kettlemeths prob ... ?
cvntdude This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Darth
PostPosted: 21:56 - 16 Dec 2009    Post subject: Reply with quote
Bin it. Its hideous anyway Thumbs Up
GhostRider
PostPosted: 00:50 - 17 Dec 2009    Post subject: Reply with quote
I probably wouldn't try using it, if you o
blind you'll know there was some residue remaining.
GhostRider
PostPosted: 01:44 - 17 Dec 2009    Post subject: Reply with quote
Fill it with a pint of cheap vinegar (around 45p for tesco value stuff) and boil it a few times. Then rinse it out and boil it with a couple of fills of clean water. It'll be like brand new.
I do this with the girlfriends kettle about once a month to descale it.
Shreddie
PostPosted: 02:42 - 17 Dec 2009    Post subject: Reply with quote
Unlikely to work, meths is very small as a compound so can seep into plastic and slowly leech out over time. Even if you've cleaned it as best you can it's probably not worth the risk of poisoning.
Get a new kettle.
Hex
Party Boy
PostPosted: 12:07 - 17 Dec 2009    Post subject: Reply with quote
Why did you mate do this anyway?
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
PostPosted: 13:11 - 17 Dec 2009    Post subject: Reply with quote
Get a new kettle.
Don't know where you learned chemistry.
Meths is a mostly ethanol with a small quantity of methanol. They usually add a blue dye and bittrex.
The methanol is the poisonous bit. It has a boiling point of 64.7C. The ethanol has a boiling point of 78.3C. So the first time you bring the kettle to the boil with water in (100C), both of those componants will have totally evaporated.
I'm not sure if the dye is poisonous or not but you would see it if it was there as a blue colour.
The bitrex is not poisonous, I 100% garauntee you'd taste it if it was still there.
Both methanol and ethanol are highly hydrophyllic, they will form hydrogen bonds with water in preference to staying as a seperate liquid (or binding to plastic). In fact, Ethanol over 70% will absorb water from the atmosphere.
It was white spirit .. which i assume is the same or similiar to meths
White spirit is a light mineral oil which has virtually nothing in common with meths other than being a flammable liquid. I would have used hot soapy water to clean the kettle out with.
Shreddie
PostPosted: 14:37 - 17 Dec 2009    Post subject: Reply with quote
stinkwheel wrote:
Get a new kettle.
RAPRA, a.k.a the rubber and plastics research agency! Though to be fair, I'm an electromechanical/electronics engineer by trade (or at least I used to be) and worked on manufacturing prototypes when I was there, I'm not a petrochemical engineer!
However, I know for a fact that some, but not all (I should have made that clear) plastics can be affected by ethanol or methanol as it's sometimes used as a treatment. I can't remember which one it is (maybe acrylic) but that can be given a shattered appearance by treating it with methanol. Others may become 'plasticised' (more floppy), those are the ones you have to watch due to the amount they absorb. Most plastics though will be unaffected. If some has been absorbed by a plastic, as it's effectively trapped within, raising its temperature above the boiling point may not get rid of all of it... But as it's not chemically bonded to the plastic, it does have a tendency to leech out over time.
As it's white spirit though, just clean it until it doesn't stink anymore... Or get a new kettle!
PostPosted: 15:08 - 17 Dec 2009    Post subject: Reply with quote
cvntdude wrote:
So Stink .. if i buy some white vinager and boil that in my old metal kettle, and rinse .. thats the ticket ... ? as there is lots of scaly crap in it ...
Yep. Any old vinegar will loosen the limescale. Boil it with the vinegar in, leave it to sit for a bit (obviously, you get a strong smell of vinegar) then rinse out thoroughly. Shiny clean.
You can also buy kettle descaler stuff but it's a lot more expensive than cheap vinegar.
GhostRider
PostPosted: 18:19 - 17 Dec 2009    Post subject: Reply with quote
We get loads of limescale in our kettle at work because we use water from teh water cooler since the tap water is not suitable for drinking. Every couple of weeks it gets treated with 12M sulphuric acid for half hour, which is overkill if you ask me, but he rinses it out well after an this has been going on for well over a year and my oesphagus has not dissolved yet......cleans the kettle a treat though!
GhostRider
The last post was made 16 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 95.86 Kb
