' bang annd normally when you buy a conrod kit you get the crank pin, big end bearing and the conrod,
you'll also have to get everything pressed back together and balanced, just a little bit out and she'll vibrate herself to bits,
ive done it all by hand before, with just a drift and a hammer,
then a couple of bits of wood and a nail to balance.
that isn't recommended, and the bike was in a very low state of tune,
the humans are dead
I kick arse for the lord
stirlinggaz
PostPosted: 11:13 - 09 Dec 2009    Post subject: Reply with quote
hi,
not sure if im following you. (forgive my ignorance)
the conrod (on the damaged one) moves freely.
i can move it round/though the weights.
but its grinding at the part where bits are pressed together.
so in an ideal crank + con rod, what sort of movement should there be?
i dont have any sideways movement, well no more than a mil or 2.
cheers,
GAZ
hmmmnz
PostPosted: 21:52 - 09 Dec 2009    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
the damaged one moves freely?? is it notchy when you rotate the conrod on the crank pin? (keep crank in one place, then rotae the conrod around the crank pin, there should be nolittle bumps or notches)
it shouldnt grind anywhere, although you should have to bent washers (thrust washers) that are between the conrod and the crank, on the same crank pin
these hold the conrod centered on the bearing/crank pin
ideally there should be no movement around the pin at all,
sideways movement is fine, there should be no grinding or any resistance as you spin the conrod,
if there is even the tiniest amount of sloppiness or grinding, then at high revs it'll be far worse, and you'll grind and shake things to bits.
if the crank in your other bike was known to be ok and running,
then give it a quick check over and slap it in,
its only a couple of hours work,. and as said.. you'll be no worse off Very Happy
the humans are dead
stirlinggaz
PostPosted: 14:29 - 10 Dec 2009    Post subject: another stoopid questionright,, Reply with quote
right,
looked at the replacement crank.
looks fine to me, but im no expert, lol
why do i have to replace the main bearings?
they look good, no grinding & no debris in there.
i know the bearings are only a tenner each but im gonna have to pay someone to remove them (or cut them off) & pay someone to put the new ones on.
why cant i just slap it in, replace the seals & hope for the best?
its a 20yr old engine, will it matter?
ps just realised the crank in the mtx125 engine is identical to the crank in the mtx200!
cheers,
GAZ
Theoutsider
PostPosted: 14:39 - 10 Dec 2009    Post subject: Re: another stoopid questionright,, Reply with quote
stirlinggaz wrote:
right,
cheers,
GAZ
Bearings are bearings,if the engine is opened it`s worth changing them,they might look good but you cannot actually see.Also you can replace the bearings ,it ain`t that hard ,I can usually take them out with a flat screwdriver and a hammer,and also when you put the new ones in be careful not to hammer them it,with a piece of wood and a lot of grease will do the trick Thumbs Up
The last post was made 16 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 72.89 Kb
