| markrolls88 |
 markrolls88 Renault 5 Driver
 Posted: 23:10 - 30 Nov 2009 Post subject: honda cg125 sump plug |
i have a honda cg 125 i have only had it 3 month and is due an oil change but my sump plug bolt is rounded i have bought a spare sump plug bolt for when i finally get this one off but i cant work out how to get it off i have tryed a correct size spanner a correct size socket a monkey wrench but have had no luck can someone help me please  ____________________ sparky |
| temeluchus |
| Alexio |
 Alexio World Chat Champion
 Posted: 00:29 - 01 Dec 2009 Post subject: |
Extreme heat or cold (within reason), a big hammer and you could even try cutting in to the sump plug to make those corners not rounded any more. then again, it's probably stupid to take my advice on this matter at this time in the morning. ____________________ will never give up his CG. I look at my fuel gauge more as a progress bar than a fuel gauge.
ms51ves3: why does it need 500 miles? Are you teaching it how to be a piston? |
| neil. |
 neil. World Chat Champion
 Posted: 07:19 - 01 Dec 2009 Post subject: |
Mole grips? Or you can cut a notch through it with a Dremel and try a big flat blade screwdriver? Stud extractor? If you're not using a torque wrench, be careful when you tighten up the new plug - it's really quite easy to over-tighten and ruin the thread on the sump. Replace the washer as well or else you might get a bit of leakage.  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| Darth |
 Darth World Chat Champion
 Posted: 08:06 - 01 Dec 2009 Post subject: |
Cant rate these things high enough for removing rounded bolts and nuts. Depends on the size though - sump plug might be a bit on the large side. ____________________ Harold_Shand wrote: I suppose it's like anything, you get your fingers burned when you start out, you learn from it and eventually become a complete arsehole about the whole thing. |
| Jamie S |
 Jamie S World Chat Champion
| unitybiker |
 unitybiker Nova Slayer
| unitybiker |
| markrolls88 |
| 27cows |
 27cows World Chat Champion
| Vincent |
 Vincent Banned
 Posted: 11:38 - 12 Dec 2009 Post subject: |
I'd be careful going anywhere near the sump with a hammer, it's cast ally I'd imagine, and will crack if you even look at it too hard  |
| TUG |
 TUG World Chat Champion
The last post was made 16 years, 320 days ago. Instead of replying here, would creating a new thread be more useful? |
