Rebuild
Hennie
PostPosted: 11:40 - 12 Dec 2009    Post subject: Rebuild Reply with quote
I have taken apart my VFR 400 NC30 motor but now i would like to know what type of oil or lubrication i should use when putting back the bearings Confused can any one help
steven_191
PostPosted: 11:54 - 12 Dec 2009    Post subject: Reply with quote
standard engine oil will do
Hennie
PostPosted: 19:06 - 12 Dec 2009    Post subject: Reply with quote
Thanks Smile i did start this afternoon made a quick phone call, do you know of anything that i should be aware of when putting the bike back together?
spitfire123
PostPosted: 19:14 - 12 Dec 2009    Post subject: Reply with quote
amke sure you no what pistons came out of were etc...
You won't be able to eat my dust......As it'll settle before you get there.
Hennie
PostPosted: 19:33 - 12 Dec 2009    Post subject: Reply with quote
I do have the manual but it does not say what piston should go where only that the inn part on top of the piston should point to the carburator ? how will i then know what goes where? Embarassed
Jamie S
PostPosted: 19:30 - 13 Dec 2009    Post subject: Reply with quote
Make sure all gasket faces are clean and flat, use a blunt plastic scraper, and some 400 wet and dry to remove bits of old gaskets.
colin_397
PostPosted: 22:04 - 13 Dec 2009    Post subject: Reply with quote
i was lookin at a hrc manual today regarding the rebuild of a cbr 600 engine and it suggested moly grease mixed with engine oil as the assembly lube. So thats what we did, it will be a bit more sticky than just the oil on its own, so it should still be on there when you get around to starting it.
Hennie
PostPosted: 18:23 - 14 Dec 2009    Post subject: Reply with quote
Thank you for all your advice it helped a lot, but now i am stuck the rocker arm on the one side is broken (bought the bike like that never saw it) and i have only noticed it now Evil or Very Mad does those rocker arms brake easily or under a lot of strain?
The last post was made 16 years, 206 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.04 - MySQL Queries: 13 - Page Size: 53.53 Kb
