honda cb125td 87
HondaGirl92
PostPosted: 21:47 - 25 Dec 2009    Post subject: honda cb125td 87 Reply with quote
i have a honda CB125TDE i believe 87 reg ,
it has major starting problems
the bike electric start , it will start but it wont keep going it'll just start with enough thats in the carbs and thats it ,
any suggestions ?
she also has a squeak/sqwarking noise sometimes when i use the throttle to start her up with ..
i'm really stuck and want to avoid an engine rebuild as i need her for work etc ...
shadowbiker
PostPosted: 22:44 - 25 Dec 2009    Post subject: Reply with quote
( dont mean to make you sound dumb but ive done this manier times )
have you turned the fuel off ?
cold weather so is the choke on ?
bike left outside ? freezing petrol in pipes and float bowl ?
HondaGirl92
PostPosted: 22:04 - 27 Dec 2009    Post subject: Reply with quote
i fill the carbs will petrol , i've checked the lines , and this happens in the warm and when its been covered.
HondaGirl92
PostPosted: 22:05 - 27 Dec 2009    Post subject: Reply with quote
Frost
PostPosted: 23:57 - 27 Dec 2009    Post subject: Reply with quote
So you press the starter and it gets going. For how long does it run after you let go of the starter button? Does giving it a bit of throttle help? does using the choke make things better or worse?
I had a 1984 one that would only start with 1/4 throttle, a tiny bit more or less and it was impossible. so it might be a case of getting the knack of it rather than an actual mechanical fault.
crackpotterpi...
PostPosted: 00:26 - 28 Dec 2009    Post subject: Reply with quote
could be a fuel tank breather or tap issue,have you disconnected the fuel pipe and turned the tap on does any fuel trickle out? or try taking the fuel cap off and running it to eliminate tank cap breathing problems Smile
1990 jc20 nsr125-sold,2003 cg 125-sold currently no bike.........might get another 2 stroke me thinks much more fun
Frost
PostPosted: 03:22 - 28 Dec 2009    Post subject: Reply with quote
That squeek on startup is also something mine did. I think its the starter clutch making the noise, besides attracting a few odd looks, it was never really a problem Laughing
The last post was made 16 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 55.57 Kb
