| Jrod |
 Jrod Page 3 Girl
| finpos |
 finpos World Chat Champion
| Jrod |
 Jrod Page 3 Girl
| oldbiker |
 oldbiker Nitrous Nuisance
 Posted: 17:56 - 12 Dec 2009 Post subject: |
Check the spark plug for any grey deposits on the centre insulator this would indicate that the timing was a little advanced,
Erosion or burning of the centre electrode would suggest that it was running a little weak on the mixture (try lifting the carb needle a notch or two).
very dark brown or wetness would suggest that it was running over rich (Lower the carb needle a notch or two)
And as the last post says check that the tank, float bowl and fuel lines are not full of snot.
is it possable that you may have altered that height of the float when you replaced the jets? ____________________ It`s all powerfull white mans magic
https://i897.photobucket.com/albums/ac178/tzrsteve/album%201/035.jpg |
| Alexio |
 Alexio World Chat Champion
| Jrod |
 Jrod Page 3 Girl
| Shreddie |
 Shreddie Spanner Monkey
| oldbiker |
 Posted: 19:08 - 12 Dec 2009 Post subject: |
the sort of symptoms that you describe ( back fires, hesitant power when you drop the throttle) point towards the engine being very hot.
the most common causes are; timing being over advanced or wrong fuel \ air ratio,
if timing is ok, jets are correct (no engine or exhaust mods),
you are looking at something reducing the amount of fuel in the float bowl. could be crap in the tank, fuel lines, float bowl.
what was the last thing that you did to the bike before this started? and what was the problem that you were trying to solve then? that is what you must sort out.
the point about the air filter previously mentioned. If the air filter was clogged or replaced with a piece of card it would only make the bike slower, if the air filter was removed it would be unlikely to cause such obvious problems though it would make the engine run hotter.
is it possible that you may have an air leak somewhare between the carb and carb mounting? ____________________ It`s all powerfull white mans magic
| finpos |
| Jrod |
 Jrod Page 3 Girl
| temeluchus |
| Jrod |
 Jrod Page 3 Girl
| temeluchus |
| Jrod |
 Jrod Page 3 Girl
| prawny1 |
 prawny1 World Chat Champion
| Dustproof |
 Dustproof L Plate Warrior
| Jrod |
 Jrod Page 3 Girl
| temeluchus |
| Vincent |
 Vincent Banned
| Jrod |
 Jrod Page 3 Girl
| temeluchus |
The last post was made 16 years, 203 days ago. Instead of replying here, would creating a new thread be more useful? |
