| punkrox |
 punkrox Two Stroke Sniffer
| Shaun |
 Shaun Likes 'em bent
| SoND |
 SoND World Chat Champion
| panrider_uk |
 panrider_uk World Chat Champion
| jokmm |
 jokmm Two Stroke Sniffer
| punkrox |
| niceday |
 niceday L Plate Warrior
 Posted: 22:27 - 23 Dec 2009 Post subject: |
Hi, did you recently top up the water (with anifreeze added?). If so, it sounds possible that the head gasket (or o-ring) or bottom cylinder gasket may hav gone. It would be more likely the head o-ring. It's quite simple to replace, cheap too. Drain the radiator by removing the coolant pipe at where it joins the engine block. Disconnect the radiator hose on the cylinder head. Remove the spark plug. Remove the four nuts on the cylinder head (the other bolt head is a bleed screw, loosen this when refilling with antifreeze later). Note, loosen the nuts very gradually, ie loosen one slightly, then do the same to the one diagonally opposite then do the same with the other two. Then lift off the cylinder head. You will see a silicon o-ring and chances are a small bit will be missing or burnt. Put a new o-ring in. Put it back in reverse order, top up oil, top up antifreeze/water, start it up and enjoy! Good luck. |
| punkrox |
| shadowbiker |
 shadowbiker Traffic Copper
| niceday |
| punkrox |
| baldy |
 baldy World Chat Champion
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
