Brighter headlight
PostPosted: 16:42 - 15 Dec 2009    Post subject: Brighter headlight Reply with quote
Hey,
On my 1993 GS500 the headlight is very VERY dim at night.
Full beam is about as good as sidelight, and main light is a candle..
Whats the options for installing brighter lights with minor modding as I have an aftermarket fairing, meaning twin headlights = no no Sad
Just the standard round headlight...any ideas guys?
Raffles
PostPosted: 16:48 - 15 Dec 2009    Post subject: Reply with quote
What bulb is installed at present?
PostPosted: 17:05 - 15 Dec 2009    Post subject: Reply with quote
probably one from 1935...
i will whip the cover off and take it out.
Basically im going to be using it, dont really want to have to take that fairing off, to put it back on, to take off again after i get the bulb etc.
I will try whipping it off, but it is very closed in with that fairing.
Any basic bright bulb that will 100% fit?
Sorry, i just figure the least work to get it on the road the better... personally i would like bulbs like this
https://dr650.zenseeker.net/Conspicuity/HeadlightCompare.jpg
Currently mine is worse than the one on the right!
salty21
PostPosted: 17:08 - 15 Dec 2009    Post subject: Reply with quote
h.i.d's, this time of year it's the best mod you can do, absolutely love mine Thumbs Up
the power consumption is less than a normal bulb aswell Thumbs Up
PostPosted: 17:13 - 15 Dec 2009    Post subject: Reply with quote
is that a simple conversion?
Basically will get a decent photo of the SHOCKING wiring on my bike.
As long as it isnt terribly difficult will HID them!
LeeR
PostPosted: 20:26 - 15 Dec 2009    Post subject: Reply with quote
The quickest and cheapest option is to fit a Halfords H4 Extreme Brilliance bulb (upto 90% brighter) @ £19.99 currently on offer BOGOF so you'll get a spare. Thumbs Up
Don't buy the motorbike one, it's not on offer and is the same bulb.
My claim to fame: Austin Vince nicked my pen...
PostPosted: 22:11 - 15 Dec 2009    Post subject: Reply with quote
if that will definitely fit standard...then im VERY happy!!
CptBlack
PostPosted: 22:41 - 15 Dec 2009    Post subject: Reply with quote
I think I might nip over in the morning and pick one up. I've looked in my manual, it only says 12V 35/35W as the spec, nothing about a H4 fitting. Does anyone know it definitely wont work or will pop (Hyosung Cruise II - 125cc)
If not, I'll try it and let you know. I really need some extra light on the roads at the mo!
Chris
PostPosted: 23:02 - 15 Dec 2009    Post subject: Reply with quote
They won't work in your bike. You have a tungsten fillament bulb of a totally different type. They won't pop but they could well melt your wiring.
I wonder if there is something wrong with the headlight or its wiring? As far as I know a GS500 takes a standard H4 halogen bulb which ought to make it as bright as a single car headlamp. Whilst not absolutely amazing, a standard, round headlamp like that ought to be at least adequate. It's the same as is fitted to the majority of motorcycles.
Your description leads me to suspect everything is not as it should be. As such, fitting a super-duper mega-bulb may not work as well as you'd hope.
I'd be checking the bulb is intact and that all the contacts are good and clean. Maybe also worth checking the battery voltage? Also check the reflector is rust free and there isn't a load of dirt on the inside of the lens. Also check the switches and the relay (if fitted) and make sure they headlight has a good earth connection.
CptBlack
PostPosted: 23:07 - 15 Dec 2009    Post subject: Reply with quote
Cheers for the heads up - will keep looking.
Chris
PostPosted: 23:13 - 15 Dec 2009    Post subject: Reply with quote
Cheers stinkwheel,
Well the wiring is a total mess but its definitely a clean connection.
All the switches work fine, the lens is pretty much spot on.
The thing is the bulb looks quite old.. you know you see a new one then look at this one, its looking VERY tired.
Im up for trying a new bulb, this one does seem very dim for what it should be, especially at night. Even on full beam i cant see too far ahead, where as on my old Hyosung GT125 it was very very clear, same commute, same darkness/roads and I really lack visibility.
Worth trying a bulb, i mean even if i go buy it, fit it and its still the same, it will then urge me into checking everything over.
Battery should be fine, its pretty new, mid November, bikes started every 2 or 3 days and ridden hard for about 20 mins..obviously not ideal, but in this weather i prefer the car...having a cracked windscreen on the other hand makes that difficult..hence needed a headlight Smile
Raffles
PostPosted: 07:58 - 16 Dec 2009    Post subject: Reply with quote
One of these may be the answer:-
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=300350873883&ssPageName=STRK:MEWAX:IT
Do be aware though that if you have a plastic lens or reflector this bulb could melt or distort them due to the extreme heat that it emits.
Mark65
PostPosted: 08:45 - 16 Dec 2009    Post subject: Reply with quote
Do be aware though that if you have a plastic lens or reflector this bulb could melt or distort them due to the extreme heat that it emits.[/quote]
I have put one of those in my YBR about 5 months ago, a lot brighter than the standard bulb, good cheap upgrade, mine was packaged by Ring about £6, very bright to look at and throws a bit more light on the road compared to the OEM bulb.
Mark
Robby
Dirty Old Man
PostPosted: 14:08 - 16 Dec 2009    Post subject: Reply with quote
GS500 I understand has a normal looking big round chrome headlight. In all the bikes I've owned, I've always like them best. You should have no problems with it using a standard bulb.
So, possible causes:
1. The bulb needs replacing. You could buy a normal one or a special one, a normal one will be a fiver. I don't like the clever super duper 20 quid blue light headlight bulbs, they claim more light but I always just seem to get whiter light in bits, and more shadow. Yellower light is easier on the eyes at night.
2. The battery is knackered. Is the electric start having a hard time, or do some of the lights dim when you brake or indicate? Does this problem go away when you rev it?
3. Corrosion in a connector. Check the connector blocks for corrosion on the terminals, which can make a difference. I don't know if your lights wiring returns to the battery, or earths through the frame. It's worth checking any earth connections on the frame for rust.
PostPosted: 14:59 - 16 Dec 2009    Post subject: Reply with quote
I will definitely try a new bulb, no matter, as I can really see shit all Sad
Battery is under a month old and kept charged, doesnt have a problem starting electrical wise, always enough juice.
The connections are terrible in design, someone has rewired the damn thing! But im up for trying a new bulb first.
If that shows as the same will do a straight wire to where its meant to be rather than the mixed up shit at the moment.
Thats the headlight
https://www.jacaremoto.com.br/noticias/fotos/gs500e08_azul_md.jpg
Shreddie
PostPosted: 22:48 - 16 Dec 2009    Post subject: Reply with quote
Back when I was on my GT550 and doing alot of riding in the dark, I fitted one of those Phillips xenon bulbs (possibly one of those blue vision things), the improvement over the standard headlight was fantastic.
Later, I also got a little pair of 55w spots from a car place and fitted those to my crashbars. They were wired to my main beam via a relay. Those were great and allowed me to see a great deal further. They were also handy when I came across those dickhead car drivers who think that they don't need to dip their lights for motorbikes... I never needed to give them more than a quick flash.
serlant
PostPosted: 07:09 - 18 Dec 2009    Post subject: Reply with quote
Seems good, Will it fit my 1990 XJ600? its got a H4 12V 60/55w, are all H4's interchangable?
Raffles
PostPosted: 08:57 - 18 Dec 2009    Post subject: Reply with quote
All H4 bulbs should be a standard size. Provided that the wattage is the same as the original bulb then there should not be any wiring issues. Go for it.
Shreddie
PostPosted: 09:03 - 18 Dec 2009    Post subject: Reply with quote
Yes and no. A H4 of any wattage will plug straight into a H4 connector but high wattage bulbs can fry wiring and/or blow fuses. 60/55w should be fine in most bikes though. I wouldn't want to fit a higher wattage than that without a relay and auxillary wiring.
As a general rule of thumb you can gauge how high a wattage you can fit from the headlight fuse rating (as long as it's the standard fuse in there, check your manual). Multiply the amperage of the fuse by the voltage of your electrical system, Amps X Volts = Watts... For example, if you have a 5 amp fuse and your electrical system is 12v... 5x12=60 so dont fit a bulb higher that 55/60w. For twin headlight systems you need to divide the wattage by two, so if you have a fuse of 10amps and 12v electrical system... 10x12=120w... divided by two thats 60watts again so don't fit higher that a 55/60w bulb into each headlight. Just be carful if you have plastic reflectors and/or lenses because bulbs with a higher wattage than standard might put out enough heat to melt them.
Xenon bulbs have a higher light output (around 30% brighter I think) than a standard halogen bulb of the same wattage so go for Xenon wherever you can.
serlant
PostPosted: 09:21 - 18 Dec 2009    Post subject: Reply with quote
Manual says Headlight is a 20A for the headlight, and i looked in the bike has a 20A, manual says 60/55w for headlight 5/21w for stop/tail light, has a 60/55 in the headlight and 2x 5/21W in the tail light.
LeeR
PostPosted: 09:26 - 18 Dec 2009    Post subject: Reply with quote
The Halfords bulb is a 12V 60/55W so yes it's the correct bulb for your bike, I've got two fitted to my V-Strom and they are significantly brighter than the stock bulb and the Super Brilliance (50% brighter) bulbs I replaced them with.
tsmith
PostPosted: 09:45 - 18 Dec 2009    Post subject: Reply with quote
fit an Osram Nightbreaker and aim it up slightly. This made a massive difference on my GPZ500 (H4 bulb 55/60w)
don't aim it up too much or you will dazzle car drivers. you can get the alignment right by placing the bike on a level surface about 10m away from a door or a wall and make the adjustments whilst the bulb is on dipped and the engine is running (otherwise you will kill the battery)
PostPosted: 10:28 - 18 Dec 2009    Post subject: Reply with quote
Also the legal limit for anything newer than about 25 years old.
The last post was made 16 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.86 - MySQL Queries: 13 - Page Size: 127.16 Kb
