Hesitant and spluttering at full throttle.
Jrod
Page 3 Girl
PostPosted: 17:36 - 12 Dec 2009    Post subject: Hesitant and spluttering at full throttle. Reply with quote
1985 XR600.
When full throttle it is fine until youve had it pinned a while and its reaching highish speed (70ish)
Starts to splutter a bit and will get worse if you keep it pinned. When this happens it also pops and bangs when you back off the throttle for a few seconds and will stall if you pull the clutch in. Carry on riding at part throttle and it clears very quickly.
Brand new coil, cap and spark plug fitted. Also fitted new original sized jets today wich made it better but didnt cure it. (went from 148's to 122's!)
finpos
PostPosted: 17:43 - 12 Dec 2009    Post subject: Reply with quote
Sounds rather like it's not getting quite enough fuel at wide open throttle and it's leaning out the mixture. On a bike that age first thing to suspect is the fuel filter is full of snot. It'll probably be in the fuel tap, somewhere.
f.
Jrod
Page 3 Girl
PostPosted: 17:49 - 12 Dec 2009    Post subject: Reply with quote
The tap was taken off and cleaned as was the tank. Carbs have been fully stripped and cleaned aswell.
oldbiker
PostPosted: 17:56 - 12 Dec 2009    Post subject: Reply with quote
Check the spark plug for any grey deposits on the centre insulator this would indicate that the timing was a little advanced,
Erosion or burning of the centre electrode would suggest that it was running a little weak on the mixture (try lifting the carb needle a notch or two).
very dark brown or wetness would suggest that it was running over rich (Lower the carb needle a notch or two)
And as the last post says check that the tank, float bowl and fuel lines are not full of snot.
is it possable that you may have altered that height of the float when you replaced the jets?
It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg
Alexio
PostPosted: 18:20 - 12 Dec 2009    Post subject: Reply with quote
Air filter?
Jrod
Page 3 Girl
PostPosted: 18:28 - 12 Dec 2009    Post subject: Reply with quote
New air filter. No i didnt touch the float levels when the jets were changed (as you don't need to take the carbs apart to swap jets, just 2 little access holes in the bottom)
Would the wrong float levels cause something along these lines as I've not checked them.
Shreddie
PostPosted: 19:05 - 12 Dec 2009    Post subject: Reply with quote
It's possible, yes.
oldbiker
PostPosted: 19:08 - 12 Dec 2009    Post subject: Reply with quote
the sort of symptoms that you describe ( back fires, hesitant power when you drop the throttle) point towards the engine being very hot.
the most common causes are; timing being over advanced or wrong fuel \ air ratio,
if timing is ok, jets are correct (no engine or exhaust mods),
you are looking at something reducing the amount of fuel in the float bowl. could be crap in the tank, fuel lines, float bowl.
what was the last thing that you did to the bike before this started? and what was the problem that you were trying to solve then? that is what you must sort out.
the point about the air filter previously mentioned. If the air filter was clogged or replaced with a piece of card it would only make the bike slower, if the air filter was removed it would be unlikely to cause such obvious problems though it would make the engine run hotter.
is it possible that you may have an air leak somewhare between the carb and carb mounting?
finpos
PostPosted: 13:16 - 13 Dec 2009    Post subject: Reply with quote
Have you checked you're getting decent enough flow of petrol out of the fuel line; should be pouring out. Check it with the fuel cap on and if is slows down after a while, take cap off (i.e. check the breather isn't blocked).
f.
Jrod
Page 3 Girl
PostPosted: 00:31 - 14 Dec 2009    Post subject: Reply with quote
f.
It flows totally fine cap on or off.
Its done it since I bought it.
I'll look into some of the other bits mentioned above and update soon. Smile
temeluchus
PostPosted: 01:58 - 14 Dec 2009    Post subject: Reply with quote
if its got a loud pipe it will need jetting.
Jrod
Page 3 Girl
PostPosted: 18:40 - 14 Dec 2009    Post subject: Reply with quote
It has and it was jetted to suit (136 instead of 122.) I then went up to 148 and it was the same, now gone back to original 122s and its better but still there.
temeluchus
PostPosted: 19:29 - 14 Dec 2009    Post subject: Reply with quote
try lowering your float height, make sure its getting what it needs top end.
Jrod
Page 3 Girl
PostPosted: 23:18 - 14 Dec 2009    Post subject: Reply with quote
The floats is my next step I tink as I've not touched these so they could well be wrong. The standard exhaust is also going back on as soon as I weld a small patch on.
prawny1
PostPosted: 23:45 - 14 Dec 2009    Post subject: Reply with quote
Does the xr have a cv type carb?
if it does check the needle slide diaphragm for splits etc, A very small split might not cause running trouble until your at full throttle/ high speed.
Dustproof
PostPosted: 07:34 - 15 Dec 2009    Post subject: Reply with quote
It sounds to me like the ignition is breaking down, replace the plugs if you haven't already. If this doesn't fix, it could be a coil breaking down. If it is arching to earth have a look at night and see if there are any electricity arching, if there is ANY sign of it replace the faulty coil.
GSX1400 - Just like a magic carpet ride with a Rocket up it's arse
Jrod
Page 3 Girl
PostPosted: 18:19 - 15 Dec 2009    Post subject: Reply with quote
temeluchus
PostPosted: 19:50 - 15 Dec 2009    Post subject: Reply with quote
this usually manifests itself as a lack of power on a single carb bike.
Jrod
Page 3 Girl
PostPosted: 20:57 - 15 Dec 2009    Post subject: Reply with quote
Its twin carbs
It doesn't do it when not under load.
temeluchus
PostPosted: 21:18 - 15 Dec 2009    Post subject: Reply with quote
ah you have the twin carb head.
Not under load-almost certainly float height.
The last post was made 16 years, 202 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.87 - MySQL Queries: 13 - Page Size: 110.28 Kb
