What program to colour diagrams?
Matchless
PostPosted: 06:07 - 18 Dec 2009    Post subject: What program to colour diagrams? Reply with quote
I need to colour some wiring diagrams at times to make them easier to follow;
Does anyone know what program is best to use for colouring the wires?
Thanks and appreciated
Matchless
Thanks & regards
Matchless
27cows
PostPosted: 06:40 - 18 Dec 2009    Post subject: Reply with quote
Might you not be able to find some colour wiring diagrams online? I've seen quite a few in my travels.
Matchless
PostPosted: 06:47 - 18 Dec 2009    Post subject: Reply with quote
No, I want to colour some of those I have, but only get in mono.
Thanks
Thanks & regards
Matchless
PostPosted: 09:28 - 18 Dec 2009    Post subject: Reply with quote
I use Paint. It draws coloured lines and boxes.
Matchless
PostPosted: 09:34 - 18 Dec 2009    Post subject: Reply with quote
Yes have tried it, but can it draw say yellow/black lines? I could only draw single colour lines with it?
Thanks.
Thanks & regards
Matchless
TQ
PostPosted: 09:46 - 18 Dec 2009    Post subject: Reply with quote
Try Paint.net
It's free and it's basically paint on steroids.
I haven't got a copy to hand so I can't confirm it can draw yellow and black lines but it sounds like the kind of thing it would be able to do.
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
Matchless
PostPosted: 20:07 - 18 Dec 2009    Post subject: Reply with quote
TQ wrote:
Try Paint.net
Paint.net also seems to be lacking when needing multi-coloured wires??
Thanks & regards
Matchless
PostPosted: 22:05 - 18 Dec 2009    Post subject: Reply with quote
I do a thick line, then a thin line on top of it for bicoloured wires.
It's white ones that are difficult, you need to do long, thin rectangles.
Do it all big and chunky then scale it down for the final version. Something like photoshop is better for scaling than paint.
Reduce the colour depth to 256 (or even 16) colours.
Don't save the original as a .jpg or .png. Use a lossless format like .bmp or .tif or you'll have trouble editing it later (specifically doing things like flood filling a wire to a different colour, compressed formats pixellate them). If you need to email it you can save a copy as a compressed format and email that but keep the original lossless.
PostPosted: 00:23 - 19 Dec 2009    Post subject: Reply with quote
Tut Tut - "Type of format lossless bitmap image format" from https://en.wikipedia.org/wiki/.png - and, yes, you can check to see that I didn't just edit it to say that Wink.
PNG is basically a betterer .gif, that also doesn't suffer copyright issues that never really happened.
GIMP is worth a look if you want free photo editing stuff - should do all you need in this case.
PostPosted: 11:09 - 19 Dec 2009    Post subject: Reply with quote
MS paint .png files are not proper .png files, it doesn't compress them properly and can screw them up. Fine if using .png in photoshop or GIMP but not MS paint.
I actually use Kolourpaint for linux which is basically the same as MS paint but a bit better at scaling/resizing, handling transparency and undoing.
hmmmnz
PostPosted: 11:19 - 20 Dec 2009    Post subject: Reply with quote
i use visio,
its not perfect, but its better than paint and paint.net
its better than every other program ive tryed,
if you want a multi coloured line, then you have to draw the base line
and then do it again with either a thinner line or a dotted one,
on the plus side it will follow the previous line you've drawn, so isn't too bad.
if you are running win 7 then you'll need visio 2007
if you are running xp then visio pro 2002 is sweet/better but doesnt seem to run on win7
both are on bit torrent and have the codes with them
the humans are dead
I kick arse for the lord
PostPosted: 11:46 - 20 Dec 2009    Post subject: Reply with quote
Fair enough, though I suspect this may be sorted in later versions?
Still use mspaint for screen shots on occasion at work.
Matchless
PostPosted: 11:51 - 20 Dec 2009    Post subject: Reply with quote
Thanks! Visio is about the only program to date I have not looked at for this purpose.
Smartdraw claims to do wiring digrams, but I have not tested it yet and the screenshots all show non colour schematics.
Excellent collection of wiring diagrams you have made available!!!!
Thanks & regards
Matchless
PostPosted: 12:06 - 20 Dec 2009    Post subject: Reply with quote
What about a freeware vector drawing program?
I used open office draw to create this, took a minute.
Use the polygon (45 degree) line drawing tool, when I'd got the layout, set the 'back' colour, copied and pasted it and made the line ontop dotted and changed the colour.
Matchless
PostPosted: 12:39 - 20 Dec 2009    Post subject: Reply with quote
Yes that opens another option that I will try. Basically the perfect one would be a program that can change the wire colours on an existing diagram, but in addition one that will also allow drawing up a complete wiring diagram or modification from scratch.
Thanks, I never even thought of looking at Ooo Draw. Smile
Thanks & regards
Matchless
hmmmnz
PostPosted: 20:37 - 20 Dec 2009    Post subject: Reply with quote
let me know if you find anything, i do quite a few diagrams every month,
all using visio,
https://i675.photobucket.com/albums/vv118/hmmmnz2/yamaha/th_xz400.jpg
have a look in the wiring diagram thread
for more diagrams, might save you a bit of work if the diagram is already there,
and if you do start doing diagrams,
i expect links Very Happy for the greater good and all that Very Happy
the humans are dead
Matchless
PostPosted: 21:06 - 20 Dec 2009    Post subject: Reply with quote
hmmmnz wrote:
let me know if you find anything, i do quite a few diagrams every month, all using visio, and if you do start doing diagrams, i expect links Very Happy for the greater good and all that Very Happy
Will do! Your wiring diagrams are actually one of my main sources when fixing a friends bike.
I am not planning any large scale colouring, just for bikes that may need some time spent on the diagram to fixed up butchered wiring.
I will most likely try Visio soon.
Thanks & regards
Matchless
hmmmnz
PostPosted: 21:22 - 20 Dec 2009    Post subject: Reply with quote
glad i could help
heres the torrents for visio
visio 2007 if you want visio pro 2002 let me know, it doesnt seem to be on bit torrent any more... but i still have a copy on my hard drive, i think its a better program, but it doesnt seem to work on win7 which bites Very Happy[/url]
the humans are dead
Matchless
PostPosted: 09:33 - 08 Jan 2010    Post subject: Reply with quote
I have set up Visio on Win7. Quickly saw that I will need to do a bit of playing around to get the hang of it before it will be useful. Now I just need some spare time.
Thanks for the tip again. Very Happy
By the way do you have a Kymco Zing Wiring Diagram somewhere?
Thanks & regards
Matchless
The last post was made 16 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 104.73 Kb
