Suzuki GP100 carb woes
GP100Kid
PostPosted: 16:38 - 13 Dec 2009    Post subject: Suzuki GP100 carb woes Reply with quote
Hi all, I am new to motorcycles after years of working on classic cars. I have recently purchased a trio of Suzuki GP100s. I have a carb issue with one bike and have tried to refer to the other two for a resolution but they are earlier models and have a different carb.
The bike I have the issue with is a 1986 model which someone abandoned an engine rebuild on. I have fitted a newly built engine which came with the bike but am unsure to which pipe fits where on the carb. There are two larger brass inlets of the left of the carb body, one points straight up and one at a 45 degree angle. Behind these is a smaller inlet which I assume is the oil feed? The right hand side of the carb has two overflow hoses still in situ, I assume these are just contained within the casing and dont connect to anything on the other end? I hope this makes sense! Got the new motor bolted in, wired up etc just need now to do the final set up, put some oil in and it should be away again!
Thanks for your help in advance! Very Happy
stirlinggaz
PostPosted: 10:02 - 14 Dec 2009    Post subject: Reply with quote
Hi,
~what carb is it?
(should be narked on the side)
as i should have achematic for it here.
your right in thinking 1 will be fuel inlet & another oil inlet.
iirc, its 2 smoke, right?
so the thinner inlet, probably at an angle will be the 2t feed.(any others should be breathers)
didnt these bikes have 6v electrics?
i vaguely remember them, but never owned one.
let us know how you get on.
cheers,
GAZ
GP100Kid
PostPosted: 22:11 - 14 Dec 2009    Post subject: Reply with quote
Hi mate, cheers for getting back to me! I will have a look on the carb and get back with the details, was stupid of me not to have thought to do that in my original post Confused
GP100Kid
PostPosted: 01:18 - 16 Dec 2009    Post subject: Reply with quote
Have had a look on the carb and it just says 'Mikuni' no serial number etc visible. Its similar to this one........
https://cgi.ebay.co.uk/SUZUKI-GP100-GP-100-CARBURETTOR_W0QQitemZ190357464839QQcmdZViewItemQQptZUK_Motorcycle_Parts?hash=item2c52306707
Is that any help Confused
Yes the bike is a 2 smoker and it does have 6v electrics Smile
temeluchus
PostPosted: 01:46 - 16 Dec 2009    Post subject: Reply with quote
I believe this is correct.
GP100Kid
PostPosted: 02:30 - 16 Dec 2009    Post subject: Reply with quote
On the inlet on the left, labelled 'fuel' on your picture, I have another inlet of the same bore below it but at 90 degrees to the carb body rather then 45 as the higher inlet is set. Also on mine, the oil feed pipe is behind the upper left hand fuel inlet rather than being on the right hand side of the carb? Will take a pic tomorrow and post it up Very Happy
Many thanks for your help
temeluchus
PostPosted: 03:20 - 16 Dec 2009    Post subject: Reply with quote
check this out
https://www.cmsnl.com/suzuki-gp100-1983-ud_model13384/partslist/FIG-05.html
GP100Kid
PostPosted: 22:40 - 16 Dec 2009    Post subject: Reply with quote
https://i.ebayimg.com/16/!BhUpORQBWk~$(KGrHqUOKjMErzSTSQEZBLInjhmQJg~~_35.JPG
This is the carb I have, obviously this is a rear shot of it. You can see on the right hand side of this pic, the two larger bore pipes I mean, obviously the small pipe entering the carb mouth is the oil pipe and the overflows are on the other side of the carb so what is this mystery second large pipe? (One at a 45 degree angle and one at 90 degrees?
neilo
PostPosted: 18:56 - 26 Jan 2010    Post subject: carb woes Reply with quote
Hi there are 2 over flow pipes used on the gp100/125 carbs that's what the 2 pipe outlets are for .The carb id number is just behind the tick over screw it will say 39201. This makes it a Mikuni vm22ss which is for the gp100 or 39111. this is a Mikuni vm24ss which is for the gp125 Hopefully this answers your question
Neil
GP100Kid
PostPosted: 20:13 - 26 Jan 2010    Post subject: Reply with quote
Cheers Neil, thats a massive help! Thank you Very Happy
The last post was made 16 years, 239 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 64.46 Kb
